[pdal-commits] [PDAL/PDAL] 61bcbf: Fix failure on PgpointcloudWriterTest
GitHub noreply at github.com
Tue Sep 22 12:55:12 PDT 2015
  Branch: refs/heads/lasperf
  Home:   https://github.com/PDAL/PDAL
  Commit: 61bcbf5f29ab9c25321abc34fedb02f7eb9be7cf
      https://github.com/PDAL/PDAL/commit/61bcbf5f29ab9c25321abc34fedb02f7eb9be7cf
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2015-09-11 (Fri, 11 Sep 2015)
  Changed paths:
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
  Log Message:
If Postgres is available at runtime but not properly configured for database
creation, or pointcloud extension not available, the tests fail.
Here we sheat by skipping the tests in case of those errors.
It would be good if the infrastructure had a cleaner way of skipping tests
in case a requirement isn't met at runtime.
  Commit: 70d17e424b2d851f351c5beef0d8858ea5c6a672
      https://github.com/PDAL/PDAL/commit/70d17e424b2d851f351c5beef0d8858ea5c6a672
  Author: Howard Butler <howard at hobu.co>
  Date:   2015-09-18 (Fri, 18 Sep 2015)
  Changed paths:
    M doc/stages/readers.buffer.rst
    A doc/stages/readers.gdal.rst
    M filters/colorization/ColorizationFilter.cpp
    M filters/colorization/ColorizationFilter.hpp
    M include/pdal/GDALUtils.hpp
    M io/CMakeLists.txt
    A io/gdal/CMakeLists.txt
    A io/gdal/GDALReader.cpp
    A io/gdal/GDALReader.hpp
    M io/ply/PlyReader.cpp
    M src/GDALUtils.cpp
    M src/StageFactory.cpp
  Log Message:
  readers.gdal reader for reading in raster data as point clouds #996
  Commit: 09b56fcb3debf710e0fffed623dc4973c8a4aafe
      https://github.com/PDAL/PDAL/commit/09b56fcb3debf710e0fffed623dc4973c8a4aafe
  Changed paths:
  Log Message:
  Merge pull request #992 from rouault/avoid_failures_on_pgpointcloudtest
  Commit: 5777b8b7cbdb4c9992ca1ad03bdd6bb7c1a7a07f
      https://github.com/PDAL/PDAL/commit/5777b8b7cbdb4c9992ca1ad03bdd6bb7c1a7a07f
  Changed paths:
  Log Message:
  style tweaks
  Commit: c8b384cf591d49f00109d6f086168bb489a4a7ec
      https://github.com/PDAL/PDAL/commit/c8b384cf591d49f00109d6f086168bb489a4a7ec
  Date:   2015-09-22 (Tue, 22 Sep 2015)
  Changed paths:
    M doc/tutorial/reading.rst
  Log Message:
  no longer refer to XML output #998
  Commit: 95f92b51e7c6d83582afdb103442af9387ab51d4
      https://github.com/PDAL/PDAL/commit/95f92b51e7c6d83582afdb103442af9387ab51d4
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M doc/metadata.rst
  Log Message:
  Remove references to dead --xml option.
Close #998
  Commit: 52a14f979ee9a6576a2c3d469272b25a24bf8af7
      https://github.com/PDAL/PDAL/commit/52a14f979ee9a6576a2c3d469272b25a24bf8af7
  Changed paths:
    M doc/conf.py
    M doc/docs.rst
    M doc/stages/filters.ferry.rst
    A doc/stages/filters.greedyprojection.rst
    A doc/stages/filters.gridprojection.rst
    A doc/stages/filters.ground.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mortonorder.rst
    A doc/stages/filters.movingleastsquares.rst
    A doc/stages/filters.poisson.rst
    A doc/stages/filters.radiusoutlier.rst
    M doc/stages/filters.splitter.rst
    A doc/stages/filters.statisticaloutlier.rst
    M doc/stages/filters.stats.rst
    A doc/stages/filters.voxelgrid.rst
    M doc/stages/index.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/liblas_to_pdal.rst
    M doc/tutorial/overview.rst
    M doc/tutorial/pcl_spec.rst
    M doc/vagrant.rst
    M io/CMakeLists.txt
    M plugins/pcl/CMakeLists.txt
    A plugins/pcl/filters/GreedyProjectionFilter.cpp
    A plugins/pcl/filters/GreedyProjectionFilter.hpp
    A plugins/pcl/filters/GridProjectionFilter.cpp
    A plugins/pcl/filters/GridProjectionFilter.hpp
    M plugins/pcl/filters/GroundFilter.cpp
    M plugins/pcl/filters/GroundFilter.hpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.cpp
    A plugins/pcl/filters/MovingLeastSquaresFilter.hpp
    M plugins/pcl/filters/PCLBlock.cpp
    A plugins/pcl/filters/PoissonFilter.cpp
    A plugins/pcl/filters/PoissonFilter.hpp
    A plugins/pcl/filters/RadiusOutlierFilter.cpp
    A plugins/pcl/filters/RadiusOutlierFilter.hpp
    A plugins/pcl/filters/StatisticalOutlierFilter.cpp
    A plugins/pcl/filters/StatisticalOutlierFilter.hpp
    A plugins/pcl/filters/VoxelGridFilter.cpp
    A plugins/pcl/filters/VoxelGridFilter.hpp
    M plugins/pcl/pipeline/PCLPipeline.hpp
    M src/GDALUtils.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 96f48c39a6884ccb8e4fe85a5d0270d6632addd6
      https://github.com/PDAL/PDAL/commit/96f48c39a6884ccb8e4fe85a5d0270d6632addd6
  Changed paths:
    M doc/metadata.rst
    M io/CMakeLists.txt
    M src/GDALUtils.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into lasperf
Compare: https://github.com/PDAL/PDAL/compare/f2bf939bcd5d...96f48c39a688
More information about the pdal-commits mailing list
