[pgrouting-dev] Introducing myself
Stephen Woodbridge woodbri at swoodbridge.com
Sun Apr 22 14:01:53 EDT 2012
Hi Razequl,
I have a few of comments in no particular order:
* We have a GSoC student that has proposed a project  to do a
Bi-directional routing algorithm and we should know by tomorrow if that
was accepted or not. That said, while if it is accepted then having two
is a little redundant unless one supports turn restrictions like TRSP
and one does not.
* Boost as the advantage that is a generic library that is well tested
and most of the development is about how to use the library to do what
you want. On the other hand it is more restrictive if you want to do
something similar to Boost but not supported in the existing code. You
might be able to reuse some of the TRSP code which would be good if you
can do that.
* Testing - I think you need to consider making some simple unit test
examples that allow you to validate your code. This would be a
collection of tests that you can apply to a relatively simple network
that is easy to debug and trace the execution. Once this is done and
working it is reasonable to throw a larger network like osm2pgrouting to
look at performance tuning.
* One of the keys to making quality releases is our ability to automate
sanity testing of the code before we release it. While we do not have
any automated testing yet, it is very high on my list of things that
need to get done, so I will be pushing everyone to support this.
As Jay said, if you have any specific questions that we can help with,
please ask on the list.
Best regards,
   -Steve
On 4/22/2012 1:00 PM, Razequl Islam wrote:
> Hi Jay,
> Thanks for your reply and suggestion. I have already gone through the
> source of basic dijkstra, A* and the new variant trsp (turn restricted
> shortest path) as suggested by Steve. I found that dijkstra and A* has
> been implemented using the boost library while trsp has its own
> structure and implementation. It also uses STL for priority queue. I am
> thinking of implementing like trsp using my own data structure.
> I am still playing with these. I need some sample database, I am trying
> to install osm2pgrouting but struggling.
> Thanks for your help once again.
> Razequl
> On Sat, Apr 21, 2012 at 12:34 AM, Jay Mahadeokar
> <jai.mahadeokar at gmail.com <mailto:jai.mahadeokar at gmail.com>> wrote:
>     Hi Razequl,
>     Welcome to pgRouting. Good implementation of Bi-directional
>     searching algorithm will be a very useful addition to pgRouting. I
>     would suggest you to:
>     - See the pgRouting source.
>     - Study typical pgRouting algorithm implementation link
>     shortest_path, play around with it, compile and debug etc. You will
>     need to use cmake and other tools for the same.
>     - Think about design the data structures and modules that will be
>     needed for Bi-directional algorithm implementation and discuss the
>     same in the list.
>     Steve and Daniel will surely provide useful insights and guidance
>     for you. :-)
>     Let us know if you have any queries.
>     Regards,
>     On Fri, Apr 20, 2012 at 10:12 PM, Razequl Islam
>     <ziboncsedu at gmail.com <mailto:ziboncsedu at gmail.com>> wrote:
>         Hi,
>         I am Razequl Islam, student of Dhaka university, Bangladesh. I
>         am new to the group. I am interested in implementing bi
>         directional searching algorithms in pgrouting, Your feedback and
>         suggestions are welcome.
>         Best Regards,
>         Razequl
>         _______________________________________________
>         pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>     -Jay Mahadeokar
>     Mtech, II Year,
>     IIT Kanpur,
>     India.
More information about the pgrouting-dev mailing list
