[pgrouting-dev] Schema Handling
Vicky Vergara vicky_vergara at hotmail.com
Fri Aug 23 09:48:38 PDT 2013
https://github.com/cvvergara/pgrouting/tree/develop
I created a pull request for the schema handling problem.  Issue 178
Can you give it a try and report any problems?
It has a lot of NOTICES  to inform the status of the process, to help pin point any problem you encounter.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130823/76ce0296/attachment.html>
More information about the pgrouting-dev mailing list
