[pdal-commits] [PDAL/PDAL] 47c125: Move Algorithm, Endian, and FileUtils to the util ...
GitHub noreply at github.com
Tue Jan 27 08:51:16 PST 2015
  Branch: refs/heads/move-to-utils
  Home:   https://github.com/PDAL/PDAL
  Commit: 47c125e86ce5b245b64565c2c6137a6b179060bc
      https://github.com/PDAL/PDAL/commit/47c125e86ce5b245b64565c2c6137a6b179060bc
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2015-01-27 (Tue, 27 Jan 2015)
  Changed paths:
    M CMakeLists.txt
    M cmake/directories.cmake
    R include/pdal/Algorithm.hpp
    R include/pdal/Endian.hpp
    R include/pdal/FileUtils.hpp
    M include/pdal/Log.hpp
    A include/pdal/util/Algorithm.hpp
    A include/pdal/util/Endian.hpp
    A include/pdal/util/FileUtils.hpp
    M io/las/LasReader.cpp
    M io/qfit/QfitReader.cpp
    M io/terrasolid/TerrasolidReader.cpp
    M io/text/TextWriter.cpp
    M io/text/TextWriter.hpp
    M kernels/KernelSupport.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.hpp
    M kernels/info/InfoKernel.hpp
    M kernels/pipeline/PipelineKernel.hpp
    M kernels/random/RandomKernel.hpp
    M plugins/icebridge/io/Hdf5Handler.cpp
    M plugins/icebridge/io/IcebridgeReader.cpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/oci/io/OciCommon.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/pcl/io/PcdWriter.hpp
    M plugins/pcl/kernel/GroundKernel.hpp
    M plugins/pcl/kernel/SmoothKernel.hpp
    M plugins/pcl/kernel/ViewKernel.hpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M src/CMakeLists.txt
    R src/FileUtils.cpp
    M src/PipelineReader.cpp
    M src/PipelineWriter.cpp
    M src/StreamFactory.cpp
    M src/plang/Script.cpp
    A src/util/Bounds.cpp
    A src/util/CMakeLists.txt
    A src/util/FileUtils.cpp
    M test/unit/FileUtilsTest.cpp
    M test/unit/GDALUtilsTest.cpp
    M test/unit/PipelineManagerTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/StreamFactoryTest.cpp
    M test/unit/Support.cpp
    M test/unit/SupportTest.cpp
    M test/unit/XMLSchemaTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/apps/pcinfoTest.cpp
    M test/unit/apps/pcpipelineTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/las/LasWriterTest.cpp
    R util/Bounds.cpp
    R util/CMakeLists.txt
    R util/README
    R util/pdal
  Log Message:
  Move Algorithm, Endian, and FileUtils to the util library
More information about the pdal-commits mailing list
