[pgrouting-dev] http://docs.pgrouting.org/dev/doc/src/developer/sampledata.html#sampledata
Dave Potts dave.potts at pinan.co.uk
Mon Jul 8 06:27:24 PDT 2013
On 08/07/13 14:27, Stephen Woodbridge wrote:
> On 7/8/2013 5:59 AM, Dave Potts wrote:
hi Steve
What bit of software was used to visualise the existing network?  Is it
based on a screen shot from something like  mapserver?
I for one am very great full to the vast amount of effort that has been
put in to version  2.0.
Dave.
>> hi List,
>> Is it possible to rewrite the sample data network to (
>> )to include a more distinctive data sample?
>> I have been trying to use it to provide an input data sample for a TSP
>> problem.  I had problems because the current network generates several
>> routes that all look identical to the TSP so if you attempt to do some
>> topological work, you end up with several identicial routes selections.
>> For example the selection
>> SELECT  seq,  id  FROM
>> pgr_tsp('{{0,1,3,3},{1,0,2,2},{3,2,0,2},{3,2,2,0}}',X);
>> where x  is in the range 0-3 will generate 4 paths of which the
>> profile is two routes of 121 or 212 measured in distance unit terms
> Dave,
> Daniel was trying to use one sample data for all the examples and in
> general this as worked well for most of the examples where we are
> computing simple routes. I think the driving distance and tsp examples
> probably need to have a slightly larger graph too adequately
> demonstrate the function.
> If you have another graph that you think might be more appropriate for
> demonstrating both of these commands commands I think there is room
> for it. I know Daniel and I are both tied up at the moment on funded
> project work at the moment, but it you were inclined to make an
> additional sample graph and update the docs we would love to get a
> pull request to help out the release.
> We have put a lot of effort into having complete documentation
> coverage of all the functions in 2.0. We still have some work to do
> but this is an area that we would be happy to get help on. If you
> don't have time to do this at least open a ticket so it gets tracked.
> Best regards,
>   -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
