[pgrouting-dev] New Windows 32bit/64bit binary for PostgreSQL9.1
Sanak geosanak at gmail.com
Thu Jul 5 23:02:52 PDT 2012
Hi guys,
Thanks for response :-)
I had added the each build environments to skydrive,
so if someone who want to make custom build on Windows exists,
use these one.
http://sdrv.ms/NFCgr2
 +- Build.zip     ... for 32bit work folder. (extract to "C:\")
 +- MinGW.zip ... for 32bit build environment. (extract to "C:\" and run
"C:\MinGW\msys\1.0\msys.bat")
 +- Build64.zip ... for 64bit work folder. (extract to "C:\")
 +- ming64.zip ... for 64bit build environment. (based on PostGIS one.
extract to "C:\" and run "C:\ming64\msys\msys.bat")
Regards,
2012/7/3 Sanak <geosanak at gmail.com>
> Hi list,
> I had build pgRouting git version for Windows PostgreSQL9.1(x86_32/x86_64).
> https://github.com/sanak/pgrouting/downloads
>  +- pgRouting-git-sanak-mingw64_20120703_pg-9.1(x86_64).zip  => 64bit
> version
>  +- pgRouting-git-sanak-mingw32_20120703_pg-9.1(x86_32).zip  => 32bit
> version
> * Both include David Techer's roads.sql (for postgis1.x/2.x). (See
> http://www.davidgis.fr/documentation/pgrouting-1.02/)
> * If you use roads_postgis2.x.sql on PostGIS 2.0, in addition to
> "postgis.sql" and "spatial_ref_sys.sql", "legacy.sql" is necessary.
> * Shooting Star reverse cost issue still remain. (I will check Steve
> Horn's fixes(https://github.com/stevehorn/pgrouting/commits/) till next
> week)
> * This archive is not ver.1.05, because many other fixes includes after
> 1.05  release.
> Build instruction is here.
> https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw
> https://github.com/sanak/pgrouting/blob/mingw/BUILD.mingw64
> * Thanks PostGIS team for readable documents and ming64.zip archive.
> (http://trac.osgeo.org/postgis/wiki/DevWikiWinMingW64)
> And I will create github "Pull Request"(sanak:mingw) to pgrouting:master
> soon.
> Regards,
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120706/da34016e/attachment.html>
More information about the pgrouting-dev mailing list
