[pgrouting-dev] postgis2 and driving distance
Mario Basa mario.basa at gmail.com
Tue Jun 19 02:11:34 PDT 2012
It really is possible now to take away CGAL from pgRouting since
st_concavehull of PostGIS 2 can create the same alpha shape. I have already
managed to compile diriving-dist without CGAL installed by modifying the
cmake files and drivedist.c.
I used this:
select st_concavehull(st_collect(
  st_geomfromewkt('srid=4326;POINT('||x1||' '||y1||')')),0.7) from
jp_2po_4pgr,
  driving_distance('SELECT id,source,target,cost,reverse_cost from
jp_2po_4pgr
  where st_contains(ST_GeomFromEWKT(''SRID=4326;POLYGON((139 35,139 36,140
36,140 35,139 35))''),
  the_geom) = true',156598,0.07,false,false) where id = edge_id;
to create the drive time polygon in the attached screen dump. The
performance isn't so bad even with a 0.7 target percent parameter for the
concave hull.
I am planning to clean up routing_dd.sql and routing_dd_wrapper.sql and
start using the newer st_* postgis functions.
Will there be any objections if I move routing_dd into core instead of
extra since it will now only use BOOST to compile.
Mario.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120619/04ef545c/attachment-0001.html>
Name: Screen Shot 2012-06-19 at 4.49.38 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120619/04ef545c/attachment-0001.png>
More information about the pgrouting-dev mailing list
