R: Re: [pgrouting-dev] pgRouting render
Daniele Russo danielerusso19 at libero.it
Wed Jun 22 12:58:16 EDT 2011
My application is a desktop application, and I work on Fedora 14. How your web application works?
Thanks,
regards.
DR
Il giorno 22/giu/2011, alle ore 17.51, Stephen Woodbridge ha scritto:
> On 6/21/2011 10:32 AM, danielerusso19 at libero.it wrote:
>> Thanks for the answer.
>> Actually I'm using QuantumGIS, but I'd like to use an engine like Navit.
> Probably need to ask this on the QuantumGIS and/or Navit list.
> In general, your question is given a polyline, how do I display that in XXXXX?
> pgRouting computes the route and gives you a polyline, the rest is up to you to feed it into rendering package. Your rendering package will depend on what you application development platform is, like Web 2.0 or desktop application, iPhone or Android application, etc. each of these will have different answers and constraints.
> You can look a web application that I built here:
>   http://tinyurl.com/3rhn4nx
> This has a lot of custom code added to pgRouting but pgRouting is being used to compute underlying route.
> Hope this helps,
>  -Steve
>> Is this possible?
>> Thanks,
>> best regards.
>> DR
>> ----Messaggio originale----
>> Da: daniel at georepublic.de
>> Data: 21/06/2011 16.17
>> A: "danielerusso19 at libero.it"<danielerusso19 at libero.it>, "pgRouting developers
>> mailing list"<pgrouting-dev at lists.osgeo.org>
>> Ogg: Re: [pgrouting-dev] pgRouting render
>> 2011/6/21 danielerusso19 at libero.it<danielerusso19 at libero.it>
>> Hi all!
>> I would like to render my route (planned with pgRouting) in a graphical way
>> (2D or 3D, is the same).
>> Is this possible? In which way?
>> There are plenty ways to do so, but in the same manner as you would render
>> data in a PostgreSQL/PostGIS database, for example:Mapserver/GeoservergvSIG,
>> QGISOpenLayers (see the workshop)Best regards,Daniel
>> Thanks to all,
>> regards.
>> DR
>> pgrouting-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
