[pgrouting-dev] Schema Handling
Vicky Vergara vicky_vergara at hotmail.com
Mon Aug 19 09:18:41 PDT 2013
I made a fork of the pgrouting proyect to modify the functions so that schemas can be used:
for table:  streets  in current_schema
    vertices_tmp   will become  current_schema.steets_vertices
for table:  schema.streets
    vertices_tmp   will become schema.steets_vertices
I will modify as needed the sql files in common  and create some new functions that are needed for handling the schemas.
Once I finish, I will post the changes so they can be tested by anyone.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130819/b542be94/attachment.html>
More information about the pgrouting-dev mailing list
