[pdal-commits] [PDAL/PDAL] cdd18e: update to gtest 1.10.0
Howard Butler noreply at github.com
Fri Feb 21 12:27:21 PST 2020
  Branch: refs/heads/test-stack-trace
  Home:   https://github.com/PDAL/PDAL
  Commit: cdd18ec97b68835913a5696b2812cfbdf4c0c0d1
      https://github.com/PDAL/PDAL/commit/cdd18ec97b68835913a5696b2812cfbdf4c0c0d1
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-02-21 (Fri, 21 Feb 2020)
  Changed paths:
    M vendor/gtest/CMakeLists.txt
    M vendor/gtest/README.md
    M vendor/gtest/cmake/gtest.pc.in
    M vendor/gtest/cmake/gtest_main.pc.in
    M vendor/gtest/cmake/internal_utils.cmake
    M vendor/gtest/docs/Pkgconfig.md
    M vendor/gtest/docs/advanced.md
    M vendor/gtest/docs/faq.md
    M vendor/gtest/docs/primer.md
    M vendor/gtest/docs/samples.md
    M vendor/gtest/include/gtest/gtest-death-test.h
    A vendor/gtest/include/gtest/gtest-matchers.h
    M vendor/gtest/include/gtest/gtest-message.h
    M vendor/gtest/include/gtest/gtest-param-test.h
    M vendor/gtest/include/gtest/gtest-printers.h
    M vendor/gtest/include/gtest/gtest-spi.h
    M vendor/gtest/include/gtest/gtest-test-part.h
    M vendor/gtest/include/gtest/gtest-typed-test.h
    M vendor/gtest/include/gtest/gtest.h
    M vendor/gtest/include/gtest/gtest_pred_impl.h
    M vendor/gtest/include/gtest/internal/gtest-death-test-internal.h
    M vendor/gtest/include/gtest/internal/gtest-filepath.h
    M vendor/gtest/include/gtest/internal/gtest-internal.h
    M vendor/gtest/include/gtest/internal/gtest-param-util.h
    M vendor/gtest/include/gtest/internal/gtest-port-arch.h
    M vendor/gtest/include/gtest/internal/gtest-port.h
    M vendor/gtest/include/gtest/internal/gtest-string.h
    M vendor/gtest/include/gtest/internal/gtest-type-util.h
    M vendor/gtest/include/gtest/internal/gtest-type-util.h.pump
    M vendor/gtest/samples/prime_tables.h
    M vendor/gtest/samples/sample1.cc
    M vendor/gtest/samples/sample1.h
    M vendor/gtest/samples/sample10_unittest.cc
    M vendor/gtest/samples/sample2.cc
    M vendor/gtest/samples/sample2.h
    M vendor/gtest/samples/sample2_unittest.cc
    M vendor/gtest/samples/sample3-inl.h
    M vendor/gtest/samples/sample3_unittest.cc
    M vendor/gtest/samples/sample5_unittest.cc
    M vendor/gtest/samples/sample6_unittest.cc
    M vendor/gtest/samples/sample7_unittest.cc
    M vendor/gtest/samples/sample8_unittest.cc
    M vendor/gtest/samples/sample9_unittest.cc
    M vendor/gtest/src/gtest-all.cc
    M vendor/gtest/src/gtest-death-test.cc
    M vendor/gtest/src/gtest-filepath.cc
    M vendor/gtest/src/gtest-internal-inl.h
    A vendor/gtest/src/gtest-matchers.cc
    M vendor/gtest/src/gtest-port.cc
    M vendor/gtest/src/gtest-printers.cc
    M vendor/gtest/src/gtest-test-part.cc
    M vendor/gtest/src/gtest-typed-test.cc
    M vendor/gtest/src/gtest.cc
    M vendor/gtest/src/gtest_main.cc
    M vendor/gtest/test/BUILD.bazel
    M vendor/gtest/test/googletest-catch-exceptions-test.py
    M vendor/gtest/test/googletest-catch-exceptions-test_.cc
    M vendor/gtest/test/googletest-death-test-test.cc
    M vendor/gtest/test/googletest-death-test_ex_test.cc
    M vendor/gtest/test/googletest-env-var-test.py
    M vendor/gtest/test/googletest-filepath-test.cc
    M vendor/gtest/test/googletest-filter-unittest.py
    M vendor/gtest/test/googletest-filter-unittest_.cc
    M vendor/gtest/test/googletest-json-outfiles-test.py
    M vendor/gtest/test/googletest-json-output-unittest.py
    M vendor/gtest/test/googletest-list-tests-unittest_.cc
    M vendor/gtest/test/googletest-listener-test.cc
    M vendor/gtest/test/googletest-message-test.cc
    M vendor/gtest/test/googletest-options-test.cc
    M vendor/gtest/test/googletest-output-test-golden-lin.txt
    M vendor/gtest/test/googletest-output-test.py
    M vendor/gtest/test/googletest-output-test_.cc
    M vendor/gtest/test/googletest-param-test-invalid-name1-test_.cc
    M vendor/gtest/test/googletest-param-test-invalid-name2-test_.cc
    M vendor/gtest/test/googletest-param-test-test.cc
    M vendor/gtest/test/googletest-param-test-test.h
    M vendor/gtest/test/googletest-param-test2-test.cc
    M vendor/gtest/test/googletest-port-test.cc
    M vendor/gtest/test/googletest-printers-test.cc
    M vendor/gtest/test/googletest-shuffle-test_.cc
    M vendor/gtest/test/googletest-test-part-test.cc
    M vendor/gtest/test/googletest-test2_test.cc
    M vendor/gtest/test/googletest-throw-on-failure-test.py
    M vendor/gtest/test/googletest-throw-on-failure-test_.cc
    M vendor/gtest/test/googletest-uninitialized-test.py
    M vendor/gtest/test/gtest-typed-test2_test.cc
    M vendor/gtest/test/gtest-typed-test_test.cc
    M vendor/gtest/test/gtest-typed-test_test.h
    M vendor/gtest/test/gtest-unittest-api_test.cc
    M vendor/gtest/test/gtest_all_test.cc
    M vendor/gtest/test/gtest_assert_by_exception_test.cc
    M vendor/gtest/test/gtest_environment_test.cc
    M vendor/gtest/test/gtest_pred_impl_unittest.cc
    M vendor/gtest/test/gtest_premature_exit_test.cc
    M vendor/gtest/test/gtest_repeat_test.cc
    A vendor/gtest/test/gtest_skip_environment_check_output_test.py
    A vendor/gtest/test/gtest_skip_in_environment_setup_test.cc
    A vendor/gtest/test/gtest_skip_test.cc
    M vendor/gtest/test/gtest_stress_test.cc
    M vendor/gtest/test/gtest_test_utils.py
    M vendor/gtest/test/gtest_throw_on_failure_ex_test.cc
    M vendor/gtest/test/gtest_unittest.cc
    M vendor/gtest/test/gtest_xml_outfile1_test_.cc
    M vendor/gtest/test/gtest_xml_outfile2_test_.cc
    M vendor/gtest/test/gtest_xml_outfiles_test.py
    M vendor/gtest/test/gtest_xml_output_unittest.py
    M vendor/gtest/test/gtest_xml_output_unittest_.cc
    M vendor/gtest/test/gtest_xml_test_utils.py
  Log Message:
More information about the pdal-commits mailing list
