[pgrouting-dev] New Windows 32bit/64bit binary for PostgreSQL9.1
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jul 5 07:04:25 PDT 2012
Hi Sanak,
Thank you for all your effort to get this working and for documenting
it. We really appreciate your effort and support of the pgRouting community.
Many thanks again.
-Steve
On 7/3/2012 8:41 AM, Sanak wrote:
> Hi list,
> I had build pgRouting git version for Windows PostgreSQL9.1(x86_32/x86_64).
> https://github.com/sanak/pgrouting/downloads
>   +- pgRouting-git-sanak-mingw64_20120703_pg-9.1(x86_64).zip  => 64bit
> version
>   +- pgRouting-git-sanak-mingw32_20120703_pg-9.1(x86_32).zip  => 32bit
> version
> * Both include David Techer's roads.sql (for postgis1.x/2.x). (See
> http://www.davidgis.fr/documentation/pgrouting-1.02/)
> * If you use roads_postgis2.x.sql on PostGIS 2.0, in addition to
> "postgis.sql" and "spatial_ref_sys.sql", "legacy.sql" is necessary.
> * Shooting Star reverse cost issue still remain. (I will check Steve
> Horn's fixes(https://github.com/stevehorn/pgrouting/commits/) till next
> week)
> * This archive is not ver.1.05, because many other fixes includes after
> 1.05  release.
> Build instruction is here.
> https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw
> https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw64
> * Thanks PostGIS team for readable documents and ming64.zip archive.
> (http://trac.osgeo.org/postgis/wiki/DevWikiWinMingW64)
> And I will create github "Pull Request"(sanak:mingw) to pgrouting:master
> soon.
> Regards,
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
