[pgrouting-dev] http://docs.pgrouting.org/dev/doc/src/developer/sampledata.html#sampledata
Dave Potts dave.potts at pinan.co.uk
Tue Jul 9 09:27:46 PDT 2013
On 09/07/13 17:42, Stephen Woodbridge wrote:
Setting the srs was done by choice,I wanted to ensure that the srs value
listed in postgis would match the one listed in the mapserver file.  but
if needs to be changed......
Dave.
> FYI, there are a lot of changes moving from postgis 2.0 to 2.1 in that
> all the function names have changed and that the "unknown" srid has
> changed from -1 to 0. While the function name changes are more
> obvious, the srid change is not and I notice that your definition uses
> srid=-1.
> It might be safer to not specify any srid in which case I think it
> will default to the appropriate value. I'm not sure if you can do this
> on the addgeometrycolumn() function. So we might just need to fiddle
> with stuff like this in the transition.
> -Steve
> On 7/8/2013 4:15 PM, Dave Potts wrote:
>> On 08/07/13 15:36, Daniel Kastl wrote:
>> hi Daniel, Steve,
>> I had a bit of play and came up with this
>> map.png is the output of running
>> shp2img -m demo.map
>> The file demo.map is a mapserver file for creating the picture
>> mktabl.sql is an sql script for making the tables
>> and sql2tab.sql dumps the contents of route_table and vertexts tables as
>> source,target,cost setting
>> One off the problems that I with the existing demo map is that most of
>> the costs of getting from a to b is always 1, this is designed to be
>> different.
>> I any body can think of any improvements, please let me known
>> Dave.
>>> On Mon, Jul 8, 2013 at 10:27 PM, Dave Potts <dave.potts at pinan.co.uk
>>> <mailto:dave.potts at pinan.co.uk>> wrote:
>>>     On 08/07/13 14:27, Stephen Woodbridge wrote:
>>>         On 7/8/2013 5:59 AM, Dave Potts wrote:
>>>     hi Steve
>>>     What bit of software was used to visualise the existing network?
>>>      Is it based on a screen shot from something like mapserver?
>>>     I for one am very great full to the vast amount of effort that has
>>>     been put in to version  2.0.
>>> Hi Steve,
>>> With the sample data I was a bit lazy, I must admit.
>>> Steve had this network image and a table, so I just used it.
>>> I know that it doesn't work so well for TSP and Driving Distance. Some
>>> larger network would be better.
>>> But then the SQL to copy and paste also becomes much larger.
>>> Well, I'm glad if someone could provide a better but still simple
>>> sample network for the documentation.
>>> It's not so easy to find something that covers all algorithms and is
>>> still simple.
>>> Right now it's still the better option than no sample network ;-)
>>> Daniel
>>>     Dave.
>>>             hi List,
>>>             Is it possible to rewrite the sample data network to (
>>>             )to include a more distinctive data sample?
>>>             I have been trying to use it to provide an input data
>>>             sample for a TSP
>>>             problem.  I had problems because the current network
>>>             generates several
>>>             routes that all look identical to the TSP so if you
>>>             attempt to do some
>>>             topological work, you end up with several identicial
>>>             routes selections.
>>>             For example the selection
>>>             SELECT  seq,  id  FROM
>>> pgr_tsp('{{0,1,3,3},{1,0,2,2},{3,2,0,2},{3,2,2,0}}',X);
>>>             where x  is in the range 0-3 will generate 4 paths of
>>>             which the profile is two routes of 121 or 212 measured in
>>>             distance unit terms
>>>         Dave,
>>>         Daniel was trying to use one sample data for all the examples
>>>         and in general this as worked well for most of the examples
>>>         where we are computing simple routes. I think the driving
>>>         distance and tsp examples probably need to have a slightly
>>>         larger graph too adequately demonstrate the function.
>>>         If you have another graph that you think might be more
>>>         appropriate for demonstrating both of these commands commands
>>>         I think there is room for it. I know Daniel and I are both
>>>         tied up at the moment on funded project work at the moment,
>>>         but it you were inclined to make an additional sample graph
>>>         and update the docs we would love to get a pull request to
>>>         help out the release.
>>>         We have put a lot of effort into having complete documentation
>>>         coverage of all the functions in 2.0. We still have some work
>>>         to do but this is an area that we would be happy to get help
>>>         on. If you don't have time to do this at least open a ticket
>>>         so it gets tracked.
>>>         Best regards,
>>>           -Steve
>>>         _______________________________________________
>>>         pgrouting-dev mailing list
>>>         pgrouting-dev at lists.osgeo.org
>>>         <mailto:pgrouting-dev at lists.osgeo.org>
>>>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>>> Web: http://georepublic.de <http://georepublic.de/>
More information about the pgrouting-dev mailing list
