[pgrouting-dev] Building some tools to work with TSP
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Thu Dec 12 11:49:04 PST 2013
On 12/12/2013 2:07 PM, Helder Alves wrote:
> I've already compiled that version... ;-)
> Can you please check the query below?
> select * from pgr_trsp(
>      'select id, source, target, cost, reverse_cost from ways',
>      pgr_pointstovids(
>   pgr_texttopoints('-8.6406,40.65374;-8.6637,40.64008;-8.6923,40.63095;-8.7411,40.63105', 4326),
>         'ways'),     -- array of vids
>      false,  -- directed graph?
>      false  -- has_reverse_cost?
> This is the result I get from the query:
> seq;id1;id2;cost
> 1;-1;0;0
> 2;-1;0;0
> 3;-1;0;0
> If I run a standalone pointstovids query, these are the vids I get:
> "{228347,228369,98306,146098}"
So you are saying:
select * from pgr_pointstovids(pgr_texttopoints(
4326), 'ways');
returns:
and:
   '{228347,228369,98306,146098}'::integer[],
   false, false);
is returning:
  seq;id1;id2;cost
  1;-1;0;0
  2;-1;0;0
  3;-1;0;0
Hmmm, what do you get with:
   228347, 228369, false, false);
   228369, 98306, false, false);
   98306, 146098, false, false);
> I must tell you that the geometry between 228347 and 146098 is just fine
> and routable, and to go from a vid to the other you have to go though
> 228369 and 98306.
Have you read and run these tools?
http://imaptools.com:8081/pgr2-doc/2.0/en/doc/src/tutorial/analytics.html
http://imaptools.com:8081/pgr2-doc/2.0/en/src/common/doc/functions/node_network.html
> Do you have any idea of what is going on here?
You have to break it down to simple queries to find the root cause of
the problem.
-Steve
> Thanks! :-)
> Helder Alves
> +351912384076
> On Thu, Dec 12, 2013 at 6:28 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 12/12/2013 12:49 PM, Helder Alves wrote:
>         Hi Steve,
>         Where did you put pgr_trsptsp in the source tree?
>     I don't think I did anything like that. IIRC, the discussion was to
>     use pgr_vidsToDMatrix() that uses kdijkstra to compute the distance
>     matrix, then use TSP to get the ordered list of points then call
>     trsp with an array of locations to get point to point routes with
>     via points. Read src/trsp/doc/index.rst in the develop branch.
>     You might be thinking about:
>     https://github.com/pgRouting/__pgrouting/tree/develop/src/__kdijkstra <https://github.com/pgRouting/pgrouting/tree/develop/src/kdijkstra>
>       Where I Added a new version of pgr_vidsToDMatrix written in C that
>     is 3X fast…
>     -Steve
>         I can't find it...
>         Thanks!
>         Helder Alves
>         _________________________________________________
>         pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>         http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
More information about the pgrouting-dev
