[pgrouting-dev] custom compile
Daniel Kastl daniel at georepublic.de
Wed Dec 1 22:16:37 EST 2010
Hi Steve,
Thank you! At least you're more programmer than I am. ;-)
Well, let's see if there is a way to clean up and simplify this
CMakeLists.txt file a bit.
I haven't studied Cmake yet either.
Any other objections or something to add to the wishlist from others?
Daniel
2010/12/2 Stephen Woodbridge <woodbri at swoodbridge.com>
> Daniel,
> I'm not a cmake expert in fact I hardly know anything about it, but looking
> at the file I would assume that if you want to redefine it in cmake then you
> would replace the existing line with something like:
> IF (NOT SQL_INSTALL_PATH)
>  SET(SQL_INSTALL_PATH /usr/share/pgrouting)
> ENDIF(NOT SQL_INSTALL_PATH)
> And then when you run want to override it you do something like:
> SQL_INSTALL_PATH=/opt/emap/pgrouting  cmake
> or maybe
> cmake SQL_INSTALL_PATH=/opt/emap/pgrouting
> -Steve W
> On 12/1/2010 9:36 PM, Daniel Kastl wrote:
>> Hi,
>> This is an interesting question.
>> Actually (at least I) haven't thought about this yet.
>> I know that at least SQL install path is defined in line 67 in the file:
>> https://github.com/pgRouting/pgrouting/blob/v1.05/CMakeLists.txt#L67
>> (I actually just changed it to /usr/share/pgrouting recently in the
>> development branch, because "postlbs" was an idea in the beginning of
>> pgRouting we won't follow anymore)
>> I suppose that there should be a way to configure customs paths with
>> CMAKE, but without reading more about it I don't know how. SQL path
>> might be hard-coded though. If someone knows what could be done and
>> knows better, please let me know.
>> Daniel
>> 2010/12/1 Emre Ersin <emree at mobiliz.com.tr <mailto:emree at mobiliz.com.tr>>
>>    Hi,
>>    I am trying to compile all the mapserver stuff in a custom directory
>>    /opt/emap. Everything built fine except pgrouting.
>>    How can I define postgresql, cgal, boost directories during cmake
>>    process?
>>    I was hoping that they were defined in CMakeLists.txt but it seems I
>>    am missing something...
>>    /opt/src/pgrouting-1.05# cmake
>>    -DBoost_INCLUDE_DIR=/opt/src/boost_1_45_0 -DWITH_DD=ON
>>    -DCGAL_INCLUDE_DIR=/opt/emap -DCGAL_LIBRARIES=/opt/emap
>>    -DPOSTGRESQL_INCLUDE_DIR=/opt/emap -DPOSTGRESQL_LIBRARIES=/opt/emap
>>    -DSQL_INSTALL_PATH=/opt/emap  .
>>    -- The C compiler identification is GNU
>>    -- The CXX compiler identification is GNU
>>    -- Check for working C compiler: /usr/bin/gcc
>>    -- Check for working C compiler: /usr/bin/gcc -- works
>>    -- Detecting C compiler ABI info
>>    -- Detecting C compiler ABI info - done
>>    -- Check for working CXX compiler: /usr/bin/c++
>>    -- Check for working CXX compiler: /usr/bin/c++ -- works
>>    -- Detecting CXX compiler ABI info
>>    -- Detecting CXX compiler ABI info - done
>>    Boost headers were found here: /opt/src/boost_1_45_0
>>    Output directory for libraries is set to /opt/emap/lib/postgresql
>>    -- Found PGROUTING_CORE core: /opt/src/pgrouting-1.05/core/src
>>    Installation directory for libraries is set to
>>    /opt/emap/lib/postgresql and for SQL files is set to /usr/share/postlbs
>>    -- Configuring done
>>    WARNING: Target "routing_dd" requests linking to directory
>>    "/opt/emap".  Targets may link only to libraries.  CMake is dropping
>>    the item.
>>    -- Generating done
>>    -- Build files have been written to: /opt/src/pgrouting-1.05
>>    Emre ERSİN
>>    _______________________________________________
>>    pgrouting-dev mailing list
>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>>    http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20101202/5a5013b7/attachment.html
More information about the pgrouting-dev mailing list
