[pgrouting-dev] testing TSP example fails
Stephen Mather stephen at smathermather.com
Sat Jun 15 13:16:24 PDT 2013
I have not tried tests yet but have have run astar and djikstra w no problem.  When does vacation start... I can run tests asap...  :)
Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>On 6/15/2013 2:44 PM, Stephen Mather wrote:
>> Hi All,
>> More TSP for today.  In testing the example in the docs against the
>> example data, I get what is to me a cryptic error:
>> SELECT * FROM pgr_tsp('SELECT id AS source_id, x, y FROM
>> vertex_table','2,7,11',7);
>> ERROR:  Error TSP fail to findEulerianPath, check your distance matrix
>> is valid.
>This typically means there is something bad happening in the distance
>matrix that is getting passed to the TSP function. Hmmm.
>I would start with can you run the test cases or do they fail on your
>system.
>What OS system and versions of stuff are you running?
>There TSP solution for 3 points is a triangle, it is a trivial case
>where the input is the output. I thought is tested for that case but
>maybe not.
>BTW, I will be away on vacation without net access through June 25th, so
>I will not be much help until I get back.
>-Steve
>> ********** Error **********
>> ERROR: Error TSP fail to findEulerianPath, check your distance matrix is
>> valid.
>> SQL state: XX000
>> I get an entirely different error against my OSM data, but one error at
>> a time... .
>> Best,
>> Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
