[pgrouting-dev] Building some tools to work with TSP
Helder Alves helderalvespt at gmail.com
Thu Dec 12 11:07:54 PST 2013
I've already compiled that version... ;-)
Can you please check the query below?
select * from pgr_trsp(
    'select id, source, target, cost, reverse_cost from ways',
    pgr_pointstovids(
 pgr_texttopoints('-8.6406,40.65374;-8.6637,40.64008;-8.6923,40.63095;-8.7411,40.63105',
4326),
       'ways'),     -- array of vids
    false,  -- directed graph?
    false  -- has_reverse_cost?
This is the result I get from the query:
seq;id1;id2;cost
1;-1;0;0
2;-1;0;0
3;-1;0;0
If I run a standalone pointstovids query, these are the vids I get:
"{228347,228369,98306,146098}"
I must tell you that the geometry between 228347 and 146098 is just fine
and routable, and to go from a vid to the other you have to go though
228369 and 98306.
Do you have any idea of what is going on here?
Thanks! :-)
Helder Alves
+351912384076
On Thu, Dec 12, 2013 at 6:28 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 12/12/2013 12:49 PM, Helder Alves wrote:
>> Hi Steve,
>> Where did you put pgr_trsptsp in the source tree?
> I don't think I did anything like that. IIRC, the discussion was to use
> pgr_vidsToDMatrix() that uses kdijkstra to compute the distance matrix,
> then use TSP to get the ordered list of points then call trsp with an array
> of locations to get point to point routes with via points. Read
> src/trsp/doc/index.rst in the develop branch.
> You might be thinking about:
> https://github.com/pgRouting/pgrouting/tree/develop/src/kdijkstra
>  Where I Added a new version of pgr_vidsToDMatrix written in C that is 3X
> fast…
> -Steve
>  I can't find it...
>> Thanks!
>> Helder Alves
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131212/bf650782/attachment.html>
More information about the pgrouting-dev mailing list
