[pgrouting-dev] Fixes for Bidirectional code just checked in
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 1 11:13:49 PDT 2013
Hi all,
I think I have just submitted changes to the bidirectional dijkstra and
astar routines the resolve the server crashes we were seeing. This
closes on major outstanding bug against 2.0.
Razequl,
I made two simple changes to your code BiDirDijkstra.cpp and the astar
version:
1. in BiDirDijkstra::initall I add:
     m_vecNodeVector.reserve(maxNode + 1);
2. in BiDirDijkstra::bidir_dijkstra I move the call to initall(maxNode);
to before construct_graph(edges, edge_count, maxNode);
This does two major things:
1. std::vector doubles the size of the array every time it needs to
increase its size and then needs to copy the old data to the new area.
2. reserve() pre allocates all the memory we need once, which avoid
realloc memory fragmentation and avoids the copy each time it reallocs
so this improves performance.
Anytime you know how much space you are going to need you should reserve
it up front.
So things look good for now.
Thanks,
   -Steve
More information about the pgrouting-dev mailing list
