[pgrouting-dev] Time dependent data and input format
Jay Mahadeokar jai.mahadeokar at gmail.com
Tue Aug 2 18:08:16 EDT 2011
On Sun, Jul 31, 2011 at 1:30 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 7/30/2011 2:44 PM, Jay Mahadeokar wrote:
>> On Sat, Jul 30, 2011 at 11:22 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>    Jay,
>>    After reading your report, I'm still struggling with the is_cyclic
>>    flag. I think the reason is because this seems to be a global flag
>>    and the fact is that some records might be cyclic and some might not
>>    be cyclic so the flag needs to be set at the record level not as a
>>    global. If we set the is_cyclic flag and have two time records on is
>>    cyclic and the other is not, how do we know which is which?
>>    tdsp expects a table of:
>>    gid, start_time, end_time, travel_time
>>    So how do I translate my example table:
>>       time_dependency
>>       rule_id:seq:day_of_week:start_ time:end_time:from_cost:to_
>>       cost:expiry_date
>>       1:1:2,3,4,5,6:0700:1000:30:-1:
>>       1:2:2,3,4,5,6:1600:1900:-1:30:
>>       1:3:1,7:0000:2400:45:45:
>>       2:1:0:1100:1130:20:20:20110729
>>    into this? Note: rule_id=1 is cyclic, rule_id=2 is not.
>>    For example lets say the route start 20110729 (friday) 6AM and ends
>>    20110801 (monday) 8PM. What would be the records we would need to
>>    return from the above table? For simplicity, lets assume rule_id is
>>    the gid.
>> Hi Steve,
>> The is_cyclic flag will be returned by the plsql query that generates
>> the time dependent data. This will be done according to the nature of
>> the data, start-time, end-time etc and the logic for that will be in the
>> plsql function.
>> The example you gave, for route start friday to monday, the plsql
>> function should return the data as not cyclic and give the specific time
>> intervals from start to end. I think this is
>> If query is from say monday to thursday, then the cyclic flag can be set
>> to true and data corresponding to the 24 hour interval only can  be
>> returned. If there is transition from weekday to weekend and vice versa
>> then data should be marked as not cyclic (which we discussed yesterday).
>> I am realising that this may not be the most optimal way, but I think
>> this optimisation is still just a luxury, since usually travel times
>> won't last more than a week in real world scenarios :).
>> On second thought, Lets see if we keep the is_cyclic flag with each time
>> interval as you are suggesting.
>> So, suppose the wrapper plsql is now returning -
>> gid, start_time, end_time, travel_time, is_cyclic
>> Now, if data is not cyclic from 11 to 11:30 on 20110729, then we will
>> have to take that for just one time and if it again cycles, we will have
>> to take alternate value for same time next week.
>> If some interval is not cyclic, I think it will be included only in the
>> first cycle, as per your example I am not sure if this property is
>> generic, but I think it might be.
>> The logic to check all this would have to be within the weight_map
>> class.  I can easily detail out algorithm for solving your example. But,
>> for each cyclic interval information like how many times it will repeat,
>> what will be the ordering etc should be provided to weight_map class.
>> Ex - intervals corresp to weekdays repeat 5 times, intervals corresp to
>> weekend repeat 2 times, while there is 1 non repeating interval.
>> These intricacies will be more if we imagine a more complex data
>> format.  Since all times are offset from start_time, all this
>> information will have to be delivered in some standard format which
>> should not be example specific.
>> I think these features need a detailed understanding and discussion. We
>> can surely continue to brainstorm over the issues. But I am not sure if
>> we can implement this within GSoc timeline. So, maybe we can put that in
>> TDSP Version 1.1?
> Jay,
> Ok, sounds like the optimization is a little premature but otherwise a good
> idea. I think that after GSoC, we need to look at time dependent handling
> and see if we can come up with something general that can be used for this
> code and for multimodal scheduling. It would be nice to have a general
> facility that any routing code that needs time dependent data can use and
> easily plug into. I think the best way to do this is to start with use cases
> for:
> 1. time dependent traffic data and events
> 2. mass transit bus, train, subway schedules
> 3. other specific use cases
> Then from these, abstract the table definitions that can hold this data in
> a format that is easy to enter, edit, and manage. Then look at how we
> transform that data into a form that a specific query needs to solve a given
> problem.
> And finally, we should be able to retrofit the existing code to use these
> facilities.
> Regards your project, I would leave things as is and move forward. In your
> final report you should have a discussion of things we learned and future
> directions that should identify the above as one of those.
Thanks for your suggestions. I agree with your view. So, I think I should
not tinker with the existing working algorithm. I will keep the tdsp
separate and create a new tdsp_cyclic which will be used in case of cyclic
data. I am working on that now using the existing ideas mentioned above. I
will soon come up with the documentation and example.
Our college has also started since last week and so, I am kind of occupied
there too. So, it will be best if we make the current implementation ready
with documentation until GSoc deadline and work on your ideas later.
> I'm open to other ideas or expanding on this if people have any additional
> thoughts.
> Thanks,
> -Steve
>     Also I just noticed that you assume the edges are not directed so
>>    the cost is the same traversing from A-B and B-A. Actually, that is
>>    probably not true, if gid is the directed edge and not the GIS edge
>>    which might get entered twice in a directed graph. This is another
>>    issue that the app developer needs to think about because GIS data
>>    has a single edge with attributes that then might generate two graph
>>    edges and then need to map time depend GIS edges back to graph
>>    edges. Oh what a tangles web we weave :)
>> Actually I assume that edges are directed.
>> https://github.com/pgRouting/**pgrouting/wiki/TDSP-Details<https://github.com/pgRouting/pgrouting/wiki/TDSP-Details>.
>> Refer section 3.
>>    -Steve
>>    On 7/29/2011 1:30 PM, Jay Mahadeokar wrote:
>>        On Fri, Jul 29, 2011 at 10:50 PM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge. com
>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>>            On 7/29/2011 1:03 PM, Jay Mahadeokar wrote:
>>                On Fri, Jul 29, 2011 at 9:54 PM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge. com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>
>>        <mailto:woodbri at swoodbridge <mailto:woodbri at swoodbridge>. com
>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>> wrote:
>>                    On 7/29/2011 11:49 AM, Jay Mahadeokar wrote:
>>                        Hi Steve,
>>                        On Fri, Jul 29, 2011 at 6:26 PM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge <mailto:woodbri at swoodbridge>>. com
>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>>
>> wrote:
>>                            Jay,
>>                            This make sense. What I'm trying to
>>        understand and
>>                get to is
>>                        how do
>>                            we make this easy to setup and use. It seems
>>        like we
>>                are missing
>>                            something somewhere. For example, the
>>        cyclical range
>>                of a single
>>                            entry can be different from other entries,
>> think
>>                week days
>>                        versus
>>                            weekends. It should be possible to have some
>>        cyclic
>>                entries
>>                        and some
>>                            not cyclic. Based on this it seems that the
>>        cyclic flag
>>                        needs to be
>>                            set on each record along with the period of the
>>                cycle. Would
>>                        you agree?
>>                        The main motivation behind all this brain
>>        storming is to
>>                keep
>>                        the core
>>                        algorithm and the postgres c function
>>        implementation,
>>                        independent of the
>>                        nature of data, right? So, we need to somehow
>>        abstract
>>                the data
>>                        dependent properties from the core functionality.
>>                        That was the reason why we came up with the plsql
>>                wrapper functions
>>                        idea. For optimising again, we need to
>>        communicate the
>>                cyclic
>>                        properties
>>                        to core algorithm, but the interface should be
>>                independent of
>>                        nature of
>>                        data.
>>                            If this is the case, then a quick scan of
>>        the data would
>>                        tell us if
>>                            there are cyclic entries, in which case a
>> simple
>>                function to
>>                        scan
>>                            the data needed and see if any entry is
>>        cyclic could
>>                return that
>>                            flag. But if every entry is marked as cyclic
>>        or not
>>                then you
>>                        might
>>                            not need that flag at all.
>>                        What I feel is: if we scan the data and keep the
>>        logic of
>>                        determining
>>                        the cyclic nature within the postgres C
>>        function, then
>>                the above aim
>>                        will somehow get lost and it will again become a
>>        data format
>>                        specific
>>                        function.
>>                        So, I think it will be better if the application
>>                developers deal
>>                        with
>>                        the data themselves so that they can achieve the
>>                optimisation.
>>                        Example -
>>                        for weekday, weekend, the plsql function will
>>        provide
>>                specific
>>                        values
>>                        for each day and mark data as non cyclic if there
>> is
>>                transition from
>>                        weekday to weekend and vice versa. (A journey
>>        more than
>>                few days is
>>                        highly unlikely, so anyways it wont repeat the
>>        data too
>>                much,
>>                        though it
>>                        will not be optimal)
>>                        If the journey is within weekday or within
>>        weekend, then
>>                we can mark
>>                        data as cyclic, and just retrieve 24 hour data.
>>                        This is specific to example data you specified. I
>>                believe such
>>                        improvisations will be applicable for most data
>>        formats.
>>                Thoughts?
>>                        Again, this is not the most optimal
>>        implementation, but
>>                still it
>>                        keeps
>>                        the core implementation independent of data
>>        format. Any
>>                other ideas?
>>                    Jay,
>>                    I think you are correct in this. This will require
>>        some real
>>                world
>>                    examples of data and how to work with it. The
>>        abstraction makes
>>                    sense but it is hard to map it to reality hence our
>>        discussions.
>>                    So if we propose a hypothetical example like:
>>                    1. roadway which it one way between 7-10am north
>>        bound on
>>                mon-fri
>>                    2. same roadway is one way between 4-7pm south bound
>>        on mon-fri
>>                    3. same roadway is two otherwise
>>                    A separate type of rule might be:
>>                    4. there was an accident at 11am causing reduced
>>        speeds for
>>                the next
>>                    30 mins
>>                    we could define a table like:
>>                    time_dependency
>>                    cost:expiry_date
>>                    I hope that is clear.
>>                    sun-sat === 1-7 for day_of_week
>>                    cost -1 means you can travel that direction
>>                    then in the edges table, you can link the edge to
>>                time_dependency
>>                    table via the rule_id
>>                    This is not perfect because, from_cost and to_cost
>>        imply a
>>                direction
>>                    of digitization of the segment which might be
>>        reversed on some
>>                    segments. You might have multiple rules associated
>>        with a single
>>                    segment. I'm thinking of a "rule" as a single
>>        description of
>>                some
>>                    conditions that might get reused by multiple edges
>>        in the
>>                graph. So
>>                    we might want a linking table like:
>>                    edge_id:rule_id
>>                    that will support multiple rules to be associated.
>>                    Then the stored procedure could be written to query
>>        these tables
>>                    based on start time, elapsed time from start, and
>>        edge_id
>>                that could
>>                    return the cost of a single edge. Or you would need
>>        to write a
>>                    stored procedure to transform these tables into
>> whatever
>>                structure
>>                    you need for the routing.
>>                Hi Steve,
>>                Thanks for coming up with the example. It fits well in
>>        order to
>>                describe
>>                our current plan. So, as proposed we will assume our
>>        data is in
>>                format
>>                (instead of creating ids and seq separately im keeping
>>        gid as the id
>>                like in ways table):
>>                gid: day_of_week: start_time: end_time: from_cost: to_cost:
>>                expiry_date
>>                Now, the application developer dealing with the data
>>        will write
>>                plsql
>>                function which will query the above table and return set
>>        of rows:
>>                gid, start_time, end_time, travel_time  as expected by
>>        the tdsp
>>                query.
>>                Now, if the data format is such that there are rules
>>        associated to
>>                specific edges, and there are linking tables etc as you
>>                mentioned, then
>>                it would be the responsibility of the application
>>        developer to
>>                come up
>>                with join queries etc that will be needed in the plsql
>>        wrapper
>>                function.
>>                We will just expect data in the above format. And we can
>>        also
>>                keep track
>>                of cyclic nature as discussed earlier.  There can be
>>        many other
>>                formats
>>                and many other linking table possibilities, but we
>>        should not be
>>                responsible for those. That was the reason of deciding
>>        the input
>>                data
>>                format during the pre-coding period.
>>                I hope I am understanding your point and answering
>>        relevantly.
>>                  Thanks
>>                again for coming up with the users perspective. This is
>>        really
>>                helping
>>                me to understand the real-world scenario which I had not
>>        thought
>>                about
>>                particularly. Any other comments?
>>            I think you have it now and I understand it also. The
>>        application
>>            developer can have whatever structure they need to represent
>> the
>>            data they have and link it to the edges, and then they have
>>        to write
>>            a procedure that will transform that into the record set you
>>        defined
>>            above that the engine needs.
>>            In the documentation, you can copy my example and/or
>>        simplify it a
>>            little. It is fine to discuss points that they need to
>>        consider like
>>            direction of digitization or how to handle transient one way
>>            streets, because these are things that people might need to
>> deal
>>            with and it gives them an idea of how to deal with other data
>>            problems that they might be confronted with.
>>        Sure! I will do that in last two weeks I think. If you can list
>> such
>>        points that we should document, I can come up with details of
>>        mapping
>>        each scenario to the required format.
>>            It would be nice if we could get some real time dependent
>>        data and
>>            work through building a sample application the uses it. Maybe
>> we
>>            will have time after GSoC to do that.
>>        I have been trying to get real world time dependent data since a
>>        long
>>        time now. Still I have not found a good data source. It would be
>>        great
>>        if we can acquire that, and yes, we can do that after GSoc too!
>>            Thanks,
>>              -Steve
>>                    I just trying to put this into a concrete example so
>>        we can work
>>                    through how this works and to help understand how we
>>        need to
>>                    document it so people can use it in a real world
>>        example.
>>                    Thoughts?
>>                    -Steve
>>                            May be I'm missing something because I have
>>        not had
>>                a full
>>                        cup of
>>                            tea yet :)
>>                            Thoughts,
>>                              -Steve
>>                            On 7/29/2011 8:39 AM, Jay Mahadeokar wrote:
>>                                On Fri, Jul 29, 2011 at 5:50 PM, Stephen
>>        Woodbridge
>>        <mailto:woodbri at swoodbridge <mailto:woodbri at swoodbridge>>>**. com
>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>>>
>> wrote:
>>                                    On 7/29/2011 5:49 AM, Jay Mahadeokar
>>        wrote:
>>                                        Hi all,
>>                                        I was looking at ways to
>>        optimise the tdsp
>>                        implementation.
>>                                        Currently, if the time-interval is
>>                suppose 24, (24
>>                                hours) and
>>                                        the travel
>>                                        time expected is around 60
>>        hours, then the
>>                        tdsp-wrapper
>>                                query
>>                                        retrieves
>>                                        total 60 intervals and the data is
>>                repeated for
>>                        the 24 hour
>>                                        intervals.
>>                                        (I hope what i am trying to say
>>        is clear).
>>                                        This is unnecessary space
>>        wastage. So, I
>>                edited the
>>                                weight_map
>>                                        class to
>>                                        accommodate a variables
>>        is_cyclic and the
>>                                cycle_interval, which will
>>                                        keep track of the cyclic nature
>>        of the
>>                data. So,
>>                                actually only
>>                                        the 24
>>                                        hour data will be fed to weight
>>        map and
>>                then it
>>                        will be
>>                                reused
>>                                        in cycles.
>>                                        Because of the good design, I
>>        guess this has
>>                        scaled up
>>                                really
>>                                        nice and
>>                                        there is no need to modify
>>        actual core tdsp.
>>                        Just the
>>                                weight_map's
>>                                        get_travel_time() function and the
>>                wrapper plsql
>>                                function needed
>>                                        to be
>>                                        altered.
>>                                    This makes perfect sense and sounds
>>        like a great
>>                        optimization.
>>                                        Now, in the main query, I am
>>        thinking of
>>                adding
>>                        one more
>>                                boolean
>>                                        variable - is_cyclic which will be
>>                enabled if
>>                        the data
>>                                is cyclic in
>>                                        nature.  Should we keep this? Or
>>        we should
>>                        assume that
>>                                the data
>>                                        will be
>>                                        always cyclic.
>>                                        Any other views on the same are
>>        welcome.
>>                                    I guess my questions are:
>>                                    How does this get set?
>>                                    What are the advantages of setting it?
>>                                    Is there a way to dynamically check
>>        if it is
>>                cyclic
>>                        at the
>>                                start and
>>                                    avoid having the app builder set it up?
>>                                Advantages of setting it:
>>                                If the data is not cyclic, then the
>>        whole data
>>                will be
>>                        expected to
>>                                reside in database itself. So, if the upper
>>                bound of the
>>                        time is
>>                                reached
>>                                then by default, we can assume that the
>>        travel_time
>>                                last existing time window should be used
>> for
>>                such cases.
>>                                If data is cyclic, then we need to start
>> all
>>                over again.
>>                          These
>>                                are the
>>                                cases, what I could think of.
>>                                How does this get set:
>>                                The tdsp query must have an additional
>>        parameter -
>>                        is_cyclic which
>>                                should be used to set the is_cyclic flag
>>        of the
>>                weight_map.
>>                                Now, if data is cyclic, then the plsql
>>        function that
>>                        retrieves
>>                                the data
>>                                should be written in such a way that if
>>        interval is
>>                        suppose 0 -
>>                                24, and
>>                                start time is 21, then  21->0 and
>>        20->23. After
>>                that the
>>                        cyclic flag
>>                                will indicate us to loop again.  The plsql
>>                function will be
>>                                generally
>>                                written by app developer and he should
>>        take care of
>>                        this. (I have
>>                                already implemented this in my code.)
>>                                If data is cyclic, he should pass the flag
>>                appropriately. If
>>                                is_cyclic
>>                                is false, we can assume that if
>>        intervals are
>>                exhausted,
>>                        we will
>>                                keep
>>                                using time corresponding to last interval.
>>                                Is this reasonable?
>>                                    I suppose it is not a big deal for
>>        the app
>>                builder
>>                        to set
>>                                this flag
>>                                    since he will know if the data loaded
>> is
>>                cyclic in
>>                        nature. I
>>                                assume
>>                                    you are only looking for some
>>        indication if
>>                there
>>                        are cyclic
>>                                entries
>>                                    in the data and not if this specific
>>        query
>>                has a cyclic
>>                                nature which
>>                                    would be impossible to know without
>>                analyzing the
>>                        start time
>>                                and max
>>                                    time window, in which case we should
>>        figure
>>                that out
>>                                automatically
>>                                    because the user making the request
>>        is not
>>                likely to
>>                        know
>>                                anything
>>                                    more than start, end and start time
>>        or end time.
>>                                    -Steve
>>                                Regards,
>>                                -Jay Mahadeokar
>>            ______________________________ _________________
>>            pgrouting-dev mailing list
>>        pgrouting-dev at lists.osgeo.org
>>        <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>        <mailto:pgrouting-dev at lists. osgeo.org
>>        http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>        <http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>        <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>        Regards,
>>        -Jay Mahadeokar
>>        pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> Regards,
>> -Jay Mahadeokar
>> ______________________________**_________________
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110803/81c4d324/attachment-0001.html
More information about the pgrouting-dev mailing list
