[pgrouting-dev] Building some tools to work with TSP
Stephen Woodbridge woodbri at swoodbridge.com
Thu Dec 12 12:10:18 PST 2013
https://github.com/pgRouting/pgrouting/wiki/Working-with-OSM-Data
Please feel free to add to this if you have useful information on
working with OSM data.
Thanks,
   -Steve
On 12/12/2013 2:49 PM, Stephen Woodbridge wrote:
> On 12/12/2013 2:07 PM, Helder Alves wrote:
>> I've already compiled that version... ;-)
>> Can you please check the query below?
>> select * from pgr_trsp(
>>      'select id, source, target, cost, reverse_cost from ways',
>>      pgr_pointstovids(
>> pgr_texttopoints('-8.6406,40.65374;-8.6637,40.64008;-8.6923,40.63095;-8.7411,40.63105',
>> 4326),
>>         'ways'),     -- array of vids
>>      false,  -- directed graph?
>>      false  -- has_reverse_cost?
>> This is the result I get from the query:
>> seq;id1;id2;cost
>> 1;-1;0;0
>> 2;-1;0;0
>> 3;-1;0;0
>> If I run a standalone pointstovids query, these are the vids I get:
>> "{228347,228369,98306,146098}"
> So you are saying:
> select * from pgr_pointstovids(pgr_texttopoints(
> 4326), 'ways');
> returns:
> and:
>    '{228347,228369,98306,146098}'::integer[],
>    false, false);
> is returning:
>   seq;id1;id2;cost
>   1;-1;0;0
>   2;-1;0;0
>   3;-1;0;0
> Hmmm, what do you get with:
>    228347, 228369, false, false);
>    228369, 98306, false, false);
>    98306, 146098, false, false);
>> I must tell you that the geometry between 228347 and 146098 is just fine
>> and routable, and to go from a vid to the other you have to go though
>> 228369 and 98306.
> Have you read and run these tools?
> http://imaptools.com:8081/pgr2-doc/2.0/en/doc/src/tutorial/analytics.html
> http://imaptools.com:8081/pgr2-doc/2.0/en/src/common/doc/functions/node_network.html
>> Do you have any idea of what is going on here?
> You have to break it down to simple queries to find the root cause of
> the problem.
> -Steve
>> Thanks! :-)
>> Helder Alves
>> +351912384076
>> On Thu, Dec 12, 2013 at 6:28 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>     On 12/12/2013 12:49 PM, Helder Alves wrote:
>>         Hi Steve,
>>         Where did you put pgr_trsptsp in the source tree?
>>     I don't think I did anything like that. IIRC, the discussion was to
>>     use pgr_vidsToDMatrix() that uses kdijkstra to compute the distance
>>     matrix, then use TSP to get the ordered list of points then call
>>     trsp with an array of locations to get point to point routes with
>>     via points. Read src/trsp/doc/index.rst in the develop branch.
>>     You might be thinking about:
>> https://github.com/pgRouting/__pgrouting/tree/develop/src/__kdijkstra
>> <https://github.com/pgRouting/pgrouting/tree/develop/src/kdijkstra>
>>       Where I Added a new version of pgr_vidsToDMatrix written in C that
>>     is 3X fast…
>>     -Steve
>>         I can't find it...
>>         Thanks!
>>         Helder Alves
>>         _________________________________________________
>>         pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org
>> <mailto:pgrouting-dev at lists.osgeo.org>
>>         http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
