[pdal-commits] [PDAL/PDAL] 7bc7fe: initial commit of PDALConfig.cmake
GitHub noreply at github.com
Tue Jan 27 08:25:54 PST 2015
  Branch: refs/heads/issues/version-info
  Home:   https://github.com/PDAL/PDAL
  Commit: 7bc7fe8eefea1bc19c37e9d9985a5c29ff8698ac
      https://github.com/PDAL/PDAL/commit/7bc7fe8eefea1bc19c37e9d9985a5c29ff8698ac
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-01-20 (Tue, 20 Jan 2015)
  Changed paths:
    M CMakeLists.txt
    A PDALConfig.cmake.in
    A cmake/config.cmake
    M cmake/macros.cmake
    A examples/writing/CMakeLists.txt
    A examples/writing/tutorial.cpp
  Log Message:
Those wishing to link against PDAL will not need a FindPDAL.cmake file,
they will only need to set PDAL_DIR to point to PDALConfig.cmake, which
is installed by PDAL (typically in /usr/local/lib/pdal/cmake).
This is a minimal approach for now, only addressing a very basic PDAL
build (i.e., no plugins). It also does not propagate flags, definitions,
etc. as it probably should in the end.
A version of the writing tutorial from the docs is provided as an
example.
  Commit: d13fee7cf169aef6e91835215b1c33c2ce61a2fb
      https://github.com/PDAL/PDAL/commit/d13fee7cf169aef6e91835215b1c33c2ce61a2fb
  Changed paths:
    M CMakeLists.txt
  Log Message:
  we can specify multiple targets on the export line
  Commit: ff7923d57095d9d20b057cbf63b95761252b4ca6
      https://github.com/PDAL/PDAL/commit/ff7923d57095d9d20b057cbf63b95761252b4ca6
  Changed paths:
    M CMakeLists.txt
  Log Message:
  remove redundant export of pdal_util
  Commit: d7722743d3c51f348f8de86a0b51e6532f20ad4c
      https://github.com/PDAL/PDAL/commit/d7722743d3c51f348f8de86a0b51e6532f20ad4c
  Changed paths:
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/GroundFilter.cpp
    A plugins/pcl/filters/GroundFilter.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/GroundKernel.hpp
  Log Message:
  Add `filters.ground` and `kernels.ground`
`filters.ground` is a PDAL filter that calls the PCL PMF code directly (vice
going through PCLBlock or the PCL pipeline)
`kernels.ground` is a PDAL kernel that calls `filters.ground`
The primary motivation for this is so that we can retain all input dimentions,
extracting only ground indices if desired, and labeling as ground if a
Classification dimension is present.
  Commit: 707fa5ef21611c5b1ac7cd96d48cbb48f967aa70
      https://github.com/PDAL/PDAL/commit/707fa5ef21611c5b1ac7cd96d48cbb48f967aa70
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-01-21 (Wed, 21 Jan 2015)
  Changed paths:
    M io/bpf/BpfWriter.cpp
  Log Message:
  Remove debug.
  Commit: 85114890ac499bd7e1e82f97d3e38ca7eb46df22
      https://github.com/PDAL/PDAL/commit/85114890ac499bd7e1e82f97d3e38ca7eb46df22
  Changed paths:
    M CMakeLists.txt
    M scripts/ci/script.sh
    M scripts/vagrant/pdal.sh
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL
  Commit: cfad732f824d491fe97b8e0087399ea2a36eaee7
      https://github.com/PDAL/PDAL/commit/cfad732f824d491fe97b8e0087399ea2a36eaee7
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M src/plang/BufferedInvocation.cpp
  Log Message:
  We were using the default dimension name rather than the actual dimension name for filtering. Custom dimensions ended up being ''
  Commit: 4d76f381277864012f73ff1055b3f7ecf19eb7dd
      https://github.com/PDAL/PDAL/commit/4d76f381277864012f73ff1055b3f7ecf19eb7dd
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/use-real-dimension-name-for-filtering' into issues/version-info
  Commit: ec337278133d65f324cfe7712d0cd9930fa8d0b4
      https://github.com/PDAL/PDAL/commit/ec337278133d65f324cfe7712d0cd9930fa8d0b4
  Changed paths:
    M plugins/python/filters/ProgrammableFilter.cpp
  Log Message:
  make pdal::Dimension::Type::Double dimensions when add_dimension is invoked. We could make it fancy about types later
  Commit: 7a2f496f0e62bb1f3e81e21ea96f8497b3533d3e
      https://github.com/PDAL/PDAL/commit/7a2f496f0e62bb1f3e81e21ea96f8497b3533d3e
  Changed paths:
  Log Message:
  Merge branch 'programmable-makes-double-dimensions' into issues/version-info
  Commit: 440fbd001ad547b7283c0a3db94e05c652e5a900
      https://github.com/PDAL/PDAL/commit/440fbd001ad547b7283c0a3db94e05c652e5a900
  Changed paths:
  Log Message:
  Merge pull request #721 from PDAL/use-real-dimension-name-for-filtering
  Commit: f3a6db1c281d5c8295f03a2cddcf03bdcc698b38
      https://github.com/PDAL/PDAL/commit/f3a6db1c281d5c8295f03a2cddcf03bdcc698b38
  Changed paths:
  Log Message:
  Merge pull request #716 from PDAL/issue/689-ground-filter
  Commit: b127121ad2e900acc4237b44bc62502f3c9b7fbe
      https://github.com/PDAL/PDAL/commit/b127121ad2e900acc4237b44bc62502f3c9b7fbe
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge pull request #714 from PDAL/PDALConfig
Pdal config
  Commit: 291a10986bd33c7c1e998b047baf69d979e16270
      https://github.com/PDAL/PDAL/commit/291a10986bd33c7c1e998b047baf69d979e16270
  Changed paths:
    M include/pdal/plang/Invocation.hpp
    M plugins/python/filters/ProgrammableFilter.hpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M src/plang/Invocation.cpp
  Log Message:
  manual merge
  Commit: b2228bdb2dcd762f7a1e66a72aa954c3ab80a98f
      https://github.com/PDAL/PDAL/commit/b2228bdb2dcd762f7a1e66a72aa954c3ab80a98f
  Changed paths:
    M cmake/examples/hobu-config.sh
  Log Message:
  default my build to building with python
  Commit: 51245efef6fffa4e6ee4f42d15118a396aa87ba1
      https://github.com/PDAL/PDAL/commit/51245efef6fffa4e6ee4f42d15118a396aa87ba1
  Changed paths:
  Log Message:
  read our custom dimension out of ProgrammableFilter
  Commit: 1634fc4be176d0f3ea85e2480d2fe5cbdff5f636
      https://github.com/PDAL/PDAL/commit/1634fc4be176d0f3ea85e2480d2fe5cbdff5f636
  Date:   2015-01-22 (Thu, 22 Jan 2015)
  Changed paths:
    M io/bpf/BpfHeader.hpp
    M io/bpf/BpfReader.cpp
    M test/unit/io/bpf/BPFTest.cpp
  Log Message:
  Fix transformation math according to revised document.
  Commit: 35068a2a6788d3132238773eeb6b2a98a9ee1b13
      https://github.com/PDAL/PDAL/commit/35068a2a6788d3132238773eeb6b2a98a9ee1b13
  Date:   2015-01-24 (Sat, 24 Jan 2015)
  Changed paths:
    M src/plang/Redirector.cpp
  Log Message:
  need <ostream> include
  Commit: 27b68dad2cf68933af8855fe589ddf16e13dd72c
      https://github.com/PDAL/PDAL/commit/27b68dad2cf68933af8855fe589ddf16e13dd72c
  Date:   2015-01-25 (Sun, 25 Jan 2015)
  Changed paths:
    M include/pdal/PointBuffer.hpp
  Log Message:
  Change vector to deque for PointBuffer index.
  Commit: cd543a7e76e3555fb543a83bb85b2515877d6e16
      https://github.com/PDAL/PDAL/commit/cd543a7e76e3555fb543a83bb85b2515877d6e16
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Commit: 0a112340aa2d67ff3e0abe902cf9f83bf94ebcd0
      https://github.com/PDAL/PDAL/commit/0a112340aa2d67ff3e0abe902cf9f83bf94ebcd0
  Changed paths:
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
  Log Message:
  Don't access summary objects through shared pointers.
  Commit: 963f3f846321c2d6bdabfbcd06efba42c9b7bdc2
      https://github.com/PDAL/PDAL/commit/963f3f846321c2d6bdabfbcd06efba42c9b7bdc2
  Changed paths:
    M kernels/Kernel.cpp
  Log Message:
  boost -> std thread, clean up bad merge
  Commit: 41735f72583bef8abf3e0bd43886714080355895
      https://github.com/PDAL/PDAL/commit/41735f72583bef8abf3e0bd43886714080355895
  Date:   2015-01-27 (Tue, 27 Jan 2015)
  Changed paths:
    M kernels/delta/DeltaKernel.cpp
    M kernels/translate/TranslateKernel.cpp
  Log Message:
  min/max/mean typo in delta kernel
  Commit: d3385f575fd568deda97e7e7d4740338fa6ec5ab
      https://github.com/PDAL/PDAL/commit/d3385f575fd568deda97e7e7d4740338fa6ec5ab
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Merge branch 'master' into issues/version-info
Conflicts:
Compare: https://github.com/PDAL/PDAL/compare/641a0dcfa966...d3385f575fd5
More information about the pdal-commits mailing list
