[pgrouting-dev] Access to http://imaptools.com:8081/pgr2-doc/src/trsp/doc/index.html is timing out
Daniel Kastl daniel at georepublic.de
Sun Jul 28 08:48:01 PDT 2013
On Mon, Jul 29, 2013 at 12:45 AM, Daniel Kastl <daniel at georepublic.de>wrote:
> On Sun, Jul 28, 2013 at 10:52 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> On 7/28/2013 9:11 AM, Stephen Woodbridge wrote:
>>> On 7/28/2013 4:20 AM, Dave Potts wrote:
>>>> Hi,
>>>> I have tried to access this site several times
>>>> I get a timeout event reports :-(
>>>> Is there a problem?
>>> A/C died and I've had to power down some servers to manage the heat. I
>>> just powered it back up but is will probably get shut back down. I'll
>>> copy the doc to another server and post a new link. It is likely that
>>> I'll take all the servers down to blow the dust out of them at some
>>> point today. We have had a heat-wave and the A/C server is backup and
>>> the earliest I can get them in here is Tuesday. :(
>> I've also placed a copy temporarily at:
>> http://imaptools.com:8080/**pgr2-doc/src/trsp/doc/index.**html<http://imaptools.com:8080/pgr2-doc/src/trsp/doc/index.html>
>> Daniel - What is the process to update the main gh-pages?
> It's very easy and documented in the Readme of gh-pages branch itself:
> https://github.com/pgrouting/pgrouting/tree/gh-pages
> (maybe too perfect place to not be able to find it ;-)
> In general every HTML that gets pushed to gh-pages branch will become
> available in http://docs.pgrouting.org
> So the only thing you have to do manually is to replace the "dev"
> directory with the "build/html" directory and commit and push.
> (It's a bit more complicated if you want to add a new item to the
> index.html page, such as rc1, beta, etc.)
> .gitignore in the gh-branch should be configured correct to not publish
> the build directory for example.
> I don't know there is a way to run this automatically. Maybe it could be
> done from the Travis build script.
I forgot that with PDF and MAN a few more steps are required as you also
have to copy the new versions into the "dev" directory.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130729/fbd32e21/attachment.html>
More information about the pgrouting-dev mailing list
