[pdal-commits] [PDAL/PDAL] 95f92b: Remove references to dead --xml option.
GitHub noreply at github.com
Tue Sep 22 12:30:07 PDT 2015
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 95f92b51e7c6d83582afdb103442af9387ab51d4
      https://github.com/PDAL/PDAL/commit/95f92b51e7c6d83582afdb103442af9387ab51d4
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2015-09-22 (Tue, 22 Sep 2015)
  Changed paths:
    M doc/metadata.rst
    M doc/tutorial/reading.rst
  Log Message:
Close #998
  Commit: 52a14f979ee9a6576a2c3d469272b25a24bf8af7
      https://github.com/PDAL/PDAL/commit/52a14f979ee9a6576a2c3d469272b25a24bf8af7
  Changed paths:
    M doc/conf.py
    M doc/docs.rst
    M doc/stages/filters.ferry.rst
    A doc/stages/filters.greedyprojection.rst
    A doc/stages/filters.gridprojection.rst
    A doc/stages/filters.ground.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mortonorder.rst
    A doc/stages/filters.movingleastsquares.rst
    A doc/stages/filters.poisson.rst
    A doc/stages/filters.radiusoutlier.rst
    M doc/stages/filters.splitter.rst
    A doc/stages/filters.statisticaloutlier.rst
    M doc/stages/filters.stats.rst
    A doc/stages/filters.voxelgrid.rst
    M doc/stages/index.rst
    M doc/stages/readers.buffer.rst
    A doc/stages/readers.gdal.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/liblas_to_pdal.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_spec.rst
    M doc/vagrant.rst
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M include/pdal/GDALUtils.hpp
    M io/CMakeLists.txt
    A io/gdal/CMakeLists.txt
    A io/gdal/GDALReader.cpp
    A io/gdal/GDALReader.hpp
    M io/ply/PlyReader.cpp
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/GreedyProjectionFilter.cpp
    A plugins/pcl/filters/GreedyProjectionFilter.hpp
    A plugins/pcl/filters/GridProjectionFilter.cpp
    A plugins/pcl/filters/GridProjectionFilter.hpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.cpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PoissonFilter.cpp
    A plugins/pcl/filters/PoissonFilter.hpp
    A plugins/pcl/filters/RadiusOutlierFilter.cpp
    A plugins/pcl/filters/RadiusOutlierFilter.hpp
    A plugins/pcl/filters/StatisticalOutlierFilter.cpp
    A plugins/pcl/filters/StatisticalOutlierFilter.hpp
    A plugins/pcl/filters/VoxelGridFilter.cpp
    A plugins/pcl/filters/VoxelGridFilter.hpp
    M plugins/pcl/pipeline/PCLPipeline.hpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M src/GDALUtils.cpp
    M src/StageFactory.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/c8b384cf591d...52a14f979ee9
More information about the pdal-commits mailing list
