[pgrouting-dev] pgRouting 2.0 Update
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 14 18:55:18 PDT 2013
Hi all,
Made some major progress today. On mingw64, I can now build, and install
on pg 9.2 with postgis 2.0. I tested the trsp function only with success.
I think my next steps are:
1. check things back on linux and in pg 8.4
2. review all the sql code for changes like adding st_ to function
3. setup mingw32 and test it here
4. look into postgis 2.2
5. package up the windows support
6. start looking at pgrouting 2.0 changes
Thanks,
   -Steve
Works as follows:
createdb mydb
psql mydb
create extension plpgsql;
create extension postgis;
create extension pgrouting;
\i core/trsp/test/trsp-test-data.sql
select * from turn_restrict_shortest_path(
     'select eid as id, source::integer, target::integer,cost,
reverse_cost from edges1',
     1,     -- edge_id for start
     0.5,   -- midpoint of edge
     6,     -- edge_id of route end
     true,  -- directed graph?
     true,  -- has_reverse_cost?
     null); -- no turn restrictions
     1,     -- node_id of start
     5,     -- node_id of end
               -- include the turn restrictions
     'select to_cost, teid as target_id, feid||coalesce('',''||via,'''')
as via_path from restrictions1');
\q
More information about the pgrouting-dev mailing list
