[pdal-commits] [PDAL/PDAL] 7e723f: Initial TextReader.
GitHub noreply at github.com
Fri Feb 12 16:40:09 PST 2016
  Branch: refs/heads/noboost
  Home:   https://github.com/PDAL/PDAL
  Commit: 7e723fc8f43c5672def93116245105fc6cc29d40
      https://github.com/PDAL/PDAL/commit/7e723fc8f43c5672def93116245105fc6cc29d40
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-02-04 (Thu, 04 Feb 2016)
  Changed paths:
    M include/pdal/util/Algorithm.hpp
    M io/text/CMakeLists.txt
    A io/text/TextReader.cpp
    A io/text/TextReader.hpp
  Log Message:
  Initial TextReader.
  Commit: cf9d949c3269c7122a2c7f632046be0987cc3f2e
      https://github.com/PDAL/PDAL/commit/cf9d949c3269c7122a2c7f632046be0987cc3f2e
  Date:   2016-02-05 (Fri, 05 Feb 2016)
  Changed paths:
    A doc/stages/readers.text.rst
    M io/text/TextReader.cpp
    M src/StageFactory.cpp
    A test/data/text/utm17_1.txt
    A test/data/text/utm17_2.txt
    A test/data/text/utm17_3.txt
    M test/unit/CMakeLists.txt
    A test/unit/io/text/TextReaderTest.cpp
  Log Message:
  TextReader with doc and test.
  Commit: 62b1d0e154e14c7181ee2bcf4342800a9a3930db
      https://github.com/PDAL/PDAL/commit/62b1d0e154e14c7181ee2bcf4342800a9a3930db
  Changed paths:
    M io/text/TextReader.hpp
  Log Message:
  Add doxygen.
  Commit: 72e66ed50e61a2b2a3e8496b23f81e8b8772b04d
      https://github.com/PDAL/PDAL/commit/72e66ed50e61a2b2a3e8496b23f81e8b8772b04d
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M include/pdal/util/Bounds.hpp
    M test/unit/BoundsTest.cpp
  Log Message:
  add toGeoJSON to BOX2D
  Commit: 628b6a8ba5979504be6a02ce68c58b172ca777f7
      https://github.com/PDAL/PDAL/commit/628b6a8ba5979504be6a02ce68c58b172ca777f7
  Changed paths:
    M include/pdal/Metadata.hpp
    M include/pdal/PointTable.hpp
    M include/pdal/SpatialReference.hpp
    M src/CMakeLists.txt
    A src/Metadata.cpp
    M src/SpatialReference.cpp
    M test/unit/MetadataTest.cpp
  Log Message:
  pull SpatialReference include out of Metadata header so we can have SpatialReference::getAsMetadata() method
  Commit: 6d8784a9667880eed61f90c88a55ecae3a361948
      https://github.com/PDAL/PDAL/commit/6d8784a9667880eed61f90c88a55ecae3a361948
  Date:   2016-02-07 (Sun, 07 Feb 2016)
  Changed paths:
    M include/pdal/Polygon.hpp
    M src/Polygon.cpp
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Construct a Polygon from a BOX2D. Test using it to reproject BOX2D
  Commit: 85cb8f5b6fd85c1296d125094fe576716d29ad9f
      https://github.com/PDAL/PDAL/commit/85cb8f5b6fd85c1296d125094fe576716d29ad9f
  Date:   2016-02-08 (Mon, 08 Feb 2016)
  Changed paths:
  Log Message:
  need to export MetadataNodeImpl now that we're implementing setValue(SpatialReference) elsewhere
  Commit: 303e241b8e861fa7524097ccc0ad4e0a9c96c9c4
      https://github.com/PDAL/PDAL/commit/303e241b8e861fa7524097ccc0ad4e0a9c96c9c4
  Changed paths:
    M kernels/info/InfoKernel.cpp
    M src/Stage.cpp
  Log Message:
  add 'srs' metadata node
  Commit: 538e6dff6d5a8849f39dad9687077f84c9eb6249
      https://github.com/PDAL/PDAL/commit/538e6dff6d5a8849f39dad9687077f84c9eb6249
  Changed paths:
  Log Message:
  'Polygon' : ambiguous symbol thanks to 'Windows Kits\8.0\Include\um\wingdi.h(4972) : BOOL Polygon(HDC,const POINT *,int)'
  Commit: 0d930a915e36907b57ad64b6c57420a9f673ef4a
      https://github.com/PDAL/PDAL/commit/0d930a915e36907b57ad64b6c57420a9f673ef4a
  Changed paths:
    M src/GEOSUtils.cpp
  Log Message:
  remove debug lint
  Commit: 00a44fa6e31b74529c8a5cdc2609df5477de7d5f
      https://github.com/PDAL/PDAL/commit/00a44fa6e31b74529c8a5cdc2609df5477de7d5f
  Changed paths:
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    M include/pdal/PDALUtils.hpp
    M src/Polygon.cpp
  Log Message:
  Add bbox output to filter.stats, which adds a lat/lon bbox convenience too #1080
  Commit: 1bb0522b2f2e8f3fb3d51bc8ed1410a9d391df27
      https://github.com/PDAL/PDAL/commit/1bb0522b2f2e8f3fb3d51bc8ed1410a9d391df27
  Changed paths:
  Log Message:
  export PDAL_DLL for setValue(SpatialReference&)
  Commit: 8f24711a1bdac494c6e0b6cfe6e511014f95051a
      https://github.com/PDAL/PDAL/commit/8f24711a1bdac494c6e0b6cfe6e511014f95051a
  Changed paths:
    M src/Stage.cpp
  Log Message:
  move toMetadata to Utils for SpatialReference, make sure to PDAL_DLL inferType
  Commit: 673674b63508f4b5a8d1a87da57bafeaa490970b
      https://github.com/PDAL/PDAL/commit/673674b63508f4b5a8d1a87da57bafeaa490970b
  Changed paths:
  Log Message:
  support fetching horizontal and vertical units for convenience #1089
  Commit: cfcc8f1a8d3670976221122985169ab19dac57a3
      https://github.com/PDAL/PDAL/commit/cfcc8f1a8d3670976221122985169ab19dac57a3
  Date:   2016-02-09 (Tue, 09 Feb 2016)
  Changed paths:
    M src/Polygon.cpp
  Log Message:
  output Z dimension for WKT when requested, use that for filter.stats box reprojection
  Commit: 7c9e0288e6a26067470ba76f16def43ceeac50ef
      https://github.com/PDAL/PDAL/commit/7c9e0288e6a26067470ba76f16def43ceeac50ef
  Changed paths:
    M doc/stages/readers.gdal.rst
    M include/pdal/GDALUtils.hpp
    M include/pdal/PipelineManager.hpp
    R include/pdal/PipelineReader.hpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/pipeline/PipelineKernel.hpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/python/test/PredicateFilterTest.cpp
    M plugins/python/test/ProgrammableFilterTest.cpp
    M python/pdal/Pipeline.cpp
    M python/pdal/Pipeline.hpp
    M src/GDALUtils.cpp
    M src/KernelSupport.cpp
    M src/PipelineManager.cpp
    M src/PipelineReader.cpp
    A src/PipelineReader.hpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/io/bpf/BPFTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
    M test/unit/io/ilvis2/Ilvis2ReaderWithMDReaderTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
  Log Message:
  Merge branch 'master' into lat-lon-metadata
  Commit: 287b6c4196c980eef17d6395f3e922cbea6d1261
      https://github.com/PDAL/PDAL/commit/287b6c4196c980eef17d6395f3e922cbea6d1261
  Changed paths:
    M plugins/mrsid/test/MrsidTest.cpp
  Log Message:
  PipelineReader is gone
  Commit: 8690552b810c3e1d5b76631d9e59c4cb18032f17
      https://github.com/PDAL/PDAL/commit/8690552b810c3e1d5b76631d9e59c4cb18032f17
  Changed paths:
    M src/Polygon.cpp
    M test/unit/PolygonTest.cpp
  Log Message:
  remove BOX3D(BOX2D) constructor
  Commit: 94253c874fc9c6a8c8cf0ee5557deadbae4106d1
      https://github.com/PDAL/PDAL/commit/94253c874fc9c6a8c8cf0ee5557deadbae4106d1
  Changed paths:
    M CMakeLists.txt
    M PDALConfig.cmake.in
    M apps/pdal.cpp
    M appveyor.yml
    M doc/contributors.rst
    M doc/tutorial/index.rst
    M examples/writing-kernel/MyKernel.cpp
    M examples/writing-kernel/MyKernel.hpp
    M examples/writing/tutorial.cpp
    M include/pdal/Kernel.hpp
    A include/pdal/util/ProgramArgs.hpp
    M include/pdal/util/Utils.hpp
    M io/ilvis2/Ilvis2Reader.cpp
    M kernels/delta/DeltaKernel.cpp
    M kernels/delta/DeltaKernel.hpp
    M kernels/diff/DiffKernel.cpp
    M kernels/diff/DiffKernel.hpp
    M kernels/info/InfoKernel.hpp
    M kernels/merge/MergeKernel.cpp
    M kernels/merge/MergeKernel.hpp
    M kernels/random/RandomKernel.cpp
    M kernels/random/RandomKernel.hpp
    M kernels/sort/SortKernel.cpp
    M kernels/sort/SortKernel.hpp
    M kernels/split/SplitKernel.cpp
    M kernels/split/SplitKernel.hpp
    M kernels/tindex/TIndexKernel.cpp
    M kernels/tindex/TIndexKernel.hpp
    M kernels/translate/TranslateKernel.cpp
    M kernels/translate/TranslateKernel.hpp
    M plugins/cpd/kernel/Cpd.cpp
    M plugins/cpd/kernel/Cpd.hpp
    M plugins/pcl/kernel/GroundKernel.cpp
    M plugins/pcl/kernel/GroundKernel.hpp
    M plugins/pcl/kernel/HeightAboveGroundKernel.cpp
    M plugins/pcl/kernel/HeightAboveGroundKernel.hpp
    M plugins/pcl/kernel/PCLKernel.cpp
    M plugins/pcl/kernel/PCLKernel.hpp
    M plugins/pcl/kernel/SmoothKernel.cpp
    M plugins/pcl/kernel/SmoothKernel.hpp
    M plugins/pcl/kernel/ViewKernel.cpp
    M plugins/pcl/kernel/ViewKernel.hpp
    M plugins/pgpointcloud/io/PgWriter.cpp
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M python/test/__init__.py
    M python/test/test_libpdal.py
    A scripts/appveyor/config.cmd
    M scripts/appveyor/install.cmd
    M scripts/ci/script.sh
    M scripts/docker/dependencies/Dockerfile
    M src/GDALUtils.cpp
    M src/Kernel.cpp
    M src/util/Utils.cpp
    A test/unit/ProgramArgsTest.cpp
    M test/unit/apps/MergeTest.cpp
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/apps/pcpipelineTest.cpp
  Log Message:
  Merge branch 'master' into textreader
  Commit: 2e4b44070cccfd9ff13170ee33ada488241065cf
      https://github.com/PDAL/PDAL/commit/2e4b44070cccfd9ff13170ee33ada488241065cf
  Changed paths:
  Log Message:
  Commit: 0de42305a4bc8664d2d6c2eaa97243dbbd0fffd6
      https://github.com/PDAL/PDAL/commit/0de42305a4bc8664d2d6c2eaa97243dbbd0fffd6
  Changed paths:
    M src/GEOSUtils.cpp
    A src/Metadata.cpp
    M src/Polygon.cpp
    M src/Stage.cpp
  Log Message:
  Merge pull request #1103 from PDAL/lat-lon-metadata
Output more convenient metadata for bbox and SRS
  Commit: f3012175ab969113377b41b797cce8e204dd7e05
      https://github.com/PDAL/PDAL/commit/f3012175ab969113377b41b797cce8e204dd7e05
  Changed paths:
    M src/GEOSUtils.cpp
    A src/Metadata.cpp
    M src/Polygon.cpp
    M src/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into textreader
  Commit: f08e79b4d2eea499d1db7ba96d1954e3a7575d4c
      https://github.com/PDAL/PDAL/commit/f08e79b4d2eea499d1db7ba96d1954e3a7575d4c
  Date:   2016-02-10 (Wed, 10 Feb 2016)
  Changed paths:
    M doc/api/cpp/index.rst
    A doc/api/cpp/programargs.rst
  Log Message:
  add ProgramArgs docs to Sphinx generation
  Commit: a99b0ffe03c09aedde22b5f898dd4010bb686acd
      https://github.com/PDAL/PDAL/commit/a99b0ffe03c09aedde22b5f898dd4010bb686acd
  Changed paths:
  Log Message:
  Merge pull request #1100 from PDAL/textreader
TextReader
  Commit: d492b91539111b46e4718329629c4bf4f914ae73
      https://github.com/PDAL/PDAL/commit/d492b91539111b46e4718329629c4bf4f914ae73
  Changed paths:
    M io/ilvis2/Ilvis2Reader.hpp
    M plugins/icebridge/io/IcebridgeReader.cpp
    M plugins/icebridge/io/IcebridgeReader.hpp
  Log Message:
  Feature improvements for HDF5-based IceBridge Reader
* Read XML metadata if given using Ilvis2 Metadata Reader
* Normalize longitude to WGS84
* Advertise coordinate system as WGS84
  Commit: 739f8eb41f34cacf41fbaed2c9f9373d3b8ce36e
      https://github.com/PDAL/PDAL/commit/739f8eb41f34cacf41fbaed2c9f9373d3b8ce36e
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into icebridge-small-features
  Commit: 1f86718cafb33faa46c901edf758abe9df9bf26f
      https://github.com/PDAL/PDAL/commit/1f86718cafb33faa46c901edf758abe9df9bf26f
  Changed paths:
  Log Message:
  Merge pull request #1105 from PDAL/icebridge-small-features
  Commit: 97950f87b85348a070c3da7bb29157bf28e34714
      https://github.com/PDAL/PDAL/commit/97950f87b85348a070c3da7bb29157bf28e34714
  Date:   2016-02-11 (Thu, 11 Feb 2016)
  Changed paths:
  Log Message:
  Use a pointcloud_formats_pcid_seq if it is available for schema id generation #1101
  Commit: 9ceb590de50be41312b7a42fa1a63570e1ff6d1d
      https://github.com/PDAL/PDAL/commit/9ceb590de50be41312b7a42fa1a63570e1ff6d1d
  Changed paths:
  Log Message:
  Merge pull request #1107 from PDAL/pgpointcloud-formats-sequence
  Commit: 66545128440d76dce3fc608d643eb9e4ee4db4a1
      https://github.com/PDAL/PDAL/commit/66545128440d76dce3fc608d643eb9e4ee4db4a1
  Changed paths:
    M doc/stages/filters.height.rst
    M plugins/pcl/filters/HeightFilter.cpp
    M plugins/pcl/filters/HeightFilter.hpp
  Log Message:
  have filters.height use HeightAboveGround dimension #1077
  Commit: eb16705504c08a4a7a8577c74926c14d88b70d25
      https://github.com/PDAL/PDAL/commit/eb16705504c08a4a7a8577c74926c14d88b70d25
  Changed paths:
    M doc/compilation/python.rst
  Log Message:
  provide the bbox 'boundary' entry to the filters.stats when no hexbin is linked #920
  Commit: 48d7a74413accba069a0e8514f99e54d48ed1066
      https://github.com/PDAL/PDAL/commit/48d7a74413accba069a0e8514f99e54d48ed1066
  Changed paths:
  Log Message:
  Merge pull request #1108 from PDAL/height-filter-use-heightaboveground-dim
  Commit: bf0ad6ec88c2c5acca23646103b4fbf8ff11a1f1
      https://github.com/PDAL/PDAL/commit/bf0ad6ec88c2c5acca23646103b4fbf8ff11a1f1
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    M io/derivative/DerivativeWriter.cpp
  Log Message:
  We must stop one short of the number of rows (y)
  Commit: 4c6ebca5c2f06698541cb4a7ae75f2c63b5aa6be
      https://github.com/PDAL/PDAL/commit/4c6ebca5c2f06698541cb4a7ae75f2c63b5aa6be
  Changed paths:
  Log Message:
  Merge pull request #1111 from PDAL/bad-index-derivative-writer
  Commit: 81c55937ed4e107c503a62cedf0dc57f81a34f0a
      https://github.com/PDAL/PDAL/commit/81c55937ed4e107c503a62cedf0dc57f81a34f0a
  Changed paths:
  Log Message:
  Merge pull request #1110 from PDAL/boundary-no-hexbin
  Commit: d8b7790ea501e769b1cda78a3b4eb544f5522dcb
      https://github.com/PDAL/PDAL/commit/d8b7790ea501e769b1cda78a3b4eb544f5522dcb
  Changed paths:
    M src/GDALUtils.cpp
  Log Message:
  Fix logic for reading raster bands.
  Commit: 83db43e04cee1bdd1ebf968b6700b6776da91c2b
      https://github.com/PDAL/PDAL/commit/83db43e04cee1bdd1ebf968b6700b6776da91c2b
  Changed paths:
    M src/GEOSUtils.cpp
    A src/Metadata.cpp
    M src/Polygon.cpp
    M src/Stage.cpp
  Log Message:
  Commit: c7f931cdbdc6c063b8a3b62b2873a66d509e6f29
      https://github.com/PDAL/PDAL/commit/c7f931cdbdc6c063b8a3b62b2873a66d509e6f29
  Date:   2016-02-12 (Fri, 12 Feb 2016)
  Changed paths:
    M src/GDALUtils.cpp
    M src/GEOSUtils.cpp
    A src/Metadata.cpp
    M src/Polygon.cpp
    M src/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into noboost
Conflicts:
  Commit: 4e44e14b2916ebd4b8e91e5b050e375531d3bb7a
      https://github.com/PDAL/PDAL/commit/4e44e14b2916ebd4b8e91e5b050e375531d3bb7a
  Changed paths:
    M vendor/pdalboost/boost/property_tree/detail/json_parser/narrow_encoding.hpp
  Log Message:
  Remove assert.
  Commit: c0e4eaec251ff26e6677146faedacd70eeae82c4
      https://github.com/PDAL/PDAL/commit/c0e4eaec251ff26e6677146faedacd70eeae82c4
  Changed paths:
    M include/pdal/util/ProgramArgs.hpp
  Log Message:
  Handle ioctl failure.
Make ProgramArgs enum a class enum.
  Commit: 2a95f4db34a8be7448df3d00c4b4f14ae1bcec29
      https://github.com/PDAL/PDAL/commit/2a95f4db34a8be7448df3d00c4b4f14ae1bcec29
  Changed paths:
    M cmake/unix_compiler_options.cmake
    M src/GDALUtils.cpp
  Log Message:
  Remove duplicate call to GDALReadBlock.
Turn warning into errors on Linux.
  Commit: 4004ea398bf9c75a706e6146b12044071261d196
      https://github.com/PDAL/PDAL/commit/4004ea398bf9c75a706e6146b12044071261d196
  Changed paths:
    M pdal_defines.h.in
    M src/pdal_config.cpp
  Log Message:
  Remove unused PDAL_HAVE's
  Commit: 9bf2dc2850b1d4bce61d2c6877f15b5d32c35388
      https://github.com/PDAL/PDAL/commit/9bf2dc2850b1d4bce61d2c6877f15b5d32c35388
  Changed paths:
  Log Message:
  Make filter an optional positional argument in the translate kernel.
  Commit: 9a7f5519695e40f9d5b4ec1e5abf2f46d223400b
      https://github.com/PDAL/PDAL/commit/9a7f5519695e40f9d5b4ec1e5abf2f46d223400b
  Changed paths:
    M plugins/pcl/CMakeLists.txt
  Log Message:
  Suppress warning for PCL.
  Commit: c43ad8949083ed0e44fd109d2fb832710240071e
      https://github.com/PDAL/PDAL/commit/c43ad8949083ed0e44fd109d2fb832710240071e
  Changed paths:
    M pdal_defines.h.in
  Log Message:
  Merge pull request #1114 from PDAL/issues/1113
  Commit: ccc5e4cac8096dd90bcd1d123a67a2c8e1cd7681
      https://github.com/PDAL/PDAL/commit/ccc5e4cac8096dd90bcd1d123a67a2c8e1cd7681
  Changed paths:
  Log Message:
  Commit: ef9987787237a7a69590963437c226abbedae298
      https://github.com/PDAL/PDAL/commit/ef9987787237a7a69590963437c226abbedae298
  Changed paths:
    M pdal_defines.h.in
    M src/GDALUtils.cpp
  Log Message:
  Commit: 36110220ab9c5e1745042d9576b0c42d779be490
      https://github.com/PDAL/PDAL/commit/36110220ab9c5e1745042d9576b0c42d779be490
  Changed paths:
    M vendor/pdalboost/CMakeLists.txt
  Log Message:
  Add -fPIC for libpdal_boost stuff.
Compare: https://github.com/PDAL/PDAL/compare/86899ddc58de...36110220ab9c
More information about the pdal-commits mailing list
