[pgrouting-dev] custom compile
Stephen Woodbridge woodbri at swoodbridge.com
Wed Dec 1 22:12:35 EST 2010
Daniel,
I'm not a cmake expert in fact I hardly know anything about it, but
looking at the file I would assume that if you want to redefine it in
cmake then you would replace the existing line with something like:
IF (NOT SQL_INSTALL_PATH)
   SET(SQL_INSTALL_PATH /usr/share/pgrouting)
ENDIF(NOT SQL_INSTALL_PATH)
And then when you run want to override it you do something like:
SQL_INSTALL_PATH=/opt/emap/pgrouting  cmake
or maybe
cmake SQL_INSTALL_PATH=/opt/emap/pgrouting
-Steve W
On 12/1/2010 9:36 PM, Daniel Kastl wrote:
> Hi,
> This is an interesting question.
> Actually (at least I) haven't thought about this yet.
> I know that at least SQL install path is defined in line 67 in the file:
> https://github.com/pgRouting/pgrouting/blob/v1.05/CMakeLists.txt#L67
> (I actually just changed it to /usr/share/pgrouting recently in the
> development branch, because "postlbs" was an idea in the beginning of
> pgRouting we won't follow anymore)
> I suppose that there should be a way to configure customs paths with
> CMAKE, but without reading more about it I don't know how. SQL path
> might be hard-coded though. If someone knows what could be done and
> knows better, please let me know.
> Daniel
> 2010/12/1 Emre Ersin <emree at mobiliz.com.tr <mailto:emree at mobiliz.com.tr>>
>     Hi,
>     I am trying to compile all the mapserver stuff in a custom directory
>     /opt/emap. Everything built fine except pgrouting.
>     How can I define postgresql, cgal, boost directories during cmake
>     process?
>     I was hoping that they were defined in CMakeLists.txt but it seems I
>     am missing something...
>     /opt/src/pgrouting-1.05# cmake
>     -DBoost_INCLUDE_DIR=/opt/src/boost_1_45_0 -DWITH_DD=ON
>     -DCGAL_INCLUDE_DIR=/opt/emap -DCGAL_LIBRARIES=/opt/emap
>     -DPOSTGRESQL_INCLUDE_DIR=/opt/emap -DPOSTGRESQL_LIBRARIES=/opt/emap
>     -DSQL_INSTALL_PATH=/opt/emap  .
>     -- The C compiler identification is GNU
>     -- The CXX compiler identification is GNU
>     -- Check for working C compiler: /usr/bin/gcc
>     -- Check for working C compiler: /usr/bin/gcc -- works
>     -- Detecting C compiler ABI info
>     -- Detecting C compiler ABI info - done
>     -- Check for working CXX compiler: /usr/bin/c++
>     -- Check for working CXX compiler: /usr/bin/c++ -- works
>     -- Detecting CXX compiler ABI info
>     -- Detecting CXX compiler ABI info - done
>     Boost headers were found here: /opt/src/boost_1_45_0
>     Output directory for libraries is set to /opt/emap/lib/postgresql
>     -- Found PGROUTING_CORE core: /opt/src/pgrouting-1.05/core/src
>     Installation directory for libraries is set to
>     /opt/emap/lib/postgresql and for SQL files is set to /usr/share/postlbs
>     -- Configuring done
>     WARNING: Target "routing_dd" requests linking to directory
>     "/opt/emap".  Targets may link only to libraries.  CMake is dropping
>     the item.
>     -- Generating done
>     -- Build files have been written to: /opt/src/pgrouting-1.05
>     Emre ERSİN
>     _______________________________________________
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
More information about the pgrouting-dev mailing list
