[pdal-commits] [PDAL/PDAL] 5ec922: more file reorganization #441
GitHub noreply at github.com
Mon Sep 8 13:22:06 PDT 2014
  Branch: refs/heads/issues/441-clean-up-test-data
  Home:   https://github.com/PDAL/PDAL
  Commit: 5ec922162be456a9167c67e848add37d092b25e4
      https://github.com/PDAL/PDAL/commit/5ec922162be456a9167c67e848add37d092b25e4
  Author: Howard Butler <howard at hobu.co>
  Date:   2014-09-08 (Mon, 08 Sep 2014)
  Changed paths:
    R test/data/1.0_0.las
    R test/data/1.0_0_nosrs.las
    R test/data/1.0_1.las
    R test/data/1.0_1_nosrs.las
    R test/data/1.1_0.las
    R test/data/1.1_0_nosrs.las
    R test/data/1.1_1.las
    R test/data/1.1_1_nosrs.las
    R test/data/1.2-no-points.las
    R test/data/1.2_0.las
    R test/data/1.2_0_nosrs.las
    R test/data/1.2_1.las
    R test/data/1.2_1_nosrs.las
    R test/data/1.2_2.las
    R test/data/1.2_2_nosrs.las
    R test/data/1.2_3.las
    R test/data/1.2_3_nosrs.las
    R test/data/TextWriterTest-geojson.json
    R test/data/epsg_4326.las
    A test/data/filters/hextest.txt
    R test/data/hextest.las
    R test/data/hextest.txt
    R test/data/interesting.las
    A test/data/las/epsg_4326.las
    A test/data/las/hextest.las
    A test/data/las/interesting.las
    A test/data/las/lots_of_vlr.las
    A test/data/las/mvk-thin.las
    A test/data/las/mvk-thin.las.wkt
    A test/data/las/no-points.las
    A test/data/las/noise-clean.las
    A test/data/las/noise-dirty.las
    A test/data/las/permutations/1.0_0.las
    A test/data/las/permutations/1.0_1.las
    A test/data/las/permutations/1.1_0.las
    A test/data/las/permutations/1.1_1.las
    A test/data/las/permutations/1.2-no-points.las
    A test/data/las/permutations/1.2_0.las
    A test/data/las/permutations/1.2_1.las
    A test/data/las/permutations/1.2_2.las
    A test/data/las/permutations/1.2_3.las
    A test/data/las/simple.las
    A test/data/las/utm15.las
    A test/data/las/utm17.las
    A test/data/laz/simple.laz
    R test/data/log_py.txt
    A test/data/logs/log_py.txt
    A test/data/logs/logtest.txt
    A test/data/logs/logtest_1.txt
    A test/data/logs/logtest_123.txt
    A test/data/logs/logtest_2.txt
    A test/data/logs/logtest_3.txt
    R test/data/logtest.txt
    R test/data/logtest_1.txt
    R test/data/logtest_123.txt
    R test/data/logtest_2.txt
    R test/data/logtest_3.txt
    R test/data/lots_of_vlr.las
    R test/data/mvk-thin.las
    R test/data/mvk-thin.las.wkt
    R test/data/no-points.las
    R test/data/noise-clean.las
    R test/data/noise-dirty.las
    R test/data/simple.las
    R test/data/simple.laz
    R test/data/text.txt
    A test/data/text/TextWriterTest-geojson.json
    A test/data/text/text.txt
    R test/data/utm15.las
    R test/data/utm17.las
    M test/unit/FileUtilsTest.cpp
    M test/unit/LogTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/StreamFactoryTest.cpp
    M test/unit/SupportTest.cpp
    M test/unit/drivers/las/LasReaderTest.cpp
    M test/unit/filters/HexbinFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
  Log Message:
More information about the pdal-commits mailing list
