R: Re: [pgrouting-dev] pgRouting render
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jun 22 16:32:30 EDT 2011
On 6/22/2011 12:58 PM, Daniele Russo wrote:
> My application is a desktop application, and I work on Fedora 14. How
> your web application works?
So as a desktop application you have to decide if you want to build the
UI based on a browser application using something like I did or if you
want to code it in C/C++ or some other toolkit based language.
I will describe my web application, but for another direction you need
to ask how to do generic things for whatever toolkit you are using.
Browser
   o OpenLayers
      o mapserver
         o render base map
         o render vectors from routing DB
      o ajax (PHP) to get route results
         o make route request
         o PHP gets request queries pgRouting
         o PHP formats results as XML back to OpenLayers
      o javaScript parse XML create route feature and populates directions
pgRouting does not currently do the driving directions. This is custom
code that I wrote for this application. I have explained how to do this
on the list so check the archives. You can look at the demo web page to
see how I glued OpenLayers and the Ajax requests together and in FireBug
you can view the XML streams of the Ajax request.
-Steve
> Thanks, regards.
> DR
> Il giorno 22/giu/2011, alle ore 17.51, Stephen Woodbridge ha
> scritto:
>> On 6/21/2011 10:32 AM, danielerusso19 at libero.it wrote:
>>> Thanks for the answer. Actually I'm using QuantumGIS, but I'd
>>> like to use an engine like Navit.
>> Probably need to ask this on the QuantumGIS and/or Navit list. In
>> general, your question is given a polyline, how do I display that
>> in XXXXX?
>> pgRouting computes the route and gives you a polyline, the rest is
>> up to you to feed it into rendering package. Your rendering package
>> will depend on what you application development platform is, like
>> Web 2.0 or desktop application, iPhone or Android application, etc.
>> each of these will have different answers and constraints.
>> You can look a web application that I built here:
>> http://tinyurl.com/3rhn4nx
>> This has a lot of custom code added to pgRouting but pgRouting is
>> being used to compute underlying route.
>> Hope this helps, -Steve
>>> Is this possible?
>>> Thanks, best regards.
>>> DR
>>> ----Messaggio originale---- Da: daniel at georepublic.de Data:
>>> 21/06/2011 16.17 A:
>>> "danielerusso19 at libero.it"<danielerusso19 at libero.it>, "pgRouting
>>> developers mailing list"<pgrouting-dev at lists.osgeo.org> Ogg: Re:
>>> 2011/6/21 danielerusso19 at libero.it<danielerusso19 at libero.it> Hi
>>> all!
>>> I would like to render my route (planned with pgRouting) in a
>>> graphical way (2D or 3D, is the same). Is this possible? In which
>>> way?
>>> There are plenty ways to do so, but in the same manner as you
>>> would render data in a PostgreSQL/PostGIS database, for
>>> example:Mapserver/GeoservergvSIG, QGISOpenLayers (see the
>>> workshop)Best regards,Daniel Thanks to all, regards.
>>> DR _______________________________________________ pgrouting-dev
>>> mailing list pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> _______________________________________________ pgrouting-dev mailing
More information about the pgrouting-dev mailing list
