[Oskari-user] Oskari 2.0 released!
Aarnio Timo (MML) timo.aarnio at maanmittauslaitos.fi
Wed Sep 23 08:59:34 PDT 2020
Thanks Jeff!
The tweets are out. The first time I did a multi-tweet tweet so.. I'm not sure it turned out right.
Cheers,
Timo
-----Original Message-----
From: Oskari-user <oskari-user-bounces at lists.osgeo.org> On Behalf Of Mäkinen Sami (MML)
Sent: Wednesday, September 23, 2020 6:48 PM
To: Jeff McKenna <jmckenna at gatewaygeomatics.com>; oskari-user at lists.osgeo.org
Subject: Re: [Oskari-user] Oskari 2.0 released!
Thanks Jeff! 😊
I bet we can get a tweet out any minute now.
   Sami
-----Alkuperäinen viesti-----
Lähettäjä: Oskari-user <oskari-user-bounces at lists.osgeo.org> Puolesta Jeff McKenna
Lähetetty: keskiviikko 23. syyskuuta 2020 18.36
Vastaanottaja: oskari-user at lists.osgeo.org
Aihe: Re: [Oskari-user] Oskari 2.0 released!
Congrats!
Can you also tweet this?  I could not find this news, and I didn't want to 'steal your thunder' ha.
-jeff
Jeff McKenna
MapServer Consulting and Training Services co-founder of FOSS4G http://gatewaygeo.com/
On 2020-09-23 12:22 p.m., Mäkinen Sami (MML) wrote:
> Good news everyone,
> We released Oskari 2.0.0 last week (and 2.0.1 for oskari-server just
> now for some search related changes) and it is now available on GitHub
> (https://github.com/oskariorg), Oskari.org Maven repository and on the
> download link in Oskari.org (https://oskari.org/download). We also now
> have a mirror for the sample application download on
> http://download.osgeo.org/oskari/. As always you can take a peek at
> the latest at https://demo.oskari.org/.
> There has been a lot of changes for the server side with just small
> fixes for the frontend compared to 1.56. Upgrading an existing
> Oskari-based application requires some additional manual work so
> please take a look at the
> https://github.com/oskariorg/oskari-server/blob/master/MigrationGuide.
> md. Also note that when updating you will need to upgrade to 1.56.0
> before jumping on to 2.0! This has allowed us to do a lot of cleanup
> on the codebase. TLDR: see end of this message for examples on upgrading!
>   Release Notes for 2.0
>     oskari-frontend
> For a full list of changes see:
> https://github.com/oskariorg/oskari-frontend/milestone/27?closed=1
> The 2.0 release is mainly for upgrading server-side components but we
> want to keep the frontend and server versions in sync. We do have a
> couple of bug fixes included since 1.56.0 but nothing that blows your
> mind with 2.0 fanfares:
>   * Added possibility to show raw HTML from localization with
>     Message-component
>   * Fixed a bug in publisher that resulted in wrong tools being selected
>     to embedded maps than ones based on user choices
>   * Fixed a visual issue with popup height in admin functionality when
>     more than 3 locales are enabled in the Oskari instance
>   * Fixed an issue with MapMoveRequest when requested coordinates
>     required reprojection
>   * Bumped node-sass and lodash versions
>   * Fixed an issue with infobox title height when an empty tag was
>     provided as title
>   * Fixed an issue with infobox when opened to 0,0 coordinates
>     (coordinates are required as numbers now)
>   * Fixed an issue with scales (optional field enabled with
>     configuration) in printout
>   * Fixed an issue with user generated statistical data import from
>     clipboard
>   * Fixed an issue with measurement tools on embedded map
>   * Fixed a visual issue with 3D-timecontrol plugin
>   * Improved and fixed some translations in publisher and admin for sv
>     and en languages
>     oskari-server
>     2.0.1
> Changes coordinates type from string to double on search channels and
> search results. Frontend assumes numbers on 2.0 and most of the code
> casts numbers to strings just for the SearchResultItem setter.
>     2.0.0
> https://github.com/oskariorg/oskari-server/milestone/25?closed=1
>       Important note for the release!
> If you are migrating an older instance to 2.0.0 make sure you migrate
> to
> 1.56.0 first and start your server at least once with a version based
> on Oskari 1.56.0. This is a required step as the database needs to be
> migrated to a specific state before migrating to 2.0.0 and beyond.
> This release aims to be functionally same as 1.56.0 but we have
> included a couple of bug fixes.
>       Maven naming changes
> GroupId for all Oskari Maven artifacts in oskari-server is now
> |org.oskari|. Much of the artifactIds have also been changed to match
> the folder they are in. Details can be found in Migration Guide
> <https://github.com/oskariorg/oskari-server/blob/master/MigrationGuide.md>.
>       Library updates
> We have updated a bunch of libraries that require changes to
> applications based on Oskari. The changes required are detailed in the
> Migration Guide
> .md> and you can also take a look at changes for the
> sample-server-extension
> <https://github.com/oskariorg/sample-server-extension/milestone/5?closed=1> to give you a better idea what these mean for your app.
> Bigger upgrades include:
>   * GeoTools 19.2 -> 23.2
>   * Java Topology Suite (JTS) 1.14.0 -> 1.16.1
>   * Spring Framework 4.3.26 ->
>   * Spring Security etc 4.2.14 -> 5.2.8
>   * Mapbox Vector Tile library 2.0.0 -> 3.1.0
>   * Flyway 4.2 -> 6.5.5
>   * GeoServer 2.13.2 -> 2.17.2 (WPS-modules updated in pre-built package)
>   * Dropped Ibatis (everything now uses MyBatis instead)
> Spring is now managed with "Bill Of Materials" so it's easier for an
> application to use the same version as Oskari-server without
> re-declaring the version (spring artifacts are in managed dependencies
> so you don't have to declare version for them on your app).
> The updates introduce a bunch of code changes that are required to be
> matched on applications based on Oskari. These include Java-package
> changes and even some API changes for Java classes. Details can be
>       Applications and initial content
> Support for setup.json files have been dropped. While this might feel
> like a downgrade it actually makes creating initial content for
> applications simpler and easier to understand. Everything is now done
> using Flyway-migrations and everything you could do with a setup.json
> you can do with migrations. For the oskari-server core modules this
> includes creating database tables for empty database and populating
> them with initial content. We have dropped all the 1.x migrations and
> with that have been able to cleanup the codebase a fair bit.
> We also improved the helpers that can be used with application
> specific Flyway-modules to make registering bundles, map layer and
> appsetup inserts/updates easier in applications. We also renamed some
> of the database tables so table names are now consistent.
> Because of Flyway API changes you will need to modify your application
> specific migrations. Details can be found in Migration Guide
>       Bug fixes
>   * Line color for printing has been fixed (now uses defined style again)
>   * Fixed a caching issue when printing user generated content after
>     changing styling
>   * Fixed an issue with creating PDF having solid lines
> Here are some extra links/examples to help with the migration. These
> are apps we’ve updated for Oskari 2.0 and the changes seen on these
> apps should give you an idea what it could mean for your Oskari-based
> server application (the frontend update is business as usual with nothing extra):
>   * sample-server-extension:
>     https://github.com/oskariorg/sample-server-extension/pull/21/files
>   * Changes for kartta.paikkatietoikkuna.fi:
>     https://github.com/nls-oskari/kartta.paikkatietoikkuna.fi/milestone/18?closed=1
>   * Changes for geoportal.arctic-sdi.org:
> https://github.com/arctic-sdi/oskari-server-extensions/pull/15/files
> Also worth noting I added instructions on oskari.org for the usual
> upgrade process: https://oskari.org/documentation/updating
> Stay safe and happy updating,
>         Sami
Oskari-user mailing list
Oskari-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/oskari-user
More information about the Oskari-user mailing list
