[pgrouting-dev] Support for Time Constraints
Jay Mahadeokar jai.mahadeokar at gmail.com
Sun Jun 12 14:59:03 EDT 2011
On Sun, Jun 12, 2011 at 8:00 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Jay,
> Try:
> select class_id, count(*) as cnt from ways group by class_id oder by
> classid;
> Typically you should a a distribution in real world data something like:
> 5% limited access major highways
> 15% major roads
> 75% minor roads
> 5% trails, pedestrian ways, etc
> Well in the US anyway. Also if this is OSM data then you might get a better
> clue on classes by looking to that .... OH!, look what I found in google :)
> http://workshop.pgrouting.org/chapters/advanced.html
Hi Steve,
Thanks for giving me the link. I somehow never tried doing advanced part of
the workshop.
Well, it is using routing database which we generate during this step:
http://workshop.pgrouting.org/chapters/osm2pgrouting.html
I am doing exact steps outlined there but unfortunately, after I run
osmtopgrouting command,  get following output:
<lots of mesages regarding different class name, and ids>
class name = roundabout
class id = 401
class id = 401 name = roundabout added to type name=junction
Trying to load data
Trying to parse data
I find only the following 3 tables generated in routing database:
               List of relations
 Schema |       Name        | Type  |  Owner
 public | geography_columns | view  | postgres
 public | geometry_columns  | table | postgres
 public | spatial_ref_sys   | table | postgres
(3 rows)
The tutorial says a total of 8 tables should be generated.
I do not get any other warning or error messages.
On other hand, I am able to do all steps here:
http://workshop.pgrouting.org/chapters/topology.html correctly, and hence
till now I was working with pgrouting-workshop database.
I am sorry if this are very silly errors, but I have no previous experience
working with such data. Any hint/link why I am not able to generate routing
database?
> Looks like first digit is type and the three digits are from the classes
> table.
> -Steve
> On 6/12/2011 4:33 AM, Jay Mahadeokar wrote:
>> On Sun, Jun 12, 2011 at 1:32 PM, Anton Patrushev
>> <anton.patrushev at georepublic.de <mailto:anton.patrushev at georepublic.de>>
>> wrote:
>>    Hi Jay,
>>    No, there was no specific meaning, just king of cyphering - first
>>    digit for road class and then two last digits for road type.
>> Hi Anton,
>> So, as you said last 2 digits are for road type. I can see they are
>> mainly 00, 01, 02, 06, 08, 09, 10, 11, 12 ,14, 17.
>> Road class is just 1 or 4.
>> Can I differentiate major highways, minor highways, streets etc using
>> this info?
>>    Anton.
>>    On 6/12/11, Jay Mahadeokar <jai.mahadeokar at gmail.com
>>    <mailto:jai.mahadeokar at gmail.com>> wrote:
>>     >> Hi Jay,
>>     >> I think that instead of just random times, I would take a different
>>     >> approach to generate this data. If we think about "rush hour"
>>    around a
>>     >> major
>>     >> city, the highways (based on road class) flowing into the city
>>    in the
>>     >> morning would get reduced average speeds you could apply curve like
>>     >> average
>>     >> speed*percent based on 6am (90%), 7am(75%), 8am(45%), 9am(50%),
>>    10am(85%)
>>     >> and do something similar in the evening rush. It might be too
>>    hard to
>>     >> figure
>>     >> on direction of flow in/out bound so apply the curve to all
>>    traffic. The
>>     >> assumption is that the highways are congested which will force
>>    traffic
>>     >> onto
>>     >> side streets. You might want to also reduce the lower class
>>    speeds by say
>>     >> a
>>     >> constant 80% during rush hour.
>>     >> If we can get OSM data then it should be easy to populate the
>>    table with
>>     >> that data.
>>     >> -Steve
>>     > I am trying to write plpgsql query to generate time-dependent data
>>     > corresponding to the ways table in pgrouting workshop. As
>>    suggested by Steve
>>     > above, instead of generating random data, I will follow patterns
>>    (see above
>>     > message) so that the data is nearer to the real worlds scenario.
>>     > So, now I need to make distinction between highways, streets etc.
>>    I saw the
>>     > attribute class_id in ways table. It has 14 distinct values:
>>     >  class_id
>>     > 102
>>     > 122
>>     > 106
>>     > 111
>>     > 108
>>     > 100
>>     > 109
>>     > 112
>>     > 101
>>     > 110
>>     > 401
>>     > 119
>>     > 117
>>     >       114
>>     > Any specific meaning attached to these values? I did not find any
>>     > information on the pgRouting-workshop website [1].
>>     > Thanks in advance.
>>     > [1] http://workshop.pgrouting.org/chapters/topology.html
>>     > Regards,
>>     > -Jay Mahadeokar
>>    Georepublic UG (haftungsbeschränkt)
>>    Salzmannstraße 44,
>>    81739 München, Germany
>>    Anton Patrushev
>>    CTO
>>    eMail: anton.patrushev at georepublic.de
>>    Web: http://georepublic.de
>>    Tel: +49 (089) 420 959 519
>>    Sip: 1959519 at sipgate.de <mailto:1959519 at sipgate.de>
>>    Commercial register: Amtsgericht München, HRB 181428
>>    CEO: Daniel Kastl
>>    _______________________________________________
>>    pgrouting-dev mailing list
>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>>    http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Regards,
>> -Jay Mahadeokar
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110613/d7bb7c56/attachment-0001.html
More information about the pgrouting-dev mailing list
