[Oskari-user] Oskari 2.0 released!
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Sep 23 09:28:27 PDT 2020
Loved it Timo!  thanks and great work to the whole team!
-jeff
On 2020-09-23 12:59 p.m., Aarnio Timo (MML) wrote:
> Thanks Jeff!
> The tweets are out. The first time I did a multi-tweet tweet so.. I'm not sure it turned out right.
> Cheers,
> Timo
> -----Original Message-----
> From: Oskari-user <oskari-user-bounces at lists.osgeo.org> On Behalf Of Mäkinen Sami (MML)
> Sent: Wednesday, September 23, 2020 6:48 PM
> To: Jeff McKenna <jmckenna at gatewaygeomatics.com>; oskari-user at lists.osgeo.org
> Subject: Re: [Oskari-user] Oskari 2.0 released!
> Thanks Jeff! 😊
> I bet we can get a tweet out any minute now.
>     Sami
> -----Alkuperäinen viesti-----
> Lähettäjä: Oskari-user <oskari-user-bounces at lists.osgeo.org> Puolesta Jeff McKenna
> Lähetetty: keskiviikko 23. syyskuuta 2020 18.36
> Vastaanottaja: oskari-user at lists.osgeo.org
> Aihe: Re: [Oskari-user] Oskari 2.0 released!
> Congrats!
> Can you also tweet this?  I could not find this news, and I didn't want to 'steal your thunder' ha.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services co-founder of FOSS4G http://gatewaygeo.com/
> On 2020-09-23 12:22 p.m., Mäkinen Sami (MML) wrote:
>> Good news everyone,
>> We released Oskari 2.0.0 last week (and 2.0.1 for oskari-server just
>> now for some search related changes) and it is now available on GitHub
>> (https://github.com/oskariorg), Oskari.org Maven repository and on the
>> download link in Oskari.org (https://oskari.org/download). We also now
>> have a mirror for the sample application download on
>> http://download.osgeo.org/oskari/. As always you can take a peek at
>> the latest at https://demo.oskari.org/.
>> There has been a lot of changes for the server side with just small
>> fixes for the frontend compared to 1.56. Upgrading an existing
>> Oskari-based application requires some additional manual work so
>> please take a look at the
>> https://github.com/oskariorg/oskari-server/blob/master/MigrationGuide.
>> md. Also note that when updating you will need to upgrade to 1.56.0
>> before jumping on to 2.0! This has allowed us to do a lot of cleanup
>> on the codebase. TLDR: see end of this message for examples on upgrading!
>>    Release Notes for 2.0
>>      oskari-frontend
>> For a full list of changes see:
>> https://github.com/oskariorg/oskari-frontend/milestone/27?closed=1
>> The 2.0 release is mainly for upgrading server-side components but we
>> want to keep the frontend and server versions in sync. We do have a
>> couple of bug fixes included since 1.56.0 but nothing that blows your
>> mind with 2.0 fanfares:
>>    * Added possibility to show raw HTML from localization with
>>      Message-component
>>    * Fixed a bug in publisher that resulted in wrong tools being selected
>>      to embedded maps than ones based on user choices
>>    * Fixed a visual issue with popup height in admin functionality when
>>      more than 3 locales are enabled in the Oskari instance
>>    * Fixed an issue with MapMoveRequest when requested coordinates
>>      required reprojection
>>    * Bumped node-sass and lodash versions
>>    * Fixed an issue with infobox title height when an empty tag was
>>      provided as title
>>    * Fixed an issue with infobox when opened to 0,0 coordinates
>>      (coordinates are required as numbers now)
>>    * Fixed an issue with scales (optional field enabled with
>>      configuration) in printout
>>    * Fixed an issue with user generated statistical data import from
>>      clipboard
>>    * Fixed an issue with measurement tools on embedded map
>>    * Fixed a visual issue with 3D-timecontrol plugin
>>    * Improved and fixed some translations in publisher and admin for sv
>>      and en languages
>>      oskari-server
>>      2.0.1
>> Changes coordinates type from string to double on search channels and
>> search results. Frontend assumes numbers on 2.0 and most of the code
>> casts numbers to strings just for the SearchResultItem setter.
>>      2.0.0
>> https://github.com/oskariorg/oskari-server/milestone/25?closed=1
>>        Important note for the release!
>> If you are migrating an older instance to 2.0.0 make sure you migrate
>> to
>> 1.56.0 first and start your server at least once with a version based
>> on Oskari 1.56.0. This is a required step as the database needs to be
>> migrated to a specific state before migrating to 2.0.0 and beyond.
>> This release aims to be functionally same as 1.56.0 but we have
>> included a couple of bug fixes.
>>        Maven naming changes
>> GroupId for all Oskari Maven artifacts in oskari-server is now
>> |org.oskari|. Much of the artifactIds have also been changed to match
>> the folder they are in. Details can be found in Migration Guide
>> <https://github.com/oskariorg/oskari-server/blob/master/MigrationGuide.md>.
>>        Library updates
>> We have updated a bunch of libraries that require changes to
>> applications based on Oskari. The changes required are detailed in the
>> Migration Guide
>> .md> and you can also take a look at changes for the
>> sample-server-extension
>> <https://github.com/oskariorg/sample-server-extension/milestone/5?closed=1> to give you a better idea what these mean for your app.
>> Bigger upgrades include:
>>    * GeoTools 19.2 -> 23.2
>>    * Java Topology Suite (JTS) 1.14.0 -> 1.16.1
>>    * Spring Framework 4.3.26 ->
>>    * Spring Security etc 4.2.14 -> 5.2.8
>>    * Mapbox Vector Tile library 2.0.0 -> 3.1.0
>>    * Flyway 4.2 -> 6.5.5
>>    * GeoServer 2.13.2 -> 2.17.2 (WPS-modules updated in pre-built package)
>>    * Dropped Ibatis (everything now uses MyBatis instead)
>> Spring is now managed with "Bill Of Materials" so it's easier for an
>> application to use the same version as Oskari-server without
>> re-declaring the version (spring artifacts are in managed dependencies
>> so you don't have to declare version for them on your app).
>> The updates introduce a bunch of code changes that are required to be
>> matched on applications based on Oskari. These include Java-package
>> changes and even some API changes for Java classes. Details can be
>>        Applications and initial content
>> Support for setup.json files have been dropped. While this might feel
>> like a downgrade it actually makes creating initial content for
>> applications simpler and easier to understand. Everything is now done
>> using Flyway-migrations and everything you could do with a setup.json
>> you can do with migrations. For the oskari-server core modules this
>> includes creating database tables for empty database and populating
>> them with initial content. We have dropped all the 1.x migrations and
>> with that have been able to cleanup the codebase a fair bit.
>> We also improved the helpers that can be used with application
>> specific Flyway-modules to make registering bundles, map layer and
>> appsetup inserts/updates easier in applications. We also renamed some
>> of the database tables so table names are now consistent.
>> Because of Flyway API changes you will need to modify your application
>> specific migrations. Details can be found in Migration Guide
>>        Bug fixes
>>    * Line color for printing has been fixed (now uses defined style again)
>>    * Fixed a caching issue when printing user generated content after
>>      changing styling
>>    * Fixed an issue with creating PDF having solid lines
>> Here are some extra links/examples to help with the migration. These
>> are apps we’ve updated for Oskari 2.0 and the changes seen on these
>> apps should give you an idea what it could mean for your Oskari-based
>> server application (the frontend update is business as usual with nothing extra):
>>    * sample-server-extension:
>>      https://github.com/oskariorg/sample-server-extension/pull/21/files
>>    * Changes for kartta.paikkatietoikkuna.fi:
>>      https://github.com/nls-oskari/kartta.paikkatietoikkuna.fi/milestone/18?closed=1
>>    * Changes for geoportal.arctic-sdi.org:
>> https://github.com/arctic-sdi/oskari-server-extensions/pull/15/files
>> Also worth noting I added instructions on oskari.org for the usual
>> upgrade process: https://oskari.org/documentation/updating
>> Stay safe and happy updating,
>>          Sami
> Oskari-user mailing list
> Oskari-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/oskari-user
Jeff McKenna
More information about the Oskari-user mailing list
