[pdal-commits] [PDAL/PDAL] b56b69: Add an FAQ about missing plugins.
GitHub noreply at github.com
Mon Sep 11 09:58:16 PDT 2017
  Branch: refs/heads/laszip
  Home:   https://github.com/PDAL/PDAL
  Commit: b56b699696c111186f5514ef0654720b1a190146
      https://github.com/PDAL/PDAL/commit/b56b699696c111186f5514ef0654720b1a190146
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-08-24 (Thu, 24 Aug 2017)
  Changed paths:
    M doc/faq.rst
  Log Message:
  Commit: 9636f052b0682e46cb72bdb726d9b4164613de1c
      https://github.com/PDAL/PDAL/commit/9636f052b0682e46cb72bdb726d9b4164613de1c
  Changed paths:
    M doc/faq.rst
  Log Message:
  Fix a typo.
  Commit: ce970a5da0966f43269f76448b0a584d0e21580c
      https://github.com/PDAL/PDAL/commit/ce970a5da0966f43269f76448b0a584d0e21580c
  Author: Adam Steer <adamsteer at users.noreply.github.com>
  Changed paths:
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.greyhound.rst
    M doc/stages/readers.ilvis2.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.mbio.rst
    M doc/stages/readers.mrsid.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.optech.rst
    M doc/stages/readers.pcd.rst
    M doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.ply.rst
    M doc/stages/readers.pts.rst
    M doc/stages/readers.qfit.rst
    M doc/stages/readers.sbet.rst
    M doc/stages/readers.sqlite.rst
    M doc/stages/readers.text.rst
    M doc/stages/readers.tindex.rst
  Log Message:
  #1591: add --count to html docs (#1649)
* add --count option
* does readers.buffer have a --count option? not listed in --options
* add a needed comma to the LAS pipeline
* actually not sure if readers.mrsid has --count, not available in my docker instance
* removed duplicate spatialreference option heading
* add --count option (#1591)
  Commit: 3d1cf9b6d41d3c02101e49abe459957ada1aa6a0
      https://github.com/PDAL/PDAL/commit/3d1cf9b6d41d3c02101e49abe459957ada1aa6a0
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-08-25 (Fri, 25 Aug 2017)
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  don't attempt to write a pdal_metadata VLR if > LasVLR::MAX_DATA_SIZE and minor_version < 4
  Commit: 4f25afc7baba8f1931f3273a2dbe28bf61387f4d
      https://github.com/PDAL/PDAL/commit/4f25afc7baba8f1931f3273a2dbe28bf61387f4d
  Date:   2017-08-28 (Mon, 28 Aug 2017)
  Changed paths:
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Fix LASZIP in pipeline test.
  Commit: 31683bcba4d4e9fa2b94b00d501758dfb264e641
      https://github.com/PDAL/PDAL/commit/31683bcba4d4e9fa2b94b00d501758dfb264e641
  Changed paths:
    M io/LasReader.cpp
    M test/unit/io/LasReaderTest.cpp
  Log Message:
  Put encoded LAS VLR in its own node.
Close #1648
  Commit: a77d62938e0904d8af82293d48a8351e7d8443a0
      https://github.com/PDAL/PDAL/commit/a77d62938e0904d8af82293d48a8351e7d8443a0
  Author: Jason Beverage <jasonbeverage at gmail.com>
  Date:   2017-08-29 (Tue, 29 Aug 2017)
  Changed paths:
    M filters/GreedyProjection.hpp
  Log Message:
  Added PDAL_DLL to GreedyProjection
  Commit: 221d887d843140c19282f4616d6b626f0f6b46c5
      https://github.com/PDAL/PDAL/commit/221d887d843140c19282f4616d6b626f0f6b46c5
  Changed paths:
  Log Message:
  Merge pull request #1655 from jasonbeverage/exportgreedprojection
  Commit: 53fda433829946e8635ebd96cfe08ef05076d703
      https://github.com/PDAL/PDAL/commit/53fda433829946e8635ebd96cfe08ef05076d703
  Changed paths:
    M PDALConfig.cmake.in
  Log Message:
  Fix for windows linking in PDALTargets.cmake.in
  Commit: 490f56e2603538ad55b1d7ab14513300fe59e98b
      https://github.com/PDAL/PDAL/commit/490f56e2603538ad55b1d7ab14513300fe59e98b
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  LasVLR::MAX_DATA_SIZE is never used, use USHRT_MAX for VLR size test
  Commit: d68e5412d8a4eb5c9e9fda4cae2a1bed69520ed1
      https://github.com/PDAL/PDAL/commit/d68e5412d8a4eb5c9e9fda4cae2a1bed69520ed1
  Changed paths:
    M io/LasReader.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: 2d550fab1e257d0103984eb7f0fb5fa23398eacf
      https://github.com/PDAL/PDAL/commit/2d550fab1e257d0103984eb7f0fb5fa23398eacf
  Changed paths:
  Log Message:
  Changed PDALConfig.cmake.in to only include pdal_util in addition to
pdalcpp and not the other libraries.
pdal_util is only included on WIN32
  Commit: 8b1dabc36c249af58cbee678679f152f29a378af
      https://github.com/PDAL/PDAL/commit/8b1dabc36c249af58cbee678679f152f29a378af
  Date:   2017-08-30 (Wed, 30 Aug 2017)
  Changed paths:
  Log Message:
  Changed pdal_util to @PDAL_UTIL_LIB_NAME@
  Commit: a7bedd265e8167b13d499681b50b82cb72de6a87
      https://github.com/PDAL/PDAL/commit/a7bedd265e8167b13d499681b50b82cb72de6a87
  Changed paths:
  Log Message:
  Merge pull request #1656 from jasonbeverage/cmakelibs
  Commit: aeac9a23a658a406e83ecffa7fd3ff51ebfb7396
      https://github.com/PDAL/PDAL/commit/aeac9a23a658a406e83ecffa7fd3ff51ebfb7396
  Changed paths:
    M pdal/DimUtil.hpp
    M pdal/PointLayout.cpp
  Log Message:
  Increase the number of allowable proprietary dimensions to 4095.
Throw an error if an attempt is made to assign more than 4095 proprietary dims.
Close #1657
  Commit: 46ff1fc7f3fc0ec04c6cfa0e79d479fc86d4bf7d
      https://github.com/PDAL/PDAL/commit/46ff1fc7f3fc0ec04c6cfa0e79d479fc86d4bf7d
  Changed paths:
    M io/LasReader.cpp
    M io/LasWriter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: d5a3ca72a46d8b0fc0c06672ccba2469cdc11423
      https://github.com/PDAL/PDAL/commit/d5a3ca72a46d8b0fc0c06672ccba2469cdc11423
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M pdal/util/Utils.cpp
    M pdal_defines.h.in
  Log Message:
  Check for execinfo/backtrace
  Commit: f08213bb9880f27c2937c162fceceb79d7fb13d4
      https://github.com/PDAL/PDAL/commit/f08213bb9880f27c2937c162fceceb79d7fb13d4
  Changed paths:
    M apps/pdal.cpp
  Log Message:
  It is enough to check for PDAL_HAVE_EXECINFO_H
  Commit: 1b1ef093ff21634f08bebdfdf0787816cd57c301
      https://github.com/PDAL/PDAL/commit/1b1ef093ff21634f08bebdfdf0787816cd57c301
  Date:   2017-08-31 (Thu, 31 Aug 2017)
  Changed paths:
    M filters/private/DimRange.cpp
    A test/data/text/numeric_dim.txt
    M test/unit/filters/RangeFilterTest.cpp
  Log Message:
  Use good logic to parse dimension names.
Close #1659
  Commit: 6c3802b0e96f559dc30fe274f1bc56c7a72f1256
      https://github.com/PDAL/PDAL/commit/6c3802b0e96f559dc30fe274f1bc56c7a72f1256
  Changed paths:
  Log Message:
  Don't repeat test.
  Commit: d181fc123f6026eea5008f6dd21d86f94f458695
      https://github.com/PDAL/PDAL/commit/d181fc123f6026eea5008f6dd21d86f94f458695
  Changed paths:
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M pdal/DimUtil.hpp
  Log Message:
  Commit: 5bd09efa69d66eda122162f4e7b6a1797439994f
      https://github.com/PDAL/PDAL/commit/5bd09efa69d66eda122162f4e7b6a1797439994f
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M pdal_defines.h.in
  Log Message:
  Merge pull request #1658 from PDAL/execinfo-guards
  Commit: e2060fd42252e2a3e0edfa9444d9269df03fb1fa
      https://github.com/PDAL/PDAL/commit/e2060fd42252e2a3e0edfa9444d9269df03fb1fa
  Date:   2017-09-01 (Fri, 01 Sep 2017)
  Changed paths:
    M CMakeLists.txt
    A cmake/arbiter.cmake
    M cmake/curl.cmake
    M cmake/json.cmake
    M pdal/PDALUtils.cpp
    M vendor/arbiter/CMakeLists.txt
  Log Message:
  Update build to make curl/arbiter relationship more clear.
  Commit: 9fb941724fe08e2fca115f147199c8aac2d412dd
      https://github.com/PDAL/PDAL/commit/9fb941724fe08e2fca115f147199c8aac2d412dd
  Changed paths:
    M CMakeLists.txt
    M cmake/curl.cmake
    M cmake/json.cmake
  Log Message:
  Merge pull request #1662 from PDAL/arbiter-cmake
  Commit: b67103c2d9ba31b28480315ac131f100ab5dee36
      https://github.com/PDAL/PDAL/commit/b67103c2d9ba31b28480315ac131f100ab5dee36
  Date:   2017-09-05 (Tue, 05 Sep 2017)
  Changed paths:
    M plugins/matlab/filters/MatlabFilter.cpp
    M plugins/matlab/filters/MatlabFilter.hpp
    M plugins/matlab/filters/Script.cpp
    M plugins/matlab/filters/Script.hpp
    M plugins/matlab/io/MatlabReader.cpp
    M plugins/matlab/io/MatlabReader.hpp
    M plugins/matlab/io/MatlabWriter.cpp
    M plugins/matlab/io/MatlabWriter.hpp
    M plugins/matlab/test/MatlabReaderTest.cpp
    M test/data/matlab/autzen.mat
  Log Message:
  metadata and srs support for Matlab stages
  Commit: ac8abc1937d4544155f9e9f689ac50f9f0168a45
      https://github.com/PDAL/PDAL/commit/ac8abc1937d4544155f9e9f689ac50f9f0168a45
  Date:   2017-09-07 (Thu, 07 Sep 2017)
  Changed paths:
    M doc/stages/writers.gdal.rst
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M pdal/DimUtil.hpp
    M pdal/EigenUtils.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M test/data/gdal/grid.txt
    M test/unit/io/GDALWriterTest.cpp
  Log Message:
  Allow all datatypes for writers.gdal raster output.
Allow specification of the writers.gdal nodata value.
  Commit: 7403bd77bc25a515a8d4e6a30cc5358437fb4097
      https://github.com/PDAL/PDAL/commit/7403bd77bc25a515a8d4e6a30cc5358437fb4097
  Changed paths:
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasUtils.cpp
    M io/LasUtils.hpp
  Log Message:
  add ignore_vlr option to readers.las #1651 (#1664)
  Commit: 295bc3fefc08db5382f43778879103bd34ee2204
      https://github.com/PDAL/PDAL/commit/295bc3fefc08db5382f43778879103bd34ee2204
  Changed paths:
    M pdal/StageFactory.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
  Log Message:
  SQLite updates to support GPKG (#1654)
  Commit: eca8bd1c5272b9cc4270372e4d182fe4acb5836d
      https://github.com/PDAL/PDAL/commit/eca8bd1c5272b9cc4270372e4d182fe4acb5836d
  Author: Grisha <gr.pomadchin at gmail.com>
  Changed paths:
    M HOWTORELEASE.txt
    M java/README.md
    M java/build.sbt
    A java/core-scala/src/main/scala/io/pdal/pipeline/ExprType.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/WriterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/package.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/package.scala
    A java/core-scala/src/test/scala/io/pdal/pipeline/PipelineExpressionsSpec.scala
    M java/project/Commands.scala
    A java/project/Dependencies.scala
    A java/project/Version.scala
    M java/project/build.properties
    M java/project/plugins.sbt
    M java/sbt
    M java/scripts/publish-212.sh
    M java/scripts/publish-javastyle.sh
    M java/scripts/publish-local-212.sh
    M java/scripts/publish-local.sh
    M java/scripts/publish.sh
    M scripts/ci/script.sh
  Log Message:
  PDAL scala (#1492)
* init
* more implicits to make library more scala like; jts dep
* add specs and ci tests
* RM a scala folder
* Move to SBT 1.0.0
* Updated README.md and HOWTORELEASE, published 1.4.1-SNAPSHOT
* Update Scala API up to PDAL 1.5
* Fix publishJavastyle command
* Bump versions up to 1.5.0
* Change licence headers
* Change core-scala license, updated README.md
* Update sbt and plugins up to stable
  Commit: 5fbba0bdbad8a1363f516fa00789e70f68fdd6e7
      https://github.com/PDAL/PDAL/commit/5fbba0bdbad8a1363f516fa00789e70f68fdd6e7
  Date:   2017-09-08 (Fri, 08 Sep 2017)
  Changed paths:
    M pdal/PipelineManager.cpp
    R pdal/PipelineReaderXML.cpp
    R pdal/private/PipelineReaderXML.hpp
    R test/unit/apps/pcinfoTest.cpp
  Log Message:
  Remove XML pipeline support.
Close #1666
  Commit: 07f8bfcd488e079781b195c2381070bb26db96f8
      https://github.com/PDAL/PDAL/commit/07f8bfcd488e079781b195c2381070bb26db96f8
  Changed paths:
  Log Message:
  Fix publish scripts to correspond HOWTORELEASE.txt (#1665)
  Commit: 9a1d4660a3c14c7eb765189fef7c53e759e0af37
      https://github.com/PDAL/PDAL/commit/9a1d4660a3c14c7eb765189fef7c53e759e0af37
  Changed paths:
    M doc/faq.rst
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M pdal/DimUtil.hpp
  Log Message:
  Merge branch 'master' into laszip
  Commit: c00af3ebbdea56c485396996721f58cbcd04b8e3
      https://github.com/PDAL/PDAL/commit/c00af3ebbdea56c485396996721f58cbcd04b8e3
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M apps/pdal.cpp
    M cmake/curl.cmake
    M cmake/json.cmake
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasUtils.cpp
    M io/LasUtils.hpp
    M java/README.md
    M java/build.sbt
    M java/sbt
    M pdal/DimUtil.hpp
    M pdal_defines.h.in
  Log Message:
  Commit: 181f6999696a73b86a83066dcf72bc2bfef6298a
      https://github.com/PDAL/PDAL/commit/181f6999696a73b86a83066dcf72bc2bfef6298a
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Roll back 23963719ae107176bb076628ca467fdf4c4d3b59
  Commit: b019784098260b16e9d342ace4545d20b5f353ac
      https://github.com/PDAL/PDAL/commit/b019784098260b16e9d342ace4545d20b5f353ac
  Changed paths:
    M io/LasHeader.cpp
  Log Message:
  remove dead code
  Commit: e0c4d980dc8decbde52f590a3e96f9c508d1a380
      https://github.com/PDAL/PDAL/commit/e0c4d980dc8decbde52f590a3e96f9c508d1a380
  Date:   2017-09-11 (Mon, 11 Sep 2017)
  Changed paths:
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M io/LasWriter.cpp
  Log Message:
  Use functions/constants and simplify code.
  Commit: a9eb3d2202bf862c57567f0e5d60535b9f7c4c3c
      https://github.com/PDAL/PDAL/commit/a9eb3d2202bf862c57567f0e5d60535b9f7c4c3c
  Changed paths:
    R test/data/hole/autzen-dd.las
    R test/data/hole/hole.dbf
    R test/data/hole/hole.las
    R test/data/hole/hole.prj
    R test/data/hole/hole.qpj
    R test/data/hole/hole.shp
    R test/data/hole/hole.shx
    R test/data/hole/make-spurious.py
    R test/data/hole/spurious.las
    A test/data/las/spurious.las
    M test/data/pipeline/crop-hole.json.in
  Log Message:
  Remove unused data.
  Commit: 298ea371b8228eb221384db6570edf6dc370a920
      https://github.com/PDAL/PDAL/commit/298ea371b8228eb221384db6570edf6dc370a920
  Changed paths:
    M CMakeLists.txt
    M io/LasHeader.cpp
  Log Message:
  Commit: 60d613a4d384c3da9743bba332cbe1e058c1c01c
      https://github.com/PDAL/PDAL/commit/60d613a4d384c3da9743bba332cbe1e058c1c01c
  Changed paths:
    M doc/stages/filters.greedyprojection.rst
    M doc/stages/writers.ply.rst
  Log Message:
  Doc updates.
  Commit: da08a8c454fd26b60461695fd3d4579e6c945695
      https://github.com/PDAL/PDAL/commit/da08a8c454fd26b60461695fd3d4579e6c945695
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M apps/pdal.cpp
    M cmake/curl.cmake
    M cmake/json.cmake
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasUtils.cpp
    M io/LasUtils.hpp
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M io/LasWriter.cpp
    M java/README.md
    M java/build.sbt
    M java/sbt
    M pdal/DimUtil.hpp
    M pdal_defines.h.in
  Log Message:
  Merge remote-tracking branch 'origin/master' into laszip
Compare: https://github.com/PDAL/PDAL/compare/a37e279f9e80...da08a8c454fd
More information about the pdal-commits mailing list
