[pgrouting-dev] http://docs.pgrouting.org/dev/doc/src/developer/sampledata.html#sampledata
Dave Potts dave.potts at pinan.co.uk
Mon Jul 8 13:15:51 PDT 2013
On 08/07/13 15:36, Daniel Kastl wrote:
hi Daniel, Steve,
I had a bit of play and came up with this
map.png is the output of running
shp2img -m demo.map
The file demo.map is a mapserver file for creating the picture
mktabl.sql is an sql script for making the tables
and sql2tab.sql dumps the contents of route_table and vertexts tables as
source,target,cost setting
One off the problems that I with the existing demo map is that most of
the costs of getting from a to b is always 1, this is designed to be
different.
I any body can think of any improvements, please let me known
Dave.
> On Mon, Jul 8, 2013 at 10:27 PM, Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>> wrote:
>     On 08/07/13 14:27, Stephen Woodbridge wrote:
>         On 7/8/2013 5:59 AM, Dave Potts wrote:
>     hi Steve
>     What bit of software was used to visualise the existing network?
>      Is it based on a screen shot from something like  mapserver?
>     I for one am very great full to the vast amount of effort that has
>     been put in to version  2.0.
> Hi Steve,
> With the sample data I was a bit lazy, I must admit.
> Steve had this network image and a table, so I just used it.
> I know that it doesn't work so well for TSP and Driving Distance. Some
> larger network would be better.
> But then the SQL to copy and paste also becomes much larger.
> Well, I'm glad if someone could provide a better but still simple
> sample network for the documentation.
> It's not so easy to find something that covers all algorithms and is
> still simple.
> Right now it's still the better option than no sample network ;-)
> Daniel
>     Dave.
>             hi List,
>             Is it possible to rewrite the sample data network to (
>             )to include a more distinctive data sample?
>             I have been trying to use it to provide an input data
>             sample for a TSP
>             problem.  I had problems because the current network
>             generates several
>             routes that all look identical to the TSP so if you
>             attempt to do some
>             topological work, you end up with several identicial
>             routes selections.
>             For example the selection
>             SELECT  seq,  id  FROM
>             pgr_tsp('{{0,1,3,3},{1,0,2,2},{3,2,0,2},{3,2,2,0}}',X);
>             where x  is in the range 0-3 will generate 4 paths of
>             which the profile is two routes of 121 or 212 measured in
>             distance unit terms
>         Dave,
>         Daniel was trying to use one sample data for all the examples
>         and in general this as worked well for most of the examples
>         where we are computing simple routes. I think the driving
>         distance and tsp examples probably need to have a slightly
>         larger graph too adequately demonstrate the function.
>         If you have another graph that you think might be more
>         appropriate for demonstrating both of these commands commands
>         I think there is room for it. I know Daniel and I are both
>         tied up at the moment on funded project work at the moment,
>         but it you were inclined to make an additional sample graph
>         and update the docs we would love to get a pull request to
>         help out the release.
>         We have put a lot of effort into having complete documentation
>         coverage of all the functions in 2.0. We still have some work
>         to do but this is an area that we would be happy to get help
>         on. If you don't have time to do this at least open a ticket
>         so it gets tracked.
>         Best regards,
>           -Steve
>         _______________________________________________
>         pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130708/0eb31d0f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130708/0eb31d0f/attachment-0001.png>
MAP
  NAME "pgRouting Test Mapfile"
  EXTENT -0.25 -0.25 10 10
  SIZE 500 500
  IMAGECOLOR 238 238 153
  TRANSPARENT OFF
  CONFIG MS_ERRORFILE "stderr"
  OUTPUTFORMAT
    NAME agg_qn
    DRIVER "AGG/PNG"
    EXTENSION "png"
    MIMETYPE "image/png"
    IMAGEMODE RGB
    FORMATOPTION "INTERLACE=false"
    FORMATOPTION "QUANTIZE_NEW=ON"
    FORMATOPTION "QUANTIZE_DITHER=OFF"
    FORMATOPTION "QUANTIZE_COLORS=256"
  END
  SYMBOL
    NAME "circle"
    TYPE ELLIPSE
    POINTS 1 1 END
  END
  SYMBOL
    NAME "circle-filled"
    TYPE ELLIPSE
    FILLED TRUE
    POINTS 1 1 END
  END
  LAYER
    NAME "Streets"
    DEBUG 5
    STATUS DEFAULT
    TYPE LINE
    CONNECTIONTYPE postgis
    CONNECTION "user=postgres dbname=demo host=localhost port=5432"
    DATA "geom from route_table as foo using srid=-1 using unique id"
#    LABELITEM 'name'
    CLASS
      STYLE
        COLOR 87 87 87
        WIDTH 2
      END
      LABEL
        TYPE BITMAP
        SIZE medium
        COLOR 0 0 0
        POSITION UR
        OFFSET 2 2
      END
    END
  END
  LAYER
    NAME "Nodes"
    STATUS DEFAULT
    TYPE POINT
    DATA "geom from  vertext_table  as foo using srid=-1 using unique id"
    LABELITEM 'name'
    CLASS
      STYLE
        SYMBOL "circle-filled"
        COLOR 180 80 80
        SIZE 8
      END
      LABEL
        TYPE BITMAP
        SIZE medium
        COLOR 180 0 0
        POSITION UR
        OFFSET 6 6
      END
    END
  END
END
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130708/0eb31d0f/attachment-0002.bin>
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130708/0eb31d0f/attachment-0003.bin>
More information about the pgrouting-dev mailing list
