[pdal-commits] [PDAL/PDAL] fa2d11: PipelineKernel should pass verbose/debug settings ...
GitHub
noreply at github.com
Mon Apr 4 20:20:18 PDT 2016
Branch: refs/heads/1.2-maintenance
Home: https://github.com/PDAL/PDAL
Commit: fa2d11a23327811a9b73956cb6358877519255d1
https://github.com/PDAL/PDAL/commit/fa2d11a23327811a9b73956cb6358877519255d1
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-04-01 (Fri, 01 Apr 2016)
Changed paths:
M include/pdal/PipelineManager.hpp
M kernels/pipeline/PipelineKernel.cpp
M src/PipelineManager.cpp
Log Message:
PipelineKernel should pass verbose/debug settings to PipelineManager (and on down to pipeline readers)
Commit: 67d8518c3cf6bddb1138d6cc7e0dcbb8049cf9de
https://github.com/PDAL/PDAL/commit/67d8518c3cf6bddb1138d6cc7e0dcbb8049cf9de
Author: Pete Gadomski <pete.gadomski at gmail.com>
Changed paths:
M CMakeLists.txt
Log Message:
On OSX, don't build with install rpath
This is an identical change to #733. If cmake builds with install rpath
on OSX, `make test` is broken when `BUILD_SHARED_LIBS=ON` on OSX.
Commit: 91d0d9aeab9f5b753c2fcbc7945c3ee954d3d0ec
https://github.com/PDAL/PDAL/commit/91d0d9aeab9f5b753c2fcbc7945c3ee954d3d0ec
Changed paths:
M CMakeLists.txt
Log Message:
Silence BUILD_SHARED_LIBS=ON gtest warnings
When `BUILD_SHARED_LIBS=ON`, gtest emits a couple of cmake warnings, one
about MACOSX_RPATH and one about a missing link_directory. We can quiet
both warnings by setting these properties.
We could also just change gtest's CMakeLists.txt in our vendor
directory, but I'm submitting this change on the principle that the
vendor subdirectories should stay pristine. If vendored software can be
tweaked in our tree, then we should discard this patch and instead fix
things in `vendor/gtest-1.7.0/CMakeLists.txt`.
Commit: fb6c5614a7419cbdbf78e7f2ebfc021bc8dd9735
https://github.com/PDAL/PDAL/commit/fb6c5614a7419cbdbf78e7f2ebfc021bc8dd9735
Author: Bas Couwenberg <sebastic at xs4all.nl>
Date: 2016-04-02 (Sat, 02 Apr 2016)
Changed paths:
M python/VERSION.txt
M python/pdal/__init__.py
Log Message:
Bump Python module version to 1.2.0.
Commit: 30dab884424f4ea63303573a5e65827355f66580
https://github.com/PDAL/PDAL/commit/30dab884424f4ea63303573a5e65827355f66580
Author: Howard Butler <howard at hobu.co>
Changed paths:
Log Message:
Merge pull request #1213 from sebastic/python
Commit: 1df494299440abd53b03d771681696ea054816d7
https://github.com/PDAL/PDAL/commit/1df494299440abd53b03d771681696ea054816d7
Changed paths:
M HOWTORELEASE.txt
Log Message:
add python release stuff to release docs
Commit: a9124dc7ae24cc5f895600c36cdd631304543589
https://github.com/PDAL/PDAL/commit/a9124dc7ae24cc5f895600c36cdd631304543589
Date: 2016-04-03 (Sun, 03 Apr 2016)
Changed paths:
M plugins/icebridge/io/IcebridgeReader.cpp
Log Message:
offset readers.icebridge longitude #1214
Commit: 8b5e2e69e467a90927f17280724fb6ff44e10922
https://github.com/PDAL/PDAL/commit/8b5e2e69e467a90927f17280724fb6ff44e10922
Date: 2016-04-04 (Mon, 04 Apr 2016)
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #1210 from gadomski/gtest-shared-libs
Two changes when building on OSX w/ shared libs
Commit: ab66a6803dee1934006ce75f4f2031981de599f1
https://github.com/PDAL/PDAL/commit/ab66a6803dee1934006ce75f4f2031981de599f1
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M include/pdal/util/Utils.hpp
M io/ilvis2/Ilvis2Reader.cpp
M io/ilvis2/Ilvis2Reader.hpp
M plugins/icebridge/io/IcebridgeReader.hpp
M src/SpatialReference.cpp
M src/util/Utils.cpp
Log Message:
Move normalizeLongitude to Utils.
Commit: 90433dd7912d61cdd4eacd3ecfa7ac1b68eeebea
https://github.com/PDAL/PDAL/commit/90433dd7912d61cdd4eacd3ecfa7ac1b68eeebea
Changed paths:
M CMakeLists.txt
Log Message:
Merge branch 'master' into offset-icebridge-longitude
Commit: 16c7ebb1005e9723ab42157b25033ebed0447c99
https://github.com/PDAL/PDAL/commit/16c7ebb1005e9723ab42157b25033ebed0447c99
Changed paths:
M plugins/icebridge/test/IcebridgeReaderTest.cpp
Log Message:
update icebridge test to account for normalized longitude
Commit: b2849d9a5184378d92ff0b46d7358b4ea9d2d7c1
https://github.com/PDAL/PDAL/commit/b2849d9a5184378d92ff0b46d7358b4ea9d2d7c1
Changed paths:
M plugins/hexbin/CMakeLists.txt
Log Message:
Find Hexer w/ REQUIRED flag
w/o this flag, a user can set `BUILD_PLUGIN_HEXBIN=ON` and successfully
configure, etc without any hexer. IMO that's confusing -- if they ask
for hexer support, CMake should bomb if they don't have it.
Commit: 4f3cade1241872fdc0332b9fc37aeacb00ffec9c
https://github.com/PDAL/PDAL/commit/4f3cade1241872fdc0332b9fc37aeacb00ffec9c
Changed paths:
Log Message:
Merge pull request #1216 from gadomski/fail-if-no-hexer
Commit: c4b30132ea299f8c89eaef51ef16bfe44dac4770
https://github.com/PDAL/PDAL/commit/c4b30132ea299f8c89eaef51ef16bfe44dac4770
Changed paths:
Log Message:
Merge pull request #1209 from PDAL/issue/1208-pipeline-verbose-debug
PipelineKernel should pass verbose/debug settings to PipelineManager …
Commit: b238d4d089b520085cf0b7bea6977b1a3b4343d9
https://github.com/PDAL/PDAL/commit/b238d4d089b520085cf0b7bea6977b1a3b4343d9
Changed paths:
Log Message:
Merge pull request #1215 from PDAL/offset-icebridge-longitude
Commit: ad3eac4759b9ce49757fdeb86c49ad898afcfa47
https://github.com/PDAL/PDAL/commit/ad3eac4759b9ce49757fdeb86c49ad898afcfa47
Changed paths:
M test/unit/UtilsTest.cpp
Log Message:
Fix wordWrap() and add an alternate implementation.
Commit: a1f69b9e21a3cdfe070fa6823c0ceffe1e31ea1e
https://github.com/PDAL/PDAL/commit/a1f69b9e21a3cdfe070fa6823c0ceffe1e31ea1e
Changed paths:
M plugins/hexbin/filters/HexBin.cpp
Log Message:
don't use negative utm zones for hexbin density computation
Commit: e1671c30f1c61cdbcf05ce1395b85abe1ca83906
https://github.com/PDAL/PDAL/commit/e1671c30f1c61cdbcf05ce1395b85abe1ca83906
Changed paths:
M CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/master' into 1.2-maintenance
Compare: https://github.com/PDAL/PDAL/compare/845c33ee792a...e1671c30f1c6
More information about the pdal-commits
