[pgrouting-dev] Free as in Freedom OSM converter
Stephen Mather stephen at smathermather.com
Mon Jun 10 20:10:04 PDT 2013
Hi Daniel,
I noticed the bigint issue-- I suppose this only became a problem a few
months back... .
Re: 2.0, any sense of what API changes would affect osm2pgrouting?  I
might poke under the hood to procrastinate from other work... .
Best,
Steve
On 06/10/2013 11:01 PM, Daniel Kastl wrote:
> On Tue, Jun 11, 2013 at 11:11 AM, Stephen Mather
> <mather.stephen at gmail.com <mailto:mather.stephen at gmail.com>> wrote:
>     Hi All,
>     Is (for the moment) OSM2pgrouting a zombie project, or has there
>     been work to port this for 2.0?  I'm using OSM2po at the moment,
>     but thought I'd check in on status of free as in freedom alternatives.
>     Thanks,
>     Best,
>     Steve
> Hi Steve,
> osm2pgrouting needs some work, because
>  1. Not compatible with PostGIS 2.0 and the new pgRouting 2.0
>  2. Cannot handle the new OSM bigint ID's
> It was some years ago written by Daniel Wendt and then hosted together
> with pgRouting and like this found its way to Github.
> There is not much activity except some modifications over the years.
> But it has so far worked and just recently we have the issues as
> described before.
> Currently pgRouting has priority. If someone wants to fix the issues
> with osm2pgrouting, then that's very welcome.
> There is a good alternative to process OSM data, named "osm2po". But
> it's not released under Open Source license, if that's OK for you.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130610/623184c6/attachment.html>
More information about the pgrouting-dev mailing list
