[pgrouting-dev] Cannot create topology
Stephanos Charalambous stephanos_ch at yahoo.gr
Fri Feb 18 03:32:45 EST 2011
Thank you Sirs.
I tried the thinks that you have told me.
1. As Daniel suggested, I ran the command: psql gis "C:\Users\User\Desktop\900913.sql" in the psql shell and when I checked the file "spatial_ref_sys.sql", the entry 900913 is in the table.
2. As Stephen suggested, I edited the epsg file in the "proj" folder and added the Spherical Mercator projection entry.
3. I changed the assign_vertex_id command to:
   SELECT assign_vertex_id('testNic', 1.0, 'the_geom', 'gid')
4. Restart Computer
THE RESULT: The same error occurs.
Where did I do wrong?
Thanks,
Stephanos
--- Στις Πέμ., 17/02/11, ο/η Stephen Woodbridge <woodbri at swoodbridge.com> έγραψε:
> Από: Stephen Woodbridge <woodbri at swoodbridge.com>
> Θέμα: Re: [pgrouting-dev] Cannot create topology
> Προς: pgrouting-dev at lists.osgeo.org
> Ημερομηνία: Πέμπτη, 17 Φεβρουάριος 2011, 20:27
> You might also need to add it to:
> /usr/share/proj/epsg
> # Spherical Mercator projection
> <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> +lon_0=0.0
> +x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null
> +no_defs  <>
> Also, when you ran assign_vetrix_id() your tolerance was
> something like
> 0.000001 which is appropriate if your data is in degrees,
> but this
> Mercator projection is in meters so your tolerance should
> be something
> in a range like 5.0 - 0.5, maybe start with 1.0 and see how
> that works.
> if you rebuild you table and try different values for
> tolerance, you can
> look at the number of unique node numbers. When the number
> suddenly gets
> smaller you probably have it too large.
> -Steve
> On 2/17/2011 1:14 PM, Daniel Kastl wrote:
> > I think SRID = 900913 is not in the spatial_ref_sys
> table, if you're
> > using an older version of PostGIS.
> > You can take it from here:
> > http://trac.openstreetmap.org/browser/applications/utils/export/osm2pgsql/900913.sql
> > <http://trac.openstreetmap.org/browser/applications/utils/export/osm2pgsql/900913.sql>Daniel
> > 2011/2/18 Stephanos Charalambous <stephanos_ch at yahoo.gr
> > <mailto:stephanos_ch at yahoo.gr>>
> >     Thanks Daniel for the quick
> response.
> >     The shapefile which i imported
> was in google web mercator, so during
> >     the import I set the SRID =
> 900913. The geom constraint has the same
> >     value too.
> >     How can I do the necessary
> checks?
> >     With Regards,
> >     On 17 Φεβ 2011, at 16:58,
> Daniel Kastl <daniel at georepublic.de
> >     <mailto:daniel at georepublic.de>>
> wrote:
> >>     Hello Stephanos,
> >>     As the error says, there
> seems to be something wrong with your
> >>     SRID. You should check if
> the constraint on "the_geom" and the
> >>     entry in the
> "geometry_columns" table are OK? Does it have an SRID
> >>     or is it set -1?
> >>     Daniel
> >>     2011/2/17 Stephanos
> Charalambous
> >>     <<mailto:stephanos_ch at yahoo.gr>stephanos_ch at yahoo.gr
> >>         Hello,
> >>         I am kind of
> new in using pgrouting and I would really like
> >>         your help.
> >>         I have
> imported a road network, called "testNic" (from
> >>         shapefile)
> into a PostgreSQL database using QGIS and pgAdmin.
> >>         Then, I
> added the necessary columns, source, target and cost,
> >>         and created
> the geom_idx. The problem that I am facing is that
> >>         I cannot
> create the topology using the query:
> >>         SELECT
> assign_vertex_id('testNic', 0.00001, 'the_geom', 'gid');
> >>         I get the
> following error, and i can't locate where the
> >>         mistake is.
>    NOTICE:  CREATE TABLE will create
> implicit sequence
>    "vertices_tmp_id_seq" for serial column
> "vertices_tmp.id
> >>         <http://vertices_tmp.id>"
>    CONTEXT:  SQL statement "CREATE TABLE
> vertices_tmp (id serial)"
> >>         PL/pgSQL
> function "assign_vertex_id" line 14 at EXECUTE statement
> >>         ERROR:
> find_srid() - couldnt find the corresponding SRID - is
> >>         the geometry
> registered in the GEOMETRY_COLUMNS table?  Is
> >>         there an
> uppercase/lowercase missmatch?
>    CONTEXT:  PL/pgSQL function
> "assign_vertex_id" line 20 at
> >>         assignment
> Error **********
> >>         ERROR:
> >>         the geometry
> >>         there an
> >>         SQL state:
> P0001
> >>         Context:
> PL/pgSQL function "assign_vertex_id" line 20 at
> >>         assignment
> >>         Any help
> would be really appreciated.
> >>         Regards
> >>         Stephanos
> Charalambous
>    _______________________________________________
>    pgrouting-dev mailing list
>    <mailto:pgrouting-dev at lists.osgeo.org>pgrouting-dev at lists.osgeo.org
> >>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> >>     Georepublic UG &
> Georepublic Japan
> >>     eMail:
> >>     <mailto:daniel.kastl at georepublic.de>daniel.kastl at georepublic.de
> >>     Web: <http://georepublic.de/>http://georepublic.de
> list
> > Georepublic UG & Georepublic Japan
> > eMail: daniel.kastl at georepublic.de
> > Web: http://georepublic.de <http://georepublic.de/>
More information about the pgrouting-dev mailing list
