[pgrouting-dev] library versions
Daniel Kastl daniel at georepublic.de
Thu Jun 27 20:21:04 PDT 2013
On Fri, Jun 28, 2013 at 12:02 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 6/27/2013 10:07 PM, Stephen Mather wrote:
>> In the documentation for compilation, several of the library version are
>> listed as TBD-- any guesses/recommendations (known versions that work)
>> for those libraries?  What does a typical (in Steve's case) debian build
>> look like library-wise?
> libcgal-dev/squeeze uptodate 3.6.1-2
> libcgal5/squeeze uptodate 3.6.1-2
> cmake version 2.8.10.2
> libboost-date-time1.42-dev/**squeeze uptodate 1.42.0-4
> libboost-date-time1.42.0/**squeeze uptodate 1.42.0-4
> libboost-dev/squeeze uptodate 1.42.0.1
> libboost-iostreams1.42.0/**squeeze uptodate 1.42.0-4
> libboost-mpi-python-dev/**squeeze uptodate 1.42.0.1
> libboost-mpi1.42-dev/squeeze uptodate 1.42.0-4
> libboost-mpi1.42.0/squeeze uptodate 1.42.0-4
> libboost-program-options-dev/**squeeze uptodate 1.42.0.1
> libboost-program-options1.42-**dev/squeeze uptodate 1.42.0-4
> libboost-program-options1.42.**0/squeeze uptodate 1.42.0-4
> libboost-serialization1.42-**dev/squeeze uptodate 1.42.0-4
> libboost-serialization1.42.0/**squeeze uptodate 1.42.0-4
> libboost-thread-dev/squeeze uptodate 1.42.0.1
> libboost-thread1.42-dev/**squeeze uptodate 1.42.0-4
> libboost-thread1.42.0/squeeze uptodate 1.42.0-4
> libboost1.42-dev/squeeze uptodate 1.42.0-4
> psql (PostgreSQL) 9.2.4
> what else am I forgetting?
Hi Steve,
I don't know about Debian, but it shouldn't be too much different to Ubuntu
package names. Maybe the versions might be a bit older.
This is a Vagrant setup script for my Ubuntu build environment, that
compiles PostGIS as well:
https://github.com/pgRouting/pgrouting/blob/develop/tools/vagrant/bootstrap.sh
>From that script the list of packages that get installed is
   - libcgal-dev
   - libboost-graph-dev
   - libboost-thread-dev
   - postgresql-$POSTGRESQL_VERSION
   - postgresql-contrib-$POSTGRESQL_VERSION
   - postgresql-server-dev-$POSTGRESQL_VERSION
The other packages are for PostGIS and packaging.
Usually the packages above should also install dependencies.
But maybe Steve can help better, because he usually works on Debian.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130628/5202ca6a/attachment-0001.html>
More information about the pgrouting-dev mailing list
