[pgrouting-dev] http://docs.pgrouting.org/dev/doc/src/developer/sampledata.html#sampledata
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jul 8 06:33:23 PDT 2013
On 7/8/2013 9:27 AM, Dave Potts wrote:
> On 08/07/13 14:27, Stephen Woodbridge wrote:
>> On 7/8/2013 5:59 AM, Dave Potts wrote:
> hi Steve
> What bit of software was used to visualise the existing network?  Is it
> based on a screen shot from something like  mapserver?
Yes, I used the stuff at tools/mapserver/
I you set the extents correctly in the mapfile then you can generate the
> I for one am very great full to the vast amount of effort that has been
> put in to version  2.0.
Thanks, there are an amazing large number of little things to track down
and get working. I'm so glad I made the test suite up front that has
really helped with checking for regressions. I also want to thank you
and all the other users that have taken the time to test things out and
report issues and successes.
Thanks,
   -Steve
> Dave.
>>> hi List,
>>> Is it possible to rewrite the sample data network to (
>>> )to include a more distinctive data sample?
>>> I have been trying to use it to provide an input data sample for a TSP
>>> problem.  I had problems because the current network generates several
>>> routes that all look identical to the TSP so if you attempt to do some
>>> topological work, you end up with several identicial routes selections.
>>> For example the selection
>>> SELECT  seq,  id  FROM
>>> pgr_tsp('{{0,1,3,3},{1,0,2,2},{3,2,0,2},{3,2,2,0}}',X);
>>> where x  is in the range 0-3 will generate 4 paths of which the
>>> profile is two routes of 121 or 212 measured in distance unit terms
>> Dave,
>> Daniel was trying to use one sample data for all the examples and in
>> general this as worked well for most of the examples where we are
>> computing simple routes. I think the driving distance and tsp examples
>> probably need to have a slightly larger graph too adequately
>> demonstrate the function.
>> If you have another graph that you think might be more appropriate for
>> demonstrating both of these commands commands I think there is room
>> for it. I know Daniel and I are both tied up at the moment on funded
>> project work at the moment, but it you were inclined to make an
>> additional sample graph and update the docs we would love to get a
>> pull request to help out the release.
>> We have put a lot of effort into having complete documentation
>> coverage of all the functions in 2.0. We still have some work to do
>> but this is an area that we would be happy to get help on. If you
>> don't have time to do this at least open a ticket so it gets tracked.
>> Best regards,
>>   -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
