[pgrouting-dev] Free as in Freedom OSM converter
Daniel Kastl daniel at georepublic.de
Mon Jun 10 20:24:18 PDT 2013
On Tue, Jun 11, 2013 at 12:10 PM, Stephen Mather
<stephen at smathermather.com>wrote:
>  Hi Daniel,
> I noticed the bigint issue-- I suppose this only became a problem a few
> months back... .
There is an issue for this:
https://github.com/pgRouting/osm2pgrouting/issues/16
> Re: 2.0, any sense of what API changes would affect osm2pgrouting?  I
> might poke under the hood to procrastinate from other work... .
It should only affect function names, mainly pgr_createTopology:
I think this file:
https://github.com/pgRouting/osm2pgrouting/blob/master/src/Export2DB.cpp
Daniel
> Best,
> Steve
> On 06/10/2013 11:01 PM, Daniel Kastl wrote:
> On Tue, Jun 11, 2013 at 11:11 AM, Stephen Mather <mather.stephen at gmail.com
> > wrote:
>>  Hi All,
>>  Is (for the moment) OSM2pgrouting a zombie project, or has there been
>> work to port this for 2.0?  I'm using OSM2po at the moment, but thought I'd
>> check in on status of free as in freedom alternatives.
>> Thanks,
>> Best,
>> Steve
>  Hi Steve,
>  osm2pgrouting needs some work, because
>    1. Not compatible with PostGIS 2.0 and the new pgRouting 2.0
>    2. Cannot handle the new OSM bigint ID's
> It was some years ago written by Daniel Wendt and then hosted together
> with pgRouting and like this found its way to Github.
> There is not much activity except some modifications over the years. But
> it has so far worked and just recently we have the issues as described
> before.
>  Currently pgRouting has priority. If someone wants to fix the issues
> with osm2pgrouting, then that's very welcome.
> There is a good alternative to process OSM data, named "osm2po". But it's
> not released under Open Source license, if that's OK for you.
>  Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130611/4f1deff6/attachment-0001.html>
More information about the pgrouting-dev mailing list
