[pdal-commits] [PDAL/PDAL] 673dd0: set linux build pin to 3.0.4
Andrew Bell noreply at github.com
Mon May 17 10:16:16 PDT 2021
  Branch: refs/heads/issue-3438
  Home:   https://github.com/PDAL/PDAL
  Commit: 673dd087cba8cc51b163e346cf3a46dae5cd227e
      https://github.com/PDAL/PDAL/commit/673dd087cba8cc51b163e346cf3a46dae5cd227e
  Author: Howard Butler <howard at hobu.co>
  Date:   2021-04-26 (Mon, 26 Apr 2021)
  Changed paths:
    M scripts/ci/linux/setup.sh
  Log Message:
  Commit: 5b32116df389ad0a8b0910f31d4455dd618b6724
      https://github.com/PDAL/PDAL/commit/5b32116df389ad0a8b0910f31d4455dd618b6724
  Date:   2021-04-27 (Tue, 27 Apr 2021)
  Changed paths:
    M .github/workflows/docker.yml
  Log Message:
  we can't push docker packages if we are a PR
  Commit: 54f57495fd3fd6e3f8310661690202978b1b732e
      https://github.com/PDAL/PDAL/commit/54f57495fd3fd6e3f8310661690202978b1b732e
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2021-04-30 (Fri, 30 Apr 2021)
  Changed paths:
    M doc/stages/readers.las.rst
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
  Log Message:
  Add nosrs option to readers.las (#3442)
  Commit: 2213aba730a0e5ae738314bd1729b06b88d5738d
      https://github.com/PDAL/PDAL/commit/2213aba730a0e5ae738314bd1729b06b88d5738d
  Author: sujeongkim <kim.sujeong at gmail.com>
  Changed paths:
    M doc/stages/filters.icp.rst
  Log Message:
  Update filters.icp.rst (#3444)
  Commit: 1192f2f221fba4acfebf587a5041ffb7b4e389c4
      https://github.com/PDAL/PDAL/commit/1192f2f221fba4acfebf587a5041ffb7b4e389c4
  Changed paths:
    M pdal/SpatialReference.cpp
    M pdal/private/gdal/GDALUtils.cpp
    M pdal/private/gdal/GDALUtils.hpp
  Log Message:
  Remove GDAL 2.X support (#3440)
* Remove support for GDAL 2.X
* Remove debug.
* Remove some dead code.
  Commit: c4e925edc4ec697a6b0b10a9a0af2b3a12db25fc
      https://github.com/PDAL/PDAL/commit/c4e925edc4ec697a6b0b10a9a0af2b3a12db25fc
  Author: dsmith8fr <82899185+dsmith8fr at users.noreply.github.com>
  Date:   2021-05-06 (Thu, 06 May 2021)
  Changed paths:
    M io/PcdReader.cpp
  Log Message:
  Fix issue #3424 (#3425)
PCD Reader not seeking to correct location in Windows.
Files were opened as text not binary causing issues with seekg and
tellg methods. By setting the binanary argument to true when opening
the file, Utils::openFile(m_filename, true); this issue is resolved.
  Commit: 4dee0561d622ae113c1b1b421b7fca295b1a51a3
      https://github.com/PDAL/PDAL/commit/4dee0561d622ae113c1b1b421b7fca295b1a51a3
  Changed paths:
    M pdal/Stage.cpp
    M pdal/private/gdal/ErrorHandler.cpp
    M pdal/private/gdal/ErrorHandler.hpp
  Log Message:
  Reset error handler when logging stops. (#3436)
  Commit: 3c08cc44f3193b7a8ce5fa88ecfdc7f0e413ad5e
      https://github.com/PDAL/PDAL/commit/3c08cc44f3193b7a8ce5fa88ecfdc7f0e413ad5e
  Author: Connor Manning <connor at hobu.co>
  Changed paths:
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Forward query/headers properly during HEAD requests and fix a warning.  Closes #3291. (#3439)
  Commit: 26551d10fb8ef4e7a0facf6267d38a10aef16ae8
      https://github.com/PDAL/PDAL/commit/26551d10fb8ef4e7a0facf6267d38a10aef16ae8
  Changed paths:
    M doc/stages/readers.ept.rst
    M io/EptReader.cpp
    M io/private/ept/TileContents.cpp
    M pdal/util/ThreadPool.hpp
  Log Message:
  Improve performance of EPT stream mode (#3446)
* Remove debug.
* test
* Add nosrs option to readers.las
* Working EPT stream mode.
* update
* Cleanup.
* Update
* Add 'requests' as synonym for 'threads'.
  Commit: 99230c2904c42cae53455c6b5da44a406da05626
      https://github.com/PDAL/PDAL/commit/99230c2904c42cae53455c6b5da44a406da05626
  Date:   2021-05-10 (Mon, 10 May 2021)
  Changed paths:
    M doc/stages/filters.assign.rst
  Log Message:
  Update documentation about condition in filters.assign.
  Commit: b7e2ceabf0e47573ca9d1b387159f9ffdd102184
      https://github.com/PDAL/PDAL/commit/b7e2ceabf0e47573ca9d1b387159f9ffdd102184
  Changed paths:
    M io/EptReader.cpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/PcdReader.cpp
    M pdal/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 6c289930894bc71cf6a895b13b8249434a0a6fdf
      https://github.com/PDAL/PDAL/commit/6c289930894bc71cf6a895b13b8249434a0a6fdf
  Date:   2021-05-13 (Thu, 13 May 2021)
  Changed paths:
    M .github/workflows/conda.yml
    M scripts/ci/conda/compile.sh
    M scripts/ci/conda/examples.sh
    M scripts/ci/conda/upload.sh
    M scripts/ci/osx/setup.sh
    M scripts/ci/win/setup.sh
  Log Message:
  Fix CI for Conda (#3453)
* force
* lammly
* v1
* rename env var.
  Commit: bd636f8185fa295eeb66b78525407df983c09174
      https://github.com/PDAL/PDAL/commit/bd636f8185fa295eeb66b78525407df983c09174
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M filters/FarthestPointSamplingFilter.cpp
  Log Message:
  Return all points when a PointView does not have count points (#3454)
Fix #3447
  Commit: f008aa8ef0e522d8aa7d76afb1f423d7bb9738e1
      https://github.com/PDAL/PDAL/commit/f008aa8ef0e522d8aa7d76afb1f423d7bb9738e1
  Changed paths:
    M plugins/teaser/filters/TeaserFilter.cpp
    M plugins/teaser/filters/TeaserFilter.hpp
    R plugins/teaser/filters/registration.h
  Log Message:
  Fix teaser issue with make_unique (#3451)
  Commit: 3448207184a822789b5c481185a51608892cfaa0
      https://github.com/PDAL/PDAL/commit/3448207184a822789b5c481185a51608892cfaa0
  Changed paths:
    M filters/HeadFilter.cpp
  Log Message:
  Set index to zero within run() s.t. we can handle multiple PointViews correctly (#3449)
* Set index to zero within run() s.t. we can handle multiple PointViews
correctly
Fix #3448
* Add ready() back for streaming support
  Commit: b172d831b74b37c1dbdeaa5f805239a2cb36d83c
      https://github.com/PDAL/PDAL/commit/b172d831b74b37c1dbdeaa5f805239a2cb36d83c
  Author: Norman Barker <norman at tiledb.io>
  Date:   2021-05-14 (Fri, 14 May 2021)
  Changed paths:
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/test/TileDBReaderTest.cpp
    M plugins/tiledb/test/TileDBWriterTest.cpp
  Log Message:
  Add TileDB Hilbert configuration (#3445)
* Add TileDB Hilbert configuration
* Added test for setting TileDB tile sizes
* Fix tests for sfcurve with TileDB 1.7
Co-authored-by: normanb <norman at tiledb.com>
  Commit: 5b36ef3e7d1de1f9199f95787ea73dabe9c08b60
      https://github.com/PDAL/PDAL/commit/5b36ef3e7d1de1f9199f95787ea73dabe9c08b60
  Date:   2021-05-17 (Mon, 17 May 2021)
  Changed paths:
    M io/EptReader.cpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/PcdReader.cpp
    M pdal/Stage.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-3438
Compare: https://github.com/PDAL/PDAL/compare/dbd0d6e445cb...5b36ef3e7d1d
More information about the pdal-commits mailing list
