[pgrouting-dev] Access to http://imaptools.com:8081/pgr2-doc/src/trsp/doc/index.html is timing out
Stephen Woodbridge woodbri at swoodbridge.com
Sun Jul 28 09:36:43 PDT 2013
On 7/28/2013 11:48 AM, Daniel Kastl wrote:
> On Mon, Jul 29, 2013 at 12:45 AM, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
>     On Sun, Jul 28, 2013 at 10:52 PM, Stephen Woodbridge
>     <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>         On 7/28/2013 9:11 AM, Stephen Woodbridge wrote:
>             On 7/28/2013 4:20 AM, Dave Potts wrote:
>                 Hi,
>                 I have tried to access this site several times
>                 I get a timeout event reports :-(
>                 Is there a problem?
>             A/C died and I've had to power down some servers to manage
>             the heat. I
>             just powered it back up but is will probably get shut back
>             down. I'll
>             copy the doc to another server and post a new link. It is
>             likely that
>             I'll take all the servers down to blow the dust out of them
>             at some
>             point today. We have had a heat-wave and the A/C server is
>             backup and
>             the earliest I can get them in here is Tuesday. :(
>         I've also placed a copy temporarily at:
>         http://imaptools.com:8080/__pgr2-doc/src/trsp/doc/index.__html
>         <http://imaptools.com:8080/pgr2-doc/src/trsp/doc/index.html>
>         Daniel - What is the process to update the main gh-pages?
>     It's very easy and documented in the Readme of gh-pages branch itself:
>     https://github.com/pgrouting/pgrouting/tree/gh-pages
>     (maybe too perfect place to not be able to find it ;-)
>     In general every HTML that gets pushed to gh-pages branch will
>     become available in http://docs.pgrouting.org
>     So the only thing you have to do manually is to replace the "dev"
>     directory with the "build/html" directory and commit and push.
>     (It's a bit more complicated if you want to add a new item to the
>     index.html page, such as rc1, beta, etc.)
>     .gitignore in the gh-branch should be configured correct to not
>     publish the build directory for example.
>     I don't know there is a way to run this automatically. Maybe it
>     could be done from the Travis build script.
> I forgot that with PDF and MAN a few more steps are required as you also
> have to copy the new versions into the "dev" directory.
I have added a script tools/publish-doc that will automate this and make
it easier for me to do this. Basically took you description gtom the
gh-pages readme. So now you(I) can do:
tools/doit
tools/publish.sh
New docs have been pushed. My servers will probably get shut down
sometime soon as the heat is rising.
-Steve
-Steve
More information about the pgrouting-dev mailing list
