[pgrouting-dev] Access to http://imaptools.com:8081/pgr2-doc/src/trsp/doc/index.html is timing out
Daniel Kastl daniel at georepublic.de
Sun Jul 28 10:09:03 PDT 2013
On Mon, Jul 29, 2013 at 1:36 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 7/28/2013 11:48 AM, Daniel Kastl wrote:
>> On Mon, Jul 29, 2013 at 12:45 AM, Daniel Kastl <daniel at georepublic.de
>> <mailto:daniel at georepublic.de>**> wrote:
>>     On Sun, Jul 28, 2013 at 10:52 PM, Stephen Woodbridge
>>     <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>         On 7/28/2013 9:11 AM, Stephen Woodbridge wrote:
>>             On 7/28/2013 4:20 AM, Dave Potts wrote:
>>                 Hi,
>>                 I have tried to access this site several times
>>                 I get a timeout event reports :-(
>>                 Is there a problem?
>>             A/C died and I've had to power down some servers to manage
>>             the heat. I
>>             just powered it back up but is will probably get shut back
>>             down. I'll
>>             copy the doc to another server and post a new link. It is
>>             likely that
>>             I'll take all the servers down to blow the dust out of them
>>             at some
>>             point today. We have had a heat-wave and the A/C server is
>>             backup and
>>             the earliest I can get them in here is Tuesday. :(
>>         I've also placed a copy temporarily at:
>>         http://imaptools.com:8080/__**pgr2-doc/src/trsp/doc/index.__**
>> html <http://imaptools.com:8080/__pgr2-doc/src/trsp/doc/index.__html>
>>         <http://imaptools.com:8080/**pgr2-doc/src/trsp/doc/index.**html<http://imaptools.com:8080/pgr2-doc/src/trsp/doc/index.html>
>>         Daniel - What is the process to update the main gh-pages?
>>     It's very easy and documented in the Readme of gh-pages branch itself:
>>     https://github.com/pgrouting/**pgrouting/tree/gh-pages<https://github.com/pgrouting/pgrouting/tree/gh-pages>
>>     (maybe too perfect place to not be able to find it ;-)
>>     In general every HTML that gets pushed to gh-pages branch will
>>     become available in http://docs.pgrouting.org
>>     So the only thing you have to do manually is to replace the "dev"
>>     directory with the "build/html" directory and commit and push.
>>     (It's a bit more complicated if you want to add a new item to the
>>     index.html page, such as rc1, beta, etc.)
>>     .gitignore in the gh-branch should be configured correct to not
>>     publish the build directory for example.
>>     I don't know there is a way to run this automatically. Maybe it
>>     could be done from the Travis build script.
>> I forgot that with PDF and MAN a few more steps are required as you also
>> have to copy the new versions into the "dev" directory.
> I have added a script tools/publish-doc that will automate this and make
> it easier for me to do this. Basically took you description gtom the
> gh-pages readme. So now you(I) can do:
> tools/doit
> tools/publish.sh
> New docs have been pushed. My servers will probably get shut down sometime
> soon as the heat is rising.
We can probably add this to the Travis script, too.
I just don't want to run it for each test, because the documentation will
not change.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130729/3985fa4a/attachment-0001.html>
More information about the pgrouting-dev mailing list
