[pgrouting-dev] Returning the correct edge id from boost_dijkstra_* functions
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jun 30 12:42:51 EDT 2011
Anton, Daniel,
I have been fighting with the dijkstra results because we do not return
things like the parent id of a path and we definitely do not return the
correct edge ids.
So with some help from the boost users list and banging my head against
the C++ wall, being only a C programmer :), I have some code that works
for me.
http://pastebin.com/qa1caiXs
In dijkstra.h I also have defined the following structs:
typedef struct edge
     int id;
     int source;
     int target;
     float8 cost;
     float8 rcost;
} edge_t;
typedef struct path_element
     int vertex_id;
     int parent_id;
     int edge_id;
     float8 cost;
} path_element_t;
You should be able to copy the appropriate parts of this file and update
the driving distance code and the low level dijkstra code to return more
correct and useful results. I'm using this code outside of the
postgresql server, but it should not require any significant changes.
Since I'm not developing code in the database, I will leave that as an
exercise for you guys to work out and test.
Thanks,
   -Steve
More information about the pgrouting-dev mailing list
