[pdal-commits] [PDAL/PDAL] 62a560: Merge branch 'master' into laszip
GitHub noreply at github.com
Tue Sep 12 10:16:27 PDT 2017
  Branch: refs/heads/laszip
  Home:   https://github.com/PDAL/PDAL
  Commit: 62a56037be894c5f6f1a22ce1035cfc71c48d91d
      https://github.com/PDAL/PDAL/commit/62a56037be894c5f6f1a22ce1035cfc71c48d91d
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-09-11 (Mon, 11 Sep 2017)
  Changed paths:
    M .gitignore
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M PDALConfig.cmake.in
    M apps/pdal.cpp
    A cmake/arbiter.cmake
    M cmake/curl.cmake
    M cmake/examples/hobu-config.sh
    M cmake/json.cmake
    M cmake/matlab.cmake
    M cmake/modules/FindMatlab.cmake
    A cmake/modules/FindOSG.cmake
    A cmake/openscenegraph.cmake
    M cmake/options.cmake
    M doc/_static/breathe.css
    M doc/_static/sphinx.css
    M doc/conf.py
    A doc/embed.py
    M doc/faq.rst
    A doc/images/poisson_edges.png
    A doc/images/poisson_points.png
    M doc/index.rst
    M doc/stages/filters.approximatecoplanar.rst
    M doc/stages/filters.assign.rst
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.cluster.rst
    M doc/stages/filters.colorinterp.rst
    M doc/stages/filters.colorization.rst
    M doc/stages/filters.computerange.rst
    M doc/stages/filters.cpd.rst
    M doc/stages/filters.crop.rst
    M doc/stages/filters.decimation.rst
    M doc/stages/filters.divider.rst
    M doc/stages/filters.eigenvalues.rst
    M doc/stages/filters.elm.rst
    M doc/stages/filters.estimaterank.rst
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.greedyprojection.rst
    M doc/stages/filters.gridprojection.rst
    M doc/stages/filters.groupby.rst
    M doc/stages/filters.hag.rst
    M doc/stages/filters.head.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/filters.icp.rst
    M doc/stages/filters.iqr.rst
    M doc/stages/filters.kdistance.rst
    M doc/stages/filters.locate.rst
    M doc/stages/filters.lof.rst
    M doc/stages/filters.mad.rst
    M doc/stages/filters.matlab.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mongus.rst
    M doc/stages/filters.mortonorder.rst
    M doc/stages/filters.movingleastsquares.rst
    M doc/stages/filters.normal.rst
    M doc/stages/filters.outlier.rst
    M doc/stages/filters.overlay.rst
    M doc/stages/filters.pclblock.rst
    M doc/stages/filters.pmf.rst
    M doc/stages/filters.poisson.rst
    M doc/stages/filters.python.rst
    M doc/stages/filters.radialdensity.rst
    M doc/stages/filters.randomize.rst
    M doc/stages/filters.range.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/filters.sample.rst
    M doc/stages/filters.smrf.rst
    M doc/stages/filters.sort.rst
    M doc/stages/filters.splitter.rst
    M doc/stages/filters.tail.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/filters.voxelcenternearestneighbor.rst
    M doc/stages/filters.voxelcentroidnearestneighbor.rst
    M doc/stages/filters.voxelgrid.rst
    M doc/stages/readers.bpf.rst
    M doc/stages/readers.buffer.rst
    M doc/stages/readers.faux.rst
    M doc/stages/readers.gdal.rst
    M doc/stages/readers.geowave.rst
    M doc/stages/readers.greyhound.rst
    M doc/stages/readers.ilvis2.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.matlab.rst
    M doc/stages/readers.mbio.rst
    M doc/stages/readers.mrsid.rst
    M doc/stages/readers.nitf.rst
    M doc/stages/readers.oci.rst
    M doc/stages/readers.optech.rst
    M doc/stages/readers.pcd.rst
    M doc/stages/readers.pgpointcloud.rst
    M doc/stages/readers.ply.rst
    M doc/stages/readers.pts.rst
    M doc/stages/readers.qfit.rst
    M doc/stages/readers.rxp.rst
    M doc/stages/readers.sbet.rst
    M doc/stages/readers.sqlite.rst
    M doc/stages/readers.text.rst
    M doc/stages/readers.tindex.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.gdal.rst
    M doc/stages/writers.geowave.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.matlab.rst
    M doc/stages/writers.nitf.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.oci.rst
    A doc/stages/writers.ogr.rst
    M doc/stages/writers.pcd.rst
    M doc/stages/writers.pgpointcloud.rst
    M doc/stages/writers.ply.rst
    M doc/stages/writers.sqlite.rst
    M doc/stages/writers.text.rst
    M doc/tutorial/las.rst
    A doc/workshop/capstone.rst
    A doc/workshop/conf.py
    A doc/workshop/exercises/python/histogram-command.txt
    A doc/workshop/exercises/python/histogram.json
    A doc/workshop/exercises/python/histogram.py
    A doc/workshop/exercises/python/histogram.rst
    A doc/workshop/exercises/translation/greyhound-command.txt
    A doc/workshop/exercises/translation/greyhound-info-command.txt
    A doc/workshop/exercises/translation/greyhound.json
    A doc/workshop/exercises/translation/greyhound.rst
    A doc/workshop/images/greyhound-command.png
    A doc/workshop/images/greyhound-info-verify.png
    A doc/workshop/images/greyhound-view.png
    A doc/workshop/images/python-histogram-command.png
    A doc/workshop/images/python-histogram.png
    M doc/workshop/index.rst
    A doc/workshop/notes.rst
    A doc/workshop/slides/source/img/osgeo4w-shell.png
    M filters/CropFilter.cpp
    M filters/CropFilter.hpp
    M filters/GreedyProjection.hpp
    M filters/NormalFilter.cpp
    M filters/NormalFilter.hpp
    M filters/private/DimRange.cpp
    A filters/private/Point.cpp
    A filters/private/Point.hpp
    R filters/private/crop/Point.cpp
    R filters/private/crop/Point.hpp
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/GDALReader.cpp
    M io/GDALReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/GeotiffSupport.cpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasUtils.cpp
    M io/LasUtils.hpp
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M io/LasWriter.cpp
    A io/OGRWriter.cpp
    A io/OGRWriter.hpp
    A io/OGRWriterV1.cpp
    M java/README.md
    M java/build.sbt
    A java/core-scala/src/main/scala/io/pdal/pipeline/ExprType.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/WriterTypes.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/json/package.scala
    A java/core-scala/src/main/scala/io/pdal/pipeline/package.scala
    A java/core-scala/src/test/scala/io/pdal/pipeline/PipelineExpressionsSpec.scala
    M java/project/Commands.scala
    A java/project/Dependencies.scala
    A java/project/Version.scala
    M java/project/build.properties
    M java/project/plugins.sbt
    M java/sbt
    M java/scripts/publish-212.sh
    M java/scripts/publish-javastyle.sh
    M java/scripts/publish-local-212.sh
    M java/scripts/publish-local.sh
    M java/scripts/publish.sh
    M pdal/DimUtil.hpp
    M pdal/EigenUtils.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/PDALUtils.cpp
    M pdal/PipelineManager.cpp
    R pdal/PipelineReaderXML.cpp
    M pdal/PointLayout.cpp
    M pdal/Stage.cpp
    M pdal/StageFactory.cpp
    R pdal/private/PipelineReaderXML.hpp
    M pdal/util/Utils.cpp
    M pdal_defines.h.in
    M plugins/CMakeLists.txt
    M plugins/cpd/filters/CpdFilter.cpp
    M plugins/matlab/CMakeLists.txt
    M plugins/matlab/filters/MatlabFilter.cpp
    M plugins/matlab/filters/MatlabFilter.hpp
    M plugins/matlab/filters/Script.cpp
    M plugins/matlab/filters/Script.hpp
    M plugins/matlab/io/MatlabReader.cpp
    M plugins/matlab/io/MatlabReader.hpp
    M plugins/matlab/io/MatlabWriter.cpp
    M plugins/matlab/io/MatlabWriter.hpp
    M plugins/matlab/test/MatlabReaderTest.cpp
    A plugins/openscenegraph/CMakeLists.txt
    A plugins/openscenegraph/io/OSGReader.cpp
    A plugins/openscenegraph/io/OSGReader.hpp
    M plugins/sqlite/io/SQLiteCommon.hpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M scripts/ci/script.sh
    M scripts/docker/dependencies/Dockerfile
    M test/data/gdal/grid.txt
    R test/data/hole/autzen-dd.las
    R test/data/hole/hole.dbf
    R test/data/hole/hole.las
    R test/data/hole/hole.prj
    R test/data/hole/hole.qpj
    R test/data/hole/hole.shp
    R test/data/hole/hole.shx
    R test/data/hole/make-spurious.py
    R test/data/hole/spurious.las
    A test/data/las/spurious.las
    M test/data/matlab/autzen.mat
    M test/data/pipeline/crop-hole.json.in
    A test/data/text/numeric_dim.txt
    R test/unit/apps/pcinfoTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
    M test/unit/filters/RangeFilterTest.cpp
    M test/unit/io/GDALWriterTest.cpp
    M test/unit/io/LasReaderTest.cpp
    M vendor/arbiter/CMakeLists.txt
    M vendor/kazhdan/PoissonRecon.h
  Log Message:
  Commit: eae1af53d49d60760530857d332215c3cb7fab78
      https://github.com/PDAL/PDAL/commit/eae1af53d49d60760530857d332215c3cb7fab78
  Date:   2017-09-12 (Tue, 12 Sep 2017)
  Changed paths:
    M cmake/laszip.cmake
    M cmake/modules/FindLASzip.cmake
    M io/LasReader.cpp
    M io/LasWriter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/laszip' into laszip
  Commit: 61d18b0413776887dce05726f91cfc9bc567b7d2
      https://github.com/PDAL/PDAL/commit/61d18b0413776887dce05726f91cfc9bc567b7d2
  Changed paths:
  Log Message:
  Add missing comma .
Compare: https://github.com/PDAL/PDAL/compare/da08a8c454fd...61d18b041377
More information about the pdal-commits mailing list
