[pdal-commits] [PDAL/PDAL] 366bd3: HDF Reader (#2934)
Ryan Pals noreply at github.com
Fri Feb 21 11:39:59 PST 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 366bd3b78249ad8734e6f245780f7c6a8aedb514
      https://github.com/PDAL/PDAL/commit/366bd3b78249ad8734e6f245780f7c6a8aedb514
  Author: Ryan Pals <ryan at hobu.co>
  Date:   2020-02-21 (Fri, 21 Feb 2020)
  Changed paths:
    M cmake/options.cmake
    A doc/stages/readers.hdf.rst
    M plugins/CMakeLists.txt
    A plugins/hdf/CMakeLists.txt
    A plugins/hdf/io/Hdf5Handler.cpp
    A plugins/hdf/io/Hdf5Handler.hpp
    A plugins/hdf/io/HdfReader.cpp
    A plugins/hdf/io/HdfReader.hpp
    A plugins/hdf/test/HdfReadertest.cpp
    M scripts/azp/linux-conda.yml
    M scripts/azp/linux.yml
    M scripts/azp/osx.yml
    M scripts/azp/win.yml
    M scripts/conda/osx.sh
    A test/data/hdf/autzen.h5
  Log Message:
  HDF Reader (#2934)
* Copy icebridge files over to hdf plugin
* WIP
Print out info from hard-coded autzen. remove test points in test file. iterate over dimensions and print size, offset, type and endianness
* Remove unused
* Compiles!
* Reads!
* Fix offset calculation
* Fix hard coded struct size
* Fix hard coded number of points
* Remove hard coded dataset name, add dataset selection from stage options
* Add case for non-compound datatypes
* Fix compound case
* Remove code for compound types
* Add ability to name dataset
* Cleanup
* Fix type bug
* Reads one chunk - wip
* WIP
* No longer segfaults - wip
* Reads an entire array
* Add JSON
* Read dataset and dims from JSON map
* WIP
* Remove unused
* Cleanup
* Fix key-value misordering
* Works for multiple dims
* Use proper loggers
* add simple readers.hdf test based on autzen
* Make chunkSize a property of dimension, rather than file
* Clean up loop
* Fix indexing bug
* Init buffers in prepare() instead of read()
* Streams!!!
* Fix sign-compare warning
* Add json validation
* Check that all datasets are the same length
* Update test data file with metadata
* Add HDF Reader docs WIP
* Add check for null map
* Add HDF plugin to AZP
* Connor's changes
* Stuff WIP
* Review changes
* Feedback
* Address feedback
* Add more test cases
* random chunk sizes, check GPSTime
* CMake feedback: Cleanup, remove LibXML2
* Get rid of compiler warnings
* Address doc feedback
* Cleanup
* Step 1
* Step 2
* Remove BufferInfo; return pointer to val instead of pointer to bufer
* Remove unused
* Get rid of m_buffers
* Style
* Get rid of all parallel vectors
* Don't open dataset on each point. Fixes 20x performance regression introduced by last commit
* Use range based for-loops
* Remove unused
* Move Handler class into hdf5 namespace
* Fix outdated error
* Sepearte initialization code into constructor
* Cleanup
* Make getValue a method of DimInfo instead of Handler
* Styling
* Remove unused
* Use fewer auto types
* Change shared_ptr to unique_ptr
* Fix macOS compiler warning
Co-authored-by: Howard Butler <howard at hobu.co>
More information about the pdal-commits mailing list
