[pgrouting-dev] routing application
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 14 19:03:18 PDT 2013
On 3/14/2013 1:11 AM, Ranjeet Paswan wrote:
> dear sir,
> i m working with an application on pg routing and want your to know that
> is it possible to carry forward the same with in dot net.
Hi Ranjeet,
I'm not sure what you are think about here.
1. do you want to create a .NET application that can make a request to a
postgresql database to do routing? then yes this is very easy and
straight forward.
2. do you want to move the routing out of the database and into .NET?
Then the short answer is no, the longer answer is sure if you want to
recode everything in .NET and figure out how to replace all the database
functions that are getting done in postgresql and postgis today. I think
there are other routing libraries available already in .NET, but maybe
not opensource ones.
-Steve
More information about the pgrouting-dev mailing list
