[pdal-commits] [PDAL/PDAL] c5a44c: Merge remote-tracking branch 'origin/master' into ...
Andrew Bell noreply at github.com
Mon May 17 09:17:14 PDT 2021
  Branch: refs/heads/lazperf
  Home:   https://github.com/PDAL/PDAL
  Commit: c5a44c93ebcaf315060b99b80aee189d4b6df62a
      https://github.com/PDAL/PDAL/commit/c5a44c93ebcaf315060b99b80aee189d4b6df62a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2021-05-17 (Mon, 17 May 2021)
  Changed paths:
    M .github/workflows/conda.yml
    M .github/workflows/docker.yml
    M CMakeLists.txt
    M cmake/draco.cmake
    M cmake/gdal.cmake
    M doc/apps/chamfer.rst
    A doc/apps/eval.rst
    M doc/apps/hausdorff.rst
    M doc/stages/filters.assign.rst
    M doc/stages/filters.cluster.rst
    M doc/stages/filters.icp.rst
    A doc/stages/filters.zsmooth.rst
    M doc/stages/readers.ept.rst
    M doc/stages/readers.las.rst
    M doc/stages/readers.mrsid.rst
    M doc/stages/writer_opts.rst
    M doc/stages/writers.draco.rst
    M doc/stages/writers.raster.rst
    M doc/tutorial/iowa.json
    M filters/CropFilter.cpp
    M filters/FarthestPointSamplingFilter.cpp
    M filters/GpsTimeConvert.cpp
    M filters/GpsTimeConvert.hpp
    M filters/HeadFilter.cpp
    M filters/StatsFilter.cpp
    A filters/ZsmoothFilter.cpp
    A filters/ZsmoothFilter.hpp
    M io/BpfWriter.cpp
    M io/EptReader.cpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasUtils.cpp
    M io/LasUtils.hpp
    M io/LasWriter.cpp
    M io/PcdReader.cpp
    M io/SbetReader.cpp
    M io/private/ept/EptInfo.cpp
    M io/private/ept/TileContents.cpp
    M io/private/ept/TileContents.hpp
    A kernels/EvalKernel.cpp
    A kernels/EvalKernel.hpp
    M kernels/HausdorffKernel.cpp
    M kernels/PipelineKernel.cpp
    M pdal/Filter.cpp
    M pdal/Filter.hpp
    M pdal/Geometry.cpp
    M pdal/Options.hpp
    M pdal/PDALUtils.cpp
    M pdal/PDALUtils.hpp
    M pdal/PipelineManager.cpp
    M pdal/PipelineManager.hpp
    M pdal/Reader.cpp
    M pdal/Reader.hpp
    M pdal/SpatialReference.cpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/Streamable.cpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
    M pdal/compression/DeflateCompression.cpp
    A pdal/compression/GzipCompression.hpp
    M pdal/private/SrsTransform.cpp
    M pdal/private/SrsTransform.hpp
    M pdal/private/StageRunner.cpp
    M pdal/private/gdal/ErrorHandler.cpp
    M pdal/private/gdal/ErrorHandler.hpp
    M pdal/private/gdal/GDALUtils.cpp
    M pdal/private/gdal/GDALUtils.hpp
    M pdal/util/CMakeLists.txt
    M pdal/util/FileUtils.cpp
    M pdal/util/FileUtils.hpp
    A pdal/util/Random.cpp
    A pdal/util/Random.hpp
    M pdal/util/ThreadPool.hpp
    M pdal/util/Utils.cpp
    M plugins/draco/CMakeLists.txt
    M plugins/i3s/CMakeLists.txt
    M plugins/i3s/io/SlpkReader.cpp
    M plugins/i3s/io/SlpkReader.hpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/teaser/filters/TeaserFilter.cpp
    M plugins/teaser/filters/TeaserFilter.hpp
    R plugins/teaser/filters/registration.h
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/test/TileDBReaderTest.cpp
    M plugins/tiledb/test/TileDBWriterTest.cpp
    M scripts/ci/conda/compile.sh
    M scripts/ci/conda/examples.sh
    M scripts/ci/conda/upload.sh
    M scripts/ci/linux/cmake.sh
    M scripts/ci/linux/setup.sh
    M scripts/ci/osx/cmake.sh
    M scripts/ci/osx/setup.sh
    M scripts/ci/win/cmake.sh
    M scripts/ci/win/setup.sh
    M scripts/conda/osx.sh
    M scripts/docker/ubuntu/Dockerfile
    A test/data/pipeline/filter-only.json.in
    M test/data/pipeline/issue2937.json.in
    A test/data/text/largescan.txt
    M test/unit/OptionsTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/Support.cpp
    M test/unit/Support.hpp
    M test/unit/UtilsTest.cpp
    M test/unit/WhereTest.cpp
    M test/unit/apps/AppPluginTest.cpp
    M test/unit/apps/AppTest.cpp
    M test/unit/apps/HausdorffTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
    M test/unit/io/LasReaderTest.cpp
    M test/unit/io/LasWriterTest.cpp
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into lazperf
  Commit: fdcfe2237e025cfb198697ebb3fbd2e55b6f229a
      https://github.com/PDAL/PDAL/commit/fdcfe2237e025cfb198697ebb3fbd2e55b6f229a
  Changed paths:
    M io/LasHeader.cpp
    M pdal/compression/LazPerfVlrCompression.cpp
  Log Message:
  Minor updates.
  Commit: fd19eea4f0e314957ee3a3af22f4d2780b2ff0d9
      https://github.com/PDAL/PDAL/commit/fd19eea4f0e314957ee3a3af22f4d2780b2ff0d9
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/lazperf' into lazperf
Compare: https://github.com/PDAL/PDAL/compare/d5e72b868dd7...fd19eea4f0e3
More information about the pdal-commits mailing list
