[pdal-commits] [PDAL/PDAL] fa2d11: PipelineKernel should pass verbose/debug settings ...
GitHub
noreply at github.com
Tue Apr 5 07:43:26 PDT 2016
Branch: refs/heads/clear-gdal-errors
Home: https://github.com/PDAL/PDAL
Commit: fa2d11a23327811a9b73956cb6358877519255d1
https://github.com/PDAL/PDAL/commit/fa2d11a23327811a9b73956cb6358877519255d1
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-04-01 (Fri, 01 Apr 2016)
Changed paths:
M include/pdal/PipelineManager.hpp
M kernels/pipeline/PipelineKernel.cpp
M src/PipelineManager.cpp
Log Message:
PipelineKernel should pass verbose/debug settings to PipelineManager (and on down to pipeline readers)
Commit: a9124dc7ae24cc5f895600c36cdd631304543589
https://github.com/PDAL/PDAL/commit/a9124dc7ae24cc5f895600c36cdd631304543589
Author: Howard Butler <howard at hobu.co>
Date: 2016-04-03 (Sun, 03 Apr 2016)
Changed paths:
M plugins/icebridge/io/IcebridgeReader.cpp
Log Message:
offset readers.icebridge longitude #1214
Commit: 90433dd7912d61cdd4eacd3ecfa7ac1b68eeebea
https://github.com/PDAL/PDAL/commit/90433dd7912d61cdd4eacd3ecfa7ac1b68eeebea
Date: 2016-04-04 (Mon, 04 Apr 2016)
Changed paths:
M CMakeLists.txt
M include/pdal/util/Utils.hpp
M io/ilvis2/Ilvis2Reader.cpp
M io/ilvis2/Ilvis2Reader.hpp
M plugins/icebridge/io/IcebridgeReader.hpp
M src/SpatialReference.cpp
M src/util/Utils.cpp
Log Message:
Merge branch 'master' into offset-icebridge-longitude
Commit: 16c7ebb1005e9723ab42157b25033ebed0447c99
https://github.com/PDAL/PDAL/commit/16c7ebb1005e9723ab42157b25033ebed0447c99
Changed paths:
M plugins/icebridge/test/IcebridgeReaderTest.cpp
Log Message:
update icebridge test to account for normalized longitude
Commit: c4b30132ea299f8c89eaef51ef16bfe44dac4770
https://github.com/PDAL/PDAL/commit/c4b30132ea299f8c89eaef51ef16bfe44dac4770
Changed paths:
Log Message:
Merge pull request #1209 from PDAL/issue/1208-pipeline-verbose-debug
PipelineKernel should pass verbose/debug settings to PipelineManager …
Commit: b238d4d089b520085cf0b7bea6977b1a3b4343d9
https://github.com/PDAL/PDAL/commit/b238d4d089b520085cf0b7bea6977b1a3b4343d9
Changed paths:
Log Message:
Merge pull request #1215 from PDAL/offset-icebridge-longitude
Commit: ad3eac4759b9ce49757fdeb86c49ad898afcfa47
https://github.com/PDAL/PDAL/commit/ad3eac4759b9ce49757fdeb86c49ad898afcfa47
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M test/unit/UtilsTest.cpp
Log Message:
Fix wordWrap() and add an alternate implementation.
Commit: 21af82432a7ba6ac45dc0fe8e4e7916c38eede77
https://github.com/PDAL/PDAL/commit/21af82432a7ba6ac45dc0fe8e4e7916c38eede77
Changed paths:
M cmake/examples/hobu-config.sh
M filters/reprojection/ReprojectionFilter.cpp
M filters/reprojection/ReprojectionFilter.hpp
M include/pdal/GDALUtils.hpp
M src/GDALUtils.cpp
M src/Stage.cpp
Log Message:
some experimentation with GDAL error handling
Commit: a1f69b9e21a3cdfe070fa6823c0ceffe1e31ea1e
https://github.com/PDAL/PDAL/commit/a1f69b9e21a3cdfe070fa6823c0ceffe1e31ea1e
Changed paths:
M plugins/hexbin/filters/HexBin.cpp
Log Message:
don't use negative utm zones for hexbin density computation
Commit: b22a9ca4e2c82831664ceba5736888ff807a39d5
https://github.com/PDAL/PDAL/commit/b22a9ca4e2c82831664ceba5736888ff807a39d5
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into clear-gdal-errors
Compare: https://github.com/PDAL/PDAL/compare/42af6505c37c...b22a9ca4e2c8
More information about the pdal-commits
