[pdal-commits] [PDAL/PDAL] 7e723f: Initial TextReader.
GitHub noreply at github.com
Wed Feb 10 12:42:36 PST 2016
  Branch: refs/heads/icebridge-small-features
  Home:   https://github.com/PDAL/PDAL
  Commit: 7e723fc8f43c5672def93116245105fc6cc29d40
      https://github.com/PDAL/PDAL/commit/7e723fc8f43c5672def93116245105fc6cc29d40
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-02-04 (Thu, 04 Feb 2016)
  Changed paths:
    M include/pdal/util/Algorithm.hpp
    M io/text/CMakeLists.txt
    A io/text/TextReader.cpp
    A io/text/TextReader.hpp
  Log Message:
  Initial TextReader.
  Commit: cf9d949c3269c7122a2c7f632046be0987cc3f2e
      https://github.com/PDAL/PDAL/commit/cf9d949c3269c7122a2c7f632046be0987cc3f2e
  Date:   2016-02-05 (Fri, 05 Feb 2016)
  Changed paths:
    A doc/stages/readers.text.rst
    M io/text/TextReader.cpp
    M src/StageFactory.cpp
    A test/data/text/utm17_1.txt
    A test/data/text/utm17_2.txt
    A test/data/text/utm17_3.txt
    M test/unit/CMakeLists.txt
    A test/unit/io/text/TextReaderTest.cpp
  Log Message:
  TextReader with doc and test.
  Commit: 62b1d0e154e14c7181ee2bcf4342800a9a3930db
      https://github.com/PDAL/PDAL/commit/62b1d0e154e14c7181ee2bcf4342800a9a3930db
  Changed paths:
    M io/text/TextReader.hpp
  Log Message:
  Add doxygen.
  Commit: 94253c874fc9c6a8c8cf0ee5557deadbae4106d1
      https://github.com/PDAL/PDAL/commit/94253c874fc9c6a8c8cf0ee5557deadbae4106d1
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-02-09 (Tue, 09 Feb 2016)
  Changed paths:
    M CMakeLists.txt
    M PDALConfig.cmake.in
    M apps/pdal.cpp
    M appveyor.yml
    M doc/contributors.rst
    M doc/stages/readers.gdal.rst
    M doc/tutorial/index.rst
    M examples/writing-kernel/MyKernel.cpp
    M examples/writing-kernel/MyKernel.hpp
    M examples/writing/tutorial.cpp
    M include/pdal/GDALUtils.hpp
    M include/pdal/Kernel.hpp
    M include/pdal/PipelineManager.hpp
    R include/pdal/PipelineReader.hpp
    A include/pdal/util/ProgramArgs.hpp
    M include/pdal/util/Utils.hpp
    M io/ilvis2/Ilvis2Reader.cpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.cpp
    M kernels/diff/DiffKernel.hpp
    M kernels/info/InfoKernel.cpp
    M kernels/info/InfoKernel.hpp
    M kernels/merge/MergeKernel.cpp
    M kernels/merge/MergeKernel.hpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/pipeline/PipelineKernel.hpp
    M kernels/random/RandomKernel.cpp
    M kernels/random/RandomKernel.hpp
    M kernels/sort/SortKernel.cpp
    M kernels/sort/SortKernel.hpp
    M kernels/split/SplitKernel.cpp
    M kernels/split/SplitKernel.hpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/tindex/TIndexKernel.hpp
    M kernels/translate/TranslateKernel.cpp
    M kernels/translate/TranslateKernel.hpp
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/cpd/kernel/Cpd.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/GroundKernel.hpp
    M plugins/pcl/kernel/HeightAboveGroundKernel.cpp
    M plugins/pcl/kernel/HeightAboveGroundKernel.hpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/PCLKernel.hpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.hpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pcl/kernel/ViewKernel.hpp
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M python/pdal/Pipeline.cpp
    M python/pdal/Pipeline.hpp
    M python/test/__init__.py
    M python/test/test_libpdal.py
    A scripts/appveyor/config.cmd
    M scripts/appveyor/install.cmd
    M scripts/ci/script.sh
    M scripts/docker/dependencies/Dockerfile
    M src/CMakeLists.txt
    M src/GDALUtils.cpp
    M src/Kernel.cpp
    M src/KernelSupport.cpp
    M src/PipelineManager.cpp
    M src/PipelineReader.cpp
    A src/PipelineReader.hpp
    M src/util/Utils.cpp
    A test/unit/ProgramArgsTest.cpp
    M test/unit/apps/MergeTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/apps/pcpipelineTest.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderWithMDReaderTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
  Log Message:
  Merge branch 'master' into textreader
  Commit: 2e4b44070cccfd9ff13170ee33ada488241065cf
      https://github.com/PDAL/PDAL/commit/2e4b44070cccfd9ff13170ee33ada488241065cf
  Changed paths:
    M plugins/mrsid/test/MrsidTest.cpp
  Log Message:
  PipelineReader is gone
  Commit: f3012175ab969113377b41b797cce8e204dd7e05
      https://github.com/PDAL/PDAL/commit/f3012175ab969113377b41b797cce8e204dd7e05
  Changed paths:
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    M include/pdal/Metadata.hpp
    M include/pdal/PDALUtils.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/Polygon.hpp
    M include/pdal/SpatialReference.hpp
    M include/pdal/util/Bounds.hpp
    M src/GEOSUtils.cpp
    A src/Metadata.cpp
    M src/Polygon.cpp
    M src/SpatialReference.cpp
    M src/Stage.cpp
    M test/unit/BoundsTest.cpp
    M test/unit/MetadataTest.cpp
    M test/unit/PolygonTest.cpp
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into textreader
  Commit: a99b0ffe03c09aedde22b5f898dd4010bb686acd
      https://github.com/PDAL/PDAL/commit/a99b0ffe03c09aedde22b5f898dd4010bb686acd
  Date:   2016-02-10 (Wed, 10 Feb 2016)
  Changed paths:
  Log Message:
  Merge pull request #1100 from PDAL/textreader
TextReader
  Commit: 739f8eb41f34cacf41fbaed2c9f9373d3b8ce36e
      https://github.com/PDAL/PDAL/commit/739f8eb41f34cacf41fbaed2c9f9373d3b8ce36e
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into icebridge-small-features
Compare: https://github.com/PDAL/PDAL/compare/d492b9153911...739f8eb41f34
More information about the pdal-commits mailing list
