[pdal-commits] [PDAL/PDAL] 5c8262: move around 1.2-with-color.las and autzen files
GitHub noreply at github.com
Mon Sep 8 12:10:02 PDT 2014
  Branch: refs/heads/issues/441-clean-up-test-data
  Home:   https://github.com/PDAL/PDAL
  Commit: 5c8262beb3b5eba940f3e9e94ceb7da59a98745b
      https://github.com/PDAL/PDAL/commit/5c8262beb3b5eba940f3e9e94ceb7da59a98745b
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-09-08 (Mon, 08 Sep 2014)
  Changed paths:
    M cmake/examples/hobu-config.sh
    R test/data/1.2-with-color-clipped.las
    R test/data/1.2-with-color.las
    R test/data/1.2-with-color.las.wkt
    R test/data/autzen-dd.las
    R test/data/autzen-point-format-3.las
    R test/data/autzen-point-format-3.txt
    R test/data/autzen-selection-dd.wkt
    R test/data/autzen-selection.wkt
    R test/data/autzen-srs.wkt
    R test/data/autzen-thin-srs.las
    R test/data/autzen-thin.las
    R test/data/autzen-utm-chipped-25.las
    R test/data/autzen-utm.las
    R test/data/autzen.jpg
    R test/data/autzen.jpg.aux.xml
    R test/data/autzen.las
    R test/data/autzen.wld
    A test/data/autzen/autzen-dd.las
    A test/data/autzen/autzen-point-format-3.las
    A test/data/autzen/autzen-point-format-3.txt
    A test/data/autzen/autzen-selection-dd.wkt
    A test/data/autzen/autzen-selection.wkt
    A test/data/autzen/autzen-srs.wkt
    A test/data/autzen/autzen-thin-srs.las
    A test/data/autzen/autzen-thin.las
    A test/data/autzen/autzen-utm-chipped-25.las
    A test/data/autzen/autzen-utm.las
    A test/data/autzen/autzen.jpg
    A test/data/autzen/autzen.jpg.aux.xml
    A test/data/autzen/autzen.las
    A test/data/autzen/autzen.wld
    M test/data/filters/colorize-multi.xml
    M test/data/filters/colorize.xml
    M test/data/filters/crop_wkt.xml
    M test/data/filters/crop_wkt_2d.xml
    M test/data/filters/crop_wkt_2d_classification.xml
    M test/data/filters/decimate.xml
    M test/data/filters/hexbin-info.xml
    M test/data/filters/hexbin.xml
    M test/data/filters/reproject.xml
    M test/data/filters/scaling.xml
    M test/data/filters/selector.xml
    M test/data/filters/splitter.xml
    M test/data/filters/stats.xml
    A test/data/las/1.2-with-color-clipped.las
    A test/data/las/1.2-with-color.las
    A test/data/las/1.2-with-color.las.wkt
    M test/data/pipeline/bad/pipeline_bad01.xml
    M test/data/pipeline/bad/pipeline_bad05.xml
    M test/data/pipeline/bad/pipeline_bad06.xml
    M test/data/pipeline/bad/pipeline_bad07.xml
    M test/data/pipeline/bad/pipeline_bad08.xml
    M test/data/pipeline/bad/pipeline_bad09.xml
    M test/data/pipeline/create-dimension.xml
    M test/data/pipeline/drop_color.xml
    M test/data/pipeline/merge.xml
    M test/data/pipeline/pipeline_asc.xml
    M test/data/pipeline/pipeline_interpolate.xml
    M test/data/pipeline/pipeline_multioptions.xml
    M test/data/pipeline/pipeline_nitf.xml
    M test/data/pipeline/pipeline_read.xml
    M test/data/pipeline/pipeline_read_notype.xml
    M test/data/pipeline/pipeline_readcomments.xml
    M test/data/pipeline/pipeline_writecomments.xml
    M test/data/plang/from-module.xml
    M test/data/plang/predicate-embed.xml
    M test/data/plang/predicate-keep-last-return.xml
    M test/data/plang/predicate-keep-specified-returns.xml
    M test/unit/PipelineManagerTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/StageFactoryTest.cpp
    M test/unit/drivers/las/LasReaderTest.cpp
    M test/unit/drivers/las/LasWriterTest.cpp
    M test/unit/drivers/nitf/NitfWriterTest.cpp
    M test/unit/drivers/oci/OCITest.cpp
    M test/unit/drivers/pgpointcloud/PgpointcloudWriterTest.cpp
    M test/unit/drivers/sqlite/SQLiteTest.cpp
    M test/unit/drivers/text/TextWriterTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/InPlaceReprojectionFilterTest.cpp
    M test/unit/filters/PCLBlockFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
  Log Message:
More information about the pdal-commits mailing list
