[pgrouting-dev] library versions
Stephen Mather stephen at smathermather.com
Thu Jun 27 20:32:12 PDT 2013
I prefer Ubuntu, but knew that Steve was a Debian guy, so figured it'd
work there if anywhere.  I'll give the script a spin tomorrow-- it looks
like neither topology building nor TSP is working for me on Debian either.
Best,
Steve
On 06/27/2013 11:21 PM, Daniel Kastl wrote:
> On Fri, Jun 28, 2013 at 12:02 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 6/27/2013 10:07 PM, Stephen Mather wrote:
>         In the documentation for compilation, several of the library
>         version are
>         listed as TBD-- any guesses/recommendations (known versions
>         that work)
>         for those libraries?  What does a typical (in Steve's case)
>         debian build
>         look like library-wise?
>     libcgal-dev/squeeze uptodate 3.6.1-2
>     libcgal5/squeeze uptodate 3.6.1-2
>     cmake version 2.8.10.2
>     libboost-date-time1.42-dev/squeeze uptodate 1.42.0-4
>     libboost-date-time1.42.0/squeeze uptodate 1.42.0-4
>     libboost-dev/squeeze uptodate 1.42.0.1
>     libboost-iostreams1.42.0/squeeze uptodate 1.42.0-4
>     libboost-mpi-python-dev/squeeze uptodate 1.42.0.1
>     libboost-mpi1.42-dev/squeeze uptodate 1.42.0-4
>     libboost-mpi1.42.0/squeeze uptodate 1.42.0-4
>     libboost-program-options-dev/squeeze uptodate 1.42.0.1
>     libboost-program-options1.42-dev/squeeze uptodate 1.42.0-4
>     libboost-program-options1.42.0/squeeze uptodate 1.42.0-4
>     libboost-serialization1.42-dev/squeeze uptodate 1.42.0-4
>     libboost-serialization1.42.0/squeeze uptodate 1.42.0-4
>     libboost-thread-dev/squeeze uptodate 1.42.0.1
>     libboost-thread1.42-dev/squeeze uptodate 1.42.0-4
>     libboost-thread1.42.0/squeeze uptodate 1.42.0-4
>     libboost1.42-dev/squeeze uptodate 1.42.0-4
>     psql (PostgreSQL) 9.2.4
>     what else am I forgetting?
> Hi Steve,
> I don't know about Debian, but it shouldn't be too much different to
> Ubuntu package names. Maybe the versions might be a bit older.
> This is a Vagrant setup script for my Ubuntu build environment, that
> compiles PostGIS as well:
> https://github.com/pgRouting/pgrouting/blob/develop/tools/vagrant/bootstrap.sh
> From that script the list of packages that get installed is
>   * libcgal-dev
>   * libboost-graph-dev
>   * libboost-thread-dev
>   * postgresql-$POSTGRESQL_VERSION
>   * postgresql-contrib-$POSTGRESQL_VERSION
>   * postgresql-server-dev-$POSTGRESQL_VERSION
> The other packages are for PostGIS and packaging.
> Usually the packages above should also install dependencies.
> But maybe Steve can help better, because he usually works on Debian.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130627/358ec776/attachment.html>
More information about the pgrouting-dev mailing list
